ubuntu 14.04.1 linuxcnc help
10 years 9 months ago #69278 by tjmarch
10 years 9 months ago - 10 years 9 months ago #69281 by probamo
Thanks both for feedback.
Following instruction,since i have 14.04.3 i got the following error (there is no linuxcnc folder in my home place)
Last edit: 10 years 9 months ago by probamo.
10 years 9 months ago #69290 by PCW
Replied by PCW on topic ubuntu 14.04.1 linuxcnc help
Debug file information:
intel_do_flush_locked failed: Input/output error
looks like OpenGL problem
wiki.linuxcnc.org/cgi-bin/wiki.pl?Troubl...oftware_based_OpenGL
may help
10 years 9 months ago #69292 by probamo
:lol:
Do I need telling you more. Awesome!!! Thank YOU to the SKY!!!
Tested AXIS and GNOMOCAPPY.
8 years 5 months ago #111271 by Marcodi
tjmarch wrote: UPDATED DOWNLOADS ON 11/25/2015 (made changes in grub setting for latency, better latency results)
I have a couple of files you may be interested in if you what to compile LinuxCNC you will have the option to install Rtai, Rt-preempt or Xenomai kernels. The script file will works with Debian Wheezy, Ubuntu 14.04 and Linuxmint 17.2. With Ubuntu you will get a splat error near end of script if you install Rt-preempt just report error to get rid of message there will be no problems. Script file will make grub changes for latency and add cam resources to Inkscape. I also made Menu items for start menu. The last time I used it documentation would not build as html, but PDF worked fine. I think there is a mistake in git for the html build. When I tested this it built html for a couple of days then would not work after that. In Readme there are some references near the end of file for some CAM software that you might not be aware of. Files can be downloaded from below link they are two large to up-load here.
to get quick view of files
drive.google.com/folderview?id=0B4sgGWsB...nWmxRX0E&usp=sharing
to download archive
www.dropbox.com/s/0b3m8gsw6o78lca/linuxcnc.tar.gz?dl=0
to download readme
www.dropbox.com/s/9ixxmrse37jd1a5/Readme.txt?dl=0
Tim March :)
Does anyone have these files somewhere, i am running into the same problem with linux mint on virtual machine. I have searched everywhere on the forum for these files but couldn't find them, none of the links are working. Little help please.
Thx
8 years 5 months ago #111300 by tjmarch
Please read the following post
forum.linuxcnc.org/9-installing-linuxcnc...2?limitstart=0#68341
You maybe interested in this also
forum.linuxcnc.org/9-installing-linuxcnc...b?limitstart=0#86179
Sorry files are not available
Tim March
Time to create page: 0.142 seconds
