Raspberry Pi 4 Tutorial - fatal error
6 years 3 months ago #174337 by phillc54
Replied by phillc54 on topic Raspberry Pi 4 Tutorial
Glad you got it working.
It would be nice to know what errors you got when using apt to install the packages. apt does call dpkg so it should work and it does for me.
6 years 3 months ago #174346 by moonco
Replied by moonco on topic Raspberry Pi 4 Tutorial
Here is what was reading out on terminal. Maybe these aren't errors? I am mostly new to linux. I use linux at work but very limited. We build 3d printers and I mostly need to copy, paste, move files from servers onto the computer etc.
Many files couldn't convert with latex. Also dbfatal error at 1182
=================================================== Pixel unit not handled (replaced by pt) Pixel unit not handled (replaced by pt) Pixel unit not handled (replaced by pt) Pixel unit not handled (replaced by pt) Pixel unit not handled (replaced by pt) Pixel unit not handled (replaced by pt) Pixel unit not handled (replaced by pt) Pixel unit not handled (replaced by pt) Pixel unit not handled (replaced by pt) Pixel unit not handled (replaced by pt) Pixel unit not handled (replaced by pt) Pixel unit not handled (replaced by pt) Pixel unit not handled (replaced by pt) Pixel unit not handled (replaced by pt) Cannot convert 'common/images/emc2-intro.png' to pdf Cannot convert 'user/images/whatstep1.png' to pdf Cannot convert 'gui/images/axis.png' to pdf Cannot convert 'gui/images/touchy.png' to pdf Cannot convert 'gui/images/gscreen-mill.png' to pdf Cannot convert 'gui/images/gmoccapy_3_axis.png' to pdf Cannot convert 'gui/images/ngcgui.png' to pdf Cannot convert 'gui/images/axis-pyvcp.png' to pdf Cannot convert 'gui/images/axis-gladevcp.png' to pdf Cannot convert 'user/images/naive-cam.png' to pdf inkscape -z -D --export-pdf=fig0.pdf /home/pi/emc/docs/src/user/images/mill-diagram_en.svg inkscape -z -D --export-pdf=fig1.pdf /home/pi/emc/docs/src/user/images/lathe-diagram_en.svg Image 'images/configuration-selector.png' not found Cannot convert 'getting-started/images/configuration-selector.png' to pdf Cannot convert 'config/images/stepconf-start_en.png' to pdf Cannot convert 'config/images/stepconf-base_en.png' to pdf Cannot convert 'config/images/latency-test_en.png' to pdf Cannot convert 'config/images/stepconf-parallel-1_en.png' to pdf Cannot convert 'config/images/stepconf-parallel-2_en.png' to pdf Cannot convert 'config/images/stepconf-axis-x_en.png' to pdf Cannot convert 'config/images/stepconf-x-test_en.png' to pdf Cannot convert 'config/images/stepconf-spindle_en.png' to pdf Cannot convert 'config/images/stepconf-options_en.png' to pdf inkscape -z -D --export-pdf=fig2.pdf /home/pi/emc/docs/src/config/images/switch-nc-series_en.svg inkscape -z -D --export-pdf=fig3.pdf /home/pi/emc/docs/src/config/images/switch-no-parallel_en.svg Cannot convert 'config/images/pncconf-splash.png' to pdf Cannot convert 'config/images/pncconf-basic.png' to pdf Cannot convert 'config/images/pncconf-external.png' to pdf Cannot convert 'config/images/pncconf-gui.png' to pdf Cannot convert 'config/images/pncconf-mesa-config.png' to pdf Cannot convert 'config/images/pncconf-mesa-io2.png' to pdf Cannot convert 