- Thank you received: 486
In the OP's case, the simplest improvement he can make is to increase the motor voltage to move the torque curve upwards. Yes, he may still need to increase the size of his motor in the end, but using a 48v power supply is perfectly matchd with his motor drivers. Take the easy win first.
This is the answer the OP should have gotten, thank you.
He did in my very first post on this thread...
You might find that 48V with the stepper drivers set to a lower max current gives a better balance.As for my cnc I use 24V because when I supply 48 then mototrs become very hot.
