ubuntu 14.04.1 linuxcnc help
10 years 11 months ago - 10 years 11 months ago #65508 by tjmarch
Andy
If you noticed I said I started LCNC in SIM mode. I can not test on real machine yet mine is not complete. Machine it self is in Michigan where I live. I have all electronic in Kansas City with me. I am working here.
Attached are a few photos of my work
Tim
Last edit: 10 years 11 months ago by tjmarch.
10 years 11 months ago #65510 by andypugh
tjmarch wrote: If you noticed I said I started LCNC in SIM mode
There is a certain amount of confusion here due to terminological inexactitude.
There are "sim" configs supplied with LinuxCNC. These have HAL simulations of things like home switches.
There also used to be dedicated "simulator" builds of LinuxCNC, intended to be used on machines without realtime kernels.
(for example; wiki.linuxcnc.org/cgi-bin/wiki.pl?LinuxCNC_Pure_Simulator )
With the development of "uspace" there is now no need for a "pure simulator" build, and you can run a "uspace" build on any kernel and it will work. It may even be able to drive hardware, but probably not well.
Your dmesg output shows that the system is running a Xenomai kernel. I think that the "POSIX non-realtime" message implies that LinuxCNC has not found the Xenomai kernel, or does not know how to interact with it.
The Machinekit project is the result of a team doing an awful lot of work to make LinuxCNC run on Xenomai, and then having that work rejected by the release manager. I rather wish that hadn't happened.
10 years 11 months ago - 10 years 11 months ago #65514 by tjmarch
Andy
I made similar script file for Machinekit and posted on Machinekit google group but withdrew post because Machinekit will not build on Ubuntu based distro Ubuntu or Mint anymore, I do not like Debian prefer Mint. From what I gather from reading there is no plans to correct this problem. Plus over there they are really stuck on BBB not much said about PC based machine control. I do not want to use BBB, stepper driver for cape have limited current capabilities. That is why I am now focused on LCNC.
Tim
10 years 11 months ago #65515 by Razor_keen
Other than the confusion over the xenomai kernel, the preempt kernel should work just fine right?
although, with an older kernel some ubuntu functions like app armor may not work. This was the problem i ran into using kernels from kernel.org.
also, the weird thing is, that when i run xconfig, it changes the settings in the stock config as well. it seems like that shouldnt happen.
10 years 11 months ago #65517 by andypugh
Razor_keen wrote: Other than the confusion over the xenomai kernel, the preempt kernel should work just fine right?
Absolutely. Sorry if I have dragged this discussion into debate over one minor point. The rest of the functionality looks great.
Just choose to install RTAI (for the best latency, I would certainly suggest that for a parallel port system) or RT-PREEMPT (which is the only choice for an Ethernet system).
10 years 11 months ago #65518 by tjmarch
Razor
Give it a try I think it should work
Tim
Time to create page: 0.109 seconds