'config/images/pncconf-mesa-io3.png' to pdf Cannot convert 'config/images/pncconf-mesa-io4.png' to pdf Cannot convert 'config/images/pncconf-parport.png' to pdf Cannot convert 'config/images/pncconf-axis-drive.png' to pdf Cannot convert 'config/images/pncconf-scale-calc.png' to pdf Cannot convert 'config/images/pncconf-axis-config.png' to pdf Cannot convert 'config/images/pncconf-diagram-lathe.png' to pdf Cannot convert 'config/images/pncconf-spindle-config.png' to pdf Cannot convert 'config/images/pncconf-advanced.png' to pdf Cannot convert 'config/images/pncconf-hal.png' to pdf inkscape -z -D --export-pdf=fig4.pdf /home/pi/emc/docs/src/lathe/images/tool-positions_en.svg inkscape -z -D --export-pdf=fig5.pdf /home/pi/emc/docs/src/lathe/images/tool-pos-1_en.svg inkscape -z -D --export-pdf=fig6.pdf /home/pi/emc/docs/src/lathe/images/tool-pos-2_en.svg inkscape -z -D --export-pdf=fig7.pdf /home/pi/emc/docs/src/lathe/images/tool-pos-3_en.svg inkscape -z -D --export-pdf=fig8.pdf /home/pi/emc/docs/src/lathe/images/tool-pos-4_en.svg inkscape -z -D --export-pdf=fig9.pdf /home/pi/emc/docs/src/lathe/images/tool-pos-5_en.svg inkscape -z -D --export-pdf=fig10.pdf /home/pi/emc/docs/src/lathe/images/tool-pos-6_en.svg inkscape -z -D --export-pdf=fig11.pdf /home/pi/emc/docs/src/lathe/images/tool-pos-7_en.svg inkscape -z -D --export-pdf=fig12.pdf /home/pi/emc/docs/src/lathe/images/tool-pos-8_en.svg inkscape -z -D --export-pdf=fig13.pdf /home/pi/emc/docs/src/lathe/images/control-point_en.svg inkscape -z -D --export-pdf=fig14.pdf /home/pi/emc/docs/src/lathe/images/ramp-entry_en.svg inkscape -z -D --export-pdf=fig15.pdf /home/pi/emc/docs/src/lathe/images/ramp-cut_en.svg inkscape -z -D --export-pdf=fig16.pdf /home/pi/emc/docs/src/lathe/images/radius-1_en.svg inkscape -z -D --export-pdf=fig17.pdf /home/pi/emc/docs/src/lathe/images/radius-2_en.svg inkscape -z -D --export-pdf=fig18.pdf /home/pi/emc/docs/src/lathe/images/radius-3_en.svg inkscape -z -D --export-pdf=fig19.pdf /home/pi/emc/docs/src/lathe/images/radius-4_en.svg Cannot convert 'plasma/images/primer_torch-head.png' to pdf Cannot convert 'plasma/images/primer_cut-angularity.png' to pdf Cannot convert 'plasma/images/primer_volts-height.png' to pdf Cannot convert 'plasma/images/primer_ohmic-sensing.png' to pdf Cannot convert 'plasma/images/primer_hypersensing.png' to pdf Cannot convert 'plasma/images/primer_thc-delay.png' to pdf Cannot convert 'plasma/images/primer_kerf-cross.png' to pdf Cannot convert 'gui/images/axis.png' to pdf convert /home/pi/emc/docs/src/gui/images/tool_estop.gif fig20.pdf convert-im6.q16: attempt to perform an operation not allowed by the security policy `PDF' @ error/constitute.c/IsCoderAuthorized/408. Unexpected error occured convert /home/pi/emc/docs/src/gui/images/tool_power.gif fig21.pdf convert-im6.q16: attempt to perform an operation not allowed by the security policy `PDF' @ error/constitute.c/IsCoderAuthorized/408. Unexpected error occured convert /home/pi/emc/docs/src/gui/images/tool_open.gif fig22.pdf convert-im6.q16: attempt to perform an operation not allowed by the security policy `PDF' @ error/constitute.c/IsCoderAuthorized/408. Unexpected error occured convert /home/pi/emc/docs/src/gui/images/tool_reload.gif