- Thank you received: 22
I have made a ISO to install Linuxcnc software it contains Deb files that I created and packages downloaded from Canonical IP to be used on a pre-installed operating system of Ubuntu 14.04 or Linux Mint 17. The install process of Linuxcnc only will take about 5 minutes. The ISO image must be mounted then a script file is run to install the needed packages that are contained in the image. If any packages that are still needed for the install due to flavor differences will download from Canonical Trusty repo. I am requesting permission to make this ISO public and for no personal gain on the Linuxcnc.org web site. ISO image will be free of charge and no gain for Linuxcnc.org.
I just meant some may have a preference, and may opt for both kernels for experimental purposes
