ubuntu 14.04.1 linuxcnc help
10 years 10 months ago #66943 by Razor_keen
i know you meant not the os' i just meant it was my first idea. i see now it may be a problem due to all the diffrent flavors. minor oversight, sorry.
10 years 10 months ago - 10 years 10 months ago #66988 by Razor_keen
For whatever reason i did not catch the last post you made, and spent much of the day thinking about how the iso might be setup in order to install the needed files. my thoughts gravitated towards a bootable iso, in which the user was placed in a command line session, and went through the setup in a question and answer format, each answer deciding which files were to be selected. ive seen this before, but the documentation is a little buried, aka i could not find it.
Are you planiing on having the user mount iso while in os or at bootup?
im assuming the options will be given in command line form as i mentioned before? Or how much did you plan on automating?
If question and answer format, there could also be an instruction on how to find which os, 32 or 64 bit , in case a user is not sure, to minimize some minor mistakes.
If i knew more about the process you planned to follow i might be able to help a little more.
Maybe we could set up an outline, to break up what is needed to be done to allow a faster work flow?
Last edit: 10 years 10 months ago by Razor_keen.
10 years 10 months ago #66994 by tjmarch
Jason
Just arrived in Kansas City been in airplanes and airports for about 8 hours, flight delays.
To answer some questions for you, I have done a similar project like this before don't worry about examples, I have them.
Jason wrote
Are you planning on having the user mount iso while in os or at bootup
Mount while in OS
No need for user to answer question about 32 or 64 bit there are ways of detecting that. If 32 bit OS is detected user would answer if they would want Rtai or Rt kernels or both. 64 bit install would not need any questions.Then files would be loaded automatically user would not search for anything.
ISO will contain a couple of archives,(archives to keep ISO size down) of needed packages and a install script and some readme files for dedicated topics, (latency, smi, and maybe kernel related items) so a person doesn't have to search the internet for the info. They would start installation process from the command line. What I will work on next is extracting archives to ram drive so there would not be any writing to the hard drive of files in archives and will result in very fast install. See link below to understand more about ram drive
www.jamescoyle.net/how-to/943-create-a-ram-disk-in-linux
Jason I can take care of the ISO, what would be a great help is if you documented what you would want to include in readme topics. Remember it needs to be wrote as if you were talking to someone who has never seen linux before, which will be the case for some. If there are command line instructions that need to be included I can help with that.
Another area of help would be if we both were able to use Virtualbox to test installation process of our creation on the 36 different OS. If you do not know how to use Virtualbox I can make you up a cheat sheet.
Also I need to know if you received a email from me with the 2 pdf's I sent you, so I know that is a good email address. Because I do not want to post a trial of ISO on this forum just the finished product. I have a space we can share on a private server to keep track of progress.
Tim
10 years 10 months ago - 10 years 10 months ago #66997 by Razor_keen
Tim
I have recieved many emails from this site yet none from you as a personal email. im nit sure if it may have something to do with user preferences.. i may need to look into that. sorry.
I think laymens terms may be a close assumption of what i can provide. I have a good understanding of certain aspects of the steps weve taken to minimize latency but ive made a bit more progress on my specific system. Ive spent some time researching overclocking of various aspects of the arch assosiated with the computer im on, and customizing its bios.
Its shown some promise albiet i crashed this thing four times now.
ussually when i spend too much time in one area i hit road blocks so being there is new avenues to focus my attention i should come back to the bios later and maybe have new ideas
so give me two days. the read me should include the various grub assignments that apply to difffrent procss. and an explanation of why we added the smi contrl. also i feel there should be some expressed cautions about cpu temp regardless of smi and a few refrences because we should downgrade safe process temp due to uneven use of cpu. its really a matter of 5 to 10 max but should be considered.
I found ways of modifying these values but its directly inverse to producing bettter latency. i will include them if i can find out which process it is abusing or(most likely conflicting with)
The disadvantages of using 64 it should come before the advantages because very few actually need a virtual system, and it sounds like a selling many may never use,
Wine is a more popular choice for casual users
It would be explained first.
The best i could explain between rtai and rt is there affinities towards certain hardware, like rt supporting more ethernet and rtai sopporting a focus on i/o throughput at the expense or response, at times. I feel this is mentionable do to the software stop, that may at times react slower under rtai at times.
as far as commands to enter they would have to be at review of what your planning. If you need my direct email, and the site is not helping i will provide someway of direct contact. It seems tho that there are plenty of people that are watching the progress made here and may be able to help at some point.
Noticing the type of install you are wanting to perform, lox ram systems may not be able to handle it. even at 2 gb some systems retain a portion that is not usable by the os, it shouldnt be a problem for most installs but it should be outlined if during testing It proved to use more than fifty percent, or if a bug introduced more files than we anticipated. certainly it would overcome a system with only a gb of ram. the files are not that large though it shouldnt be a problem
I hope some of this is useful
Regards
Jason
10 years 10 months ago #66999 by tjmarch
Trying not to confuse you. But the reason I want you to know how to use VM is to test the install process on different OS's
You can install OS with a ISO, (no disk needed) update it as if it was going to be the system you are going to use to run linuxcnc. Then take a snap shot preserving that state. Then when install test, (ex. just rtai kernel) is done you restore snap shot and try install with different option, (ex. rtai and Rt kernel). Saves a a lot of time and the expense of burning a bunch of disk.
Tim
10 years 10 months ago #67009 by Razor_keen
tim
my oppologies. when i wrote that i was referring to my opinion on possible user preferences.
wine and dual-boot both seem to work well for cad, and are the better options for a 32 bit system. For a 64bit system naturally a virtual machine would be better than wine (which is buggy in 64bit), and comes with easy access to files in the linux hierarchy.
I suppose it doesnt make as much sense to include this if the primary intent is to install it on to preexisting os, but for anyone who is not yet commited to an os, it may carry some weight.
Time to create page: 0.205 seconds