fig23.pdf convert-im6.q16: attempt to perform an operation not allowed by the security policy `PDF' @ error/constitute.c/IsCoderAuthorized/408. Unexpected error occured convert /home/pi/emc/docs/src/gui/images/tool_run.gif fig24.pdf convert-im6.q16: attempt to perform an operation not allowed by the security policy `PDF' @ error/constitute.c/IsCoderAuthorized/408. Unexpected error occured convert /home/pi/emc/docs/src/gui/images/tool_step.gif fig25.pdf convert-im6.q16: attempt to perform an operation not allowed by the security policy `PDF' @ error/constitute.c/IsCoderAuthorized/408. Unexpected error occured convert /home/pi/emc/docs/src/gui/images/tool_pause.gif fig26.pdf convert-im6.q16: attempt to perform an operation not allowed by the security policy `PDF' @ error/constitute.c/IsCoderAuthorized/408. Unexpected error occured convert /home/pi/emc/docs/src/gui/images/tool_stop.gif fig27.pdf convert-im6.q16: attempt to perform an operation not allowed by the security policy `PDF' @ error/constitute.c/IsCoderAuthorized/408. Unexpected error occured convert /home/pi/emc/docs/src/gui/images/tool_blockdelete.gif fig28.pdf convert-im6.q16: attempt to perform an operation not allowed by the security policy `PDF' @ error/constitute.c/IsCoderAuthorized/408. Unexpected error occured convert /home/pi/emc/docs/src/gui/images/tool_optpause.gif fig29.pdf convert-im6.q16: attempt to perform an operation not allowed by the security policy `PDF' @ error/constitute.c/IsCoderAuthorized/408. Unexpected error occured convert /home/pi/emc/docs/src/gui/images/tool_zoomin.gif fig30.pdf convert-im6.q16: attempt to perform an operation not allowed by the security policy `PDF' @ error/constitute.c/IsCoderAuthorized/408. Unexpected error occured convert /home/pi/emc/docs/src/gui/images/tool_zoomout.gif fig31.pdf convert-im6.q16: attempt to perform an operation not allowed by the security policy `PDF' @ error/constitute.c/IsCoderAuthorized/408. Unexpected error occured convert /home/pi/emc/docs/src/gui/images/tool_axis_z.gif fig32.pdf convert-im6.q16: attempt to perform an operation not allowed by the security policy `PDF' @ error/constitute.c/IsCoderAuthorized/408. Unexpected error occured convert /home/pi/emc/docs/src/gui/images/tool_axis_z2.gif fig33.pdf convert-im6.q16: attempt to perform an operation not allowed by the security policy `PDF' @ error/constitute.c/IsCoderAuthorized/408. Unexpected error occured convert /home/pi/emc/docs/src/gui/images/tool_axis_x.gif fig34.pdf convert-im6.q16: attempt to perform an operation not allowed by the security policy `PDF' @ error/constitute.c/IsCoderAuthorized/408. Unexpected error occured convert /home/pi/emc/docs/src/gui/images/tool_axis_y.gif fig35.pdf convert-im6.q16: attempt to perform an operation not allowed by the security policy `PDF' @ error/constitute.c/IsCoderAuthorized/408. Unexpected error occured convert /home/pi/emc/docs/src/gui/images/tool_axis_p.gif fig36.pdf convert-im6.q16: attempt to perform an operation not allowed by the security policy `PDF' @ error/constitute.c/IsCoderAuthorized/408. Unexpected error occured convert /home/pi/emc/docs/src/gui/images/tool_rotate.gif fig37.pdf convert-im6.q16: attempt to