(superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
- seuchato
- Thank you received: 126
23 Jun 2020 07:24 #172435
by seuchato
Replied by seuchato on topic (superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
this works:
download kernel 4.9.0-12-rt-amd64 from herehere
gdebi linux-image-4.9.0-12-rt-amd64_4.9.210-1+deb9u1_amd64.deb
edit /etc/default/grubthe line "GRUB_TIMEOUT=5" (lets you choose which kernel you like to boot)
reboot
select the newly installed kernel
hth
chris
reboot
hth
chris
- Thank you received: 7488
23 Jun 2020 07:24 #172436
Replied by tommylight on topic (superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
The same kernel for Buster will work on Mint but has to be manually downloaded and installed.And the 5.4 kernel will also work on Buster.
- seuchato
23 Jun 2020 07:46 #172440
by seuchato
Got 4.9.0-12-rt-amd64 installed, rebooted into it and am running lcnc-hw now for more than 35 minutes. So far no realtime delay. Hope it stays so.
23 Jun 2020 07:50 #172443
With or without base thread ?
You do not need base thread if you do not plan to use software stepping/parallel port, so base thread is useless in that case and might cause worse servo latency.
- seuchato
23 Jun 2020 08:20 #172449
by seuchato
I plan to use the dell 980s for a lathe and my ole router through parallel, so there is a base thread. for the deckel, I will use a hp 8300 cmt or sff. These will be tested with most suitable distro and kernel using just a servo thread. Once I got the hp's, sorted out which distro i wanna use, I will test the various machines and post the results
here
besides: I'll redo the test on buster with the 4.9.0-12-rt-amd64 kernel too. Seems, that after setting the bios and the boot parameters about right, the kernel version seems to be the next big screw to tune. Once I found the best combo out, I will freeze it like that and do further optimisation trials on my spare pcs.
greez
chris
greez
chris
- Mike_Eitel
- Thank you received: 183
23 Jun 2020 10:39 #172459
by Mike_Eitel
Replied by Mike_Eitel on topic (superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
Hi Beagle
Playing around Seeed X86 boards possibilities
Used your fine iso that I downloaded few days agoo.
I tried apt update & apt upgrade an got following error.
Reading state information... Done
91 packages can be upgraded. Run 'apt list --upgradable' to see them.
N: Skipping acquire of configured file '2.8-rtpreempt/binary-i386/Packages' as repository 'cnc.beaglebrainz.net/mintcnc bionic InRelease' doesn't support architecture 'i386'
Any idea ?
Any idea ?
- Clive S
- Thank you received: 486
23 Jun 2020 13:38 #172469
by Clive S
This is the one I used cnc.beaglebrainz.net/cdimage/cnc-19.2.0-...ate-uspace-64bit.iso
I have used it many time now without errors
Re this:- " tried apt update & apt upgrade an got following error."
I think it should be sudo apt-get update then sudo apt-get dist-upgrade
Replied by Clive S on topic (superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
Hi Beagle
Any idea ?
- Mike_Eitel
23 Jun 2020 14:10 #172470
by Mike_Eitel
Yes for sure as root / sudo... Was just to lazy to write
I'm in the moment trying to run the latency script. Just have to find how i can loggin on the screen as root. Via xrdp i can, but that script will correctly not run remote.
And i'm in the same time going to add another m2 ssd. So maybe i will reinstall on that in parallel ... But anyhow, all versions of upgrading should in my eyes work...
Mike
Mike
- seuchato
23 Jun 2020 14:30 #172472
by seuchato
Mike
What script do you want to run?
Normally opening a terminal (xterm) and a "sudo <runthatscript>" should be possible and successful
If you want a root password, then dogreez
chris
sudo su
passwdchris
- Mike_Eitel
23 Jun 2020 15:03 #172478
by Mike_Eitel
I know.
And actualy i started a while ago from user in a terminal as su. And now screen shows some windsurfer.... So your scripts seems to run
Was not able to follow after start as i'm heavily distracted by my dayjob..
I saw that it is not running when logged in as root. There are a few things that make problems as i installed xrdp. And the new mint and rdp is not yet very compatible.
And also Tommy dislikes windows, i do a lot of remote via rdp, from my bussiness notebook.
So hope to add some measurements too, with not at all adapted version.
Mike
Mike
The following user(s) said Thank You: seuchato, tommylight
Time to create page: 0.696 seconds
