- Thank you received: 7491
High initial torque at low speed does not mean efficient motor utilization. Usually power is the more important. Bias the motor’s operating point through power transmission gearing to operate the motor at its maximum power; normally just past its corner frequency.
[/quote]In the OP's case, the simplest improvement he can make is to increase the motor voltage to move the torque curve upwards. Yes, he may still need to increase the size of his motor in the end, but using a 48v power supply is perfectly matchd with his motor drivers. Take the easy win first.