perform an operation not allowed by the security policy `PDF' @ error/constitute.c/IsCoderAuthorized/408. Unexpected error occured convert /home/pi/emc/docs/src/gui/images/tool_clear.gif fig38.pdf convert-im6.q16: attempt to perform an operation not allowed by the security policy `PDF' @ error/constitute.c/IsCoderAuthorized/408. Unexpected error occured Cannot convert 'gui/images/axis-homed.png' to pdf Cannot convert 'gui/images/axis-limit.png' to pdf Cannot convert 'gui/images/axis-machineorigin.png' to pdf Cannot convert 'gui/images/axis-outofrange.png' to pdf Cannot convert 'gui/images/axis-currentandselected.png' to pdf Cannot convert 'gui/images/touchoff.png' to pdf Cannot convert 'gui/images/axis-mdi.png' to pdf Cannot convert 'gui/images/axis-emc-status.png' to pdf Cannot convert 'gui/images/manual-tool-change.png' to pdf Cannot convert 'gui/images/axis-lathe-tool.png' to pdf Cannot convert 'gui/images/axis-foam.png' to pdf Cannot convert 'gui/images/holes.png' to pdf Cannot convert 'gui/images/gmoccapy_5_axis.png' to pdf Cannot convert 'gui/images/gmoccapy_3_axis.png' to pdf Cannot convert 'gui/images/gmoccapy_ntb_preview_maximized_2.png' to pdf Cannot convert 'gui/images/gmoccapy_ntb_preview.png' to pdf Cannot convert 'gui/images/gmoccapy_with_left_box_in_edit_mode.png' to pdf Cannot convert 'gui/images/gmoccapy_with_right_panel_in_MDI_mode.png' to pdf Cannot convert 'gui/images/gmoccapy_mdi_hidden_keyboard.png' to pdf Cannot convert 'gui/images/gmoccapy_getting_macro_info.png' to pdf Cannot convert 'gui/images/gmoccapy_0_9_7_sim_hardware_button.png' to pdf Cannot convert 'gui/images/manual_toolchange.png' to pdf Cannot convert 'gui/images/gmoccapy_0_9_7_tool_info.png' to pdf Cannot convert 'gui/images/sketch_auto_tool_measurement.png' to pdf Cannot convert 'gui/images/gmoccapy_settings_button.png' to pdf Cannot convert 'gui/images/gmoccapy_settings_appearance.png' to pdf Cannot convert 'gui/images/gmoccapy_file_selection_dialog_with_keyboard.png' to pdf Cannot convert 'gui/images/gmoccapy_settings_hardware.png' to pdf Cannot convert 'gui/images/gmoccapy_settings_advanced.png' to pdf Cannot convert 'gui/images/gmoccapy_lathe.png' to pdf Cannot convert 'gui/images/gmoccapy_back_tool_lathe.png' to pdf Cannot convert 'gui/images/gmoccapy_plasma.png' to pdf Cannot convert 'gui/images/strange_numbers.png' to pdf Cannot convert 'gui/images/ngcgui.png' to pdf Image 'gui/images/tool_estop.gif' already converted as fig20.pdf Image 'gui/images/tool_power.gif' already converted as fig21.pdf Image 'gui/images/tool_run.gif' already converted as fig24.pdf Cannot convert 'gui/images/ngcgui-db25-1.png' to pdf Cannot convert 'gui/images/ngcgui-db25-2.png' to pdf Cannot convert 'gui/images/ngcgui-db25-3.png' to pdf Cannot convert 'gui/images/touchy.png' to pdf Cannot convert 'gui/images/gscreen-mill.png' to pdf Cannot convert 'gui/images/silverdragon.png' to pdf Cannot convert 'gui/images/spartan.png' to pdf Cannot convert 'gui/images/gaxis.png' to pdf Cannot convert 'gui/images/industrial.png' to pdf Cannot convert 'gui/images/tester.png' to pdf Cannot convert 'gui/images/tester_editor.png' to pdf Cannot convert 'gui/images/tkemc.png' to pdf Cannot convert 'gui/images/tkemc-interp.png' to