(superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
- Topic Author
- Online
- Thank you received: 5951
09 Jul 2020 08:10 #174068
Replied by tommylight on topic (superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
KUKA robots above KRC4 should also be run on Linux, not sure abut Mazak and some others. Okuma uses windoze still and a lot of other manufacturers, that really should be the deal breaker for that type of machines.
I had a Kuka KRC1 lock twice in a single run of about two hours, KRC2 once every now and then, and they used a stripped down version of Win. Some days ago i had a big industrial 400A plasma cnc at 8X2.5M try to kill me twice as it would start to violently move the gantry in one direction (my direction) twice when winXP locked solid. Not a nice feeling.
Car industry has long gone to Linux or Android for diagnostics systems. I think only Mercedes uses windoze as their software is developed by Siemens and they have very cheap windoze due to the volume they use, same thing with Bosch, they also use everything from Siemens on the software and electronics side.
- dvn4life1972
- Thank you received: 168
25 Jul 2020 23:41 #175823
by dvn4life1972
Replied by dvn4life1972 on topic (superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
I'm trying to install Linuxcnc on my new PC, and apparently it won't install the Debian version. Instead, I found this thread and installed per instructions. First let me say, Mint looks a lot 'cleaner' (maybe modern is a better way to describe). Anyway, whenever I ran pncconf and entered the stepper scale and attempted to test, it says I'm running a simulation. That's different for me. Did I install Mint/Linuxcnc wrong?
- Topic Author
- Online
25 Jul 2020 23:46 #175824
What does
uname - a
say ?
uname - a
say ?
The following user(s) said Thank You: dvn4life1972
- dvn4life1972
25 Jul 2020 23:49 #175825
by dvn4life1972
I don't recall seeing that. Forgive me, because I'm a little lost inside of Mint as it's layed out a bit different than Debian was. Where can I find that?
- Topic Author
- Online
25 Jul 2020 23:51 #175827
in a terminal from the menu or left side on the bottom panel, black square.
- dvn4life1972
26 Jul 2020 00:13 #175829
by dvn4life1972
- Topic Author
- Online
26 Jul 2020 00:26 #175830
Did you install the kernel ?
wget http://http.us.debian.org/debian/pool/main/l/linux-signed-amd64/linux-image-5.4.0-0.bpo.4-rt-amd64_5.4.19-1~bpo10+1_amd64.deb
sudo gdebi linux-image-5.4.0-0.bpo.4-rt-amd64_5.4.19-1~bpo10+1_amd64.deb
- dvn4life1972
26 Jul 2020 00:35 #175831
by dvn4life1972
Yes sir, I did.
wget http://http.us.debian.org/debian/pool/main/l/linux-signed-amd64/linux-image-5.4.0-0.bpo.4-rt-amd64_5.4.19-1~bpo10+1_amd64.deb - sudo gdebi linux-image-5.4.0-0.bpo.4-rt-amd64_5.4.19-1~bpo10+1_amd64.deb
Yes sir, I did.
- Topic Author
- Online
26 Jul 2020 00:36 - 26 Jul 2020 00:36 #175832
Reboot and hold down ctrl+shift keys until you get the grub menu.
select the line with RT in the name
Last edit: 26 Jul 2020 00:36 by tommylight. Reason: More info
- dvn4life1972
26 Jul 2020 02:04 #175838
by dvn4life1972
We had some storms roll through and lost power. I'll try probably tomorrow when we have power again. Thanks.
Time to create page: 0.380 seconds