pdf Cannot convert 'gui/images/tkemc-override-limits.png' to pdf Cannot convert 'gui/images/tkemc-mdi.png' to pdf Cannot convert 'plasma/images/plasmac_configurator_home_new.png' to pdf Cannot convert 'plasma/images/plasmac_configurator_new.png' to pdf Cannot convert 'plasma/images/plasmac_config.png' to pdf Cannot convert 'plasma/images/plasmac_run.png' to pdf Cannot convert 'plasma/images/plasmac_monitor.png' to pdf Cannot convert 'plasma/images/plasmac_buttons_a.png' to pdf Cannot convert 'plasma/images/plasmac_buttons_g.png' to pdf Cannot convert 'plasma/images/plasmac_control_a.png' to pdf Cannot convert 'plasma/images/plasmac_control_g.png' to pdf Cannot convert 'plasma/images/plasmac_stats.png' to pdf Cannot convert 'plasma/images/plasmac_extras.png' to pdf Cannot convert 'plasma/images/plasmac_configurator_home_used.png' to pdf Cannot convert 'plasma/images/plasmac_configurator_upgrade.png' to pdf Cannot convert 'plasma/images/plasmac_configurator_home_used.png' to pdf Cannot convert 'plasma/images/plasmac_configurator_reconfigure.png' to pdf Cannot convert 'plasma/images/plasmac_material_main.png' to pdf Cannot convert 'plasma/images/plasmac_material_dialogs.png' to pdf Cannot convert 'plasma/images/plasmac_rs485_pmx.png' to pdf Cannot convert 'plasma/images/plasmac_rs485_sunnix.png' to pdf Cannot convert 'plasma/images/plasmac_rs485_dtech.png' to pdf Cannot convert 'plasma/images/plasmac_reed_arc_ok.png' to pdf Cannot convert 'gcode/images/offsets.png' to pdf Cannot convert 'gcode/images/polar01.png' to pdf Cannot convert 'gcode/images/polar02.png' to pdf inkscape -z -D --export-pdf=fig39.pdf /home/pi/emc/docs/src/gcode/images/g2_en.svg inkscape -z -D --export-pdf=fig40.pdf /home/pi/emc/docs/src/gcode/images/g2-3_en.svg Cannot convert 'gcode/images/nurbs01.png' to pdf inkscape -z -D --export-pdf=fig41.pdf /home/pi/emc/docs/src/gcode/images/g76-threads_en.svg Cannot convert 'gcode/images/g76-01.png' to pdf inkscape -z -D --export-pdf=fig42.pdf /home/pi/emc/docs/src/gcode/images/eight-holes_en.svg inkscape -z -D --export-pdf=fig43.pdf /home/pi/emc/docs/src/gcode/images/twelve-holes_en.svg inkscape -z -D --export-pdf=fig44.pdf /home/pi/emc/docs/src/gcode/images/g81mult_en.svg inkscape -z -D --export-pdf=fig45.pdf /home/pi/emc/docs/src/gcode/images/g81ex1_en.svg inkscape -z -D --export-pdf=fig46.pdf /home/pi/emc/docs/src/gcode/images/g81ex2_en.svg inkscape -z -D --export-pdf=fig47.pdf /home/pi/emc/docs/src/gcode/images/g81_en.svg inkscape -z -D --export-pdf=fig48.pdf /home/pi/emc/docs/src/gcode/images/g81a_en.svg Cannot convert 'gui/images/image-to-gcode.png' to pdf Cannot convert 'gui/images/i2g-roughing.png' to pdf Cannot convert 'gcode/images/ToolTable-TouchOff.png' to pdf inkscape -z -D --export-pdf=fig49.pdf /home/pi/emc/docs/src/gcode/images/comp-path_en.svg inkscape -z -D --export-pdf=fig50.pdf /home/pi/emc/docs/src/gcode/images/comp02_en.svg Cannot convert 'gcode/images/outside-comp.png' to pdf Cannot convert 'gcode/images/inside-comp.png' to pdf Cannot convert 'gui/images/tooledit.png' to pdf Cannot convert 'gui/images/tooledit-sort.png' to pdf Cannot convert 'gui/images/tooledit-columns.png' to pdf Cannot convert 'config/images/servo-feedback.png' to pdf Cannot convert 'config/images/pid-feedback.png' to pdf Cannot convert 'config/images/latency-test_en.png' to pdf Cannot convert 'config/images/latency-plot.png' to pdf Cannot convert 'config/images/latency-histogram.png' to pdf Cannot convert 'config/images/step-calc-inch-math.png' to pdf Cannot convert 'config/images/step-calc-mm-math.png' to pdf Cannot convert 'config/images/encoder-counts-math.png' to pdf Cannot convert 'config/images/p-term.png' to pdf Cannot convert 'config/images/i-term.png' to pdf Cannot convert 'config/images/i-term.png' to pdf Cannot convert 'config/images/p-term.png' to pdf Cannot convert 'config/images/i-term.png' to pdf Cannot convert 'config/images/ff2.png' to pdf Cannot convert 'config/images/output-offset.png' to pdf Cannot convert 'config/images/scale-math.png' to pdf Cannot convert 'config/images/calibration-1.png' to pdf Cannot convert 'config/images/calibration-2.png' to pdf Cannot convert 'config/images/calibration-3.png' to pdf Cannot convert 'config/images/encoder-scale.png' to pdf Cannot convert 'config/images/stepper-scale.png' to pdf Cannot convert 'config/images/encoder-scale.png' to pdf Cannot convert 'config/images/HomeAxisTravel_V2.png' to pdf Cannot convert 'config/images/HomeAxisTravel_V3.png' to pdf Cannot convert 'config/images/emc2-motion-homing-diag.png' to pdf Cannot convert 'remap/images/debug_embedded_python.png' to pdf Cannot convert 'gui/images/pyvcp_group.png' to pdf Cannot convert 'gui/images/pyvcp_mypanel.png' to pdf Cannot convert 'gui/images/pyvcp_axis_lathe.png' to pdf Cannot convert 'gui/images/pyvcp_label.png' to pdf Cannot convert 'gui/images/pyvcp_led.png' to pdf Cannot convert 'gui/images/pyvcp_rectled.png' to pdf Cannot convert 'gui/images/pyvcp_button.png' to pdf Cannot convert 'gui/images/pyvcp_checkbutton.png' to pdf Cannot convert 'gui/images/pyvcp_radiobutton.png' to pdf Cannot convert 'gui/images/pyvcp_number.png' to pdf Cannot convert 'gui/images/pyvcp_s32.png' to pdf Cannot convert 'gui/images/pyvcp_bar.png' to pdf Cannot convert 'gui/images/pyvcp_meter.png' to pdf Cannot convert 'gui/images/pyvcp_spinbox.png' to pdf Cannot convert 'gui/images/pyvcp_scale.png' to pdf Cannot convert 'gui/images/pyvcp_dial.png' to pdf Cannot convert 'gui/images/pyvcp_jogwheel.png' to pdf Cannot convert 'gui/images/pyvcp_image01.png' to pdf Cannot convert 'gui/images/pyvcp_image02.png' to pdf Cannot convert 'gui/images/pyvcp_image_u32_01.png' to pdf Cannot convert 'gui/images/pyvcp_image01.png' to pdf Cannot convert 'gui/images/pyvcp_image02.png' to pdf Cannot convert 'gui/images/pyvcp_borders.png' to pdf Cannot convert 'gui/images/pyvcp_hbox.png' to pdf Cannot convert 'gui/images/pyvcp_vbox.png' to pdf Cannot convert 'gui/images/pyvcp_labelframe.png' to pdf Cannot convert 'gui/images/pyvcp_table.png' to pdf Cannot convert 'gui/images/pyvcp_tabs1.png' to pdf Cannot convert 'gui/images/pyvcp_tabs2.png' to pdf Cannot convert 'gui/images/pyvcp_tabs3.png' to pdf Cannot convert 'gui/images/xyz_ACO.png' to pdf Cannot convert 'gui/images/xyz_buttons.png' to pdf Cannot convert 'gui/images/ptest.png' to pdf Cannot convert 'gui/images/ptest-final.png' to pdf Cannot convert 'gui/images/gs2_panel.png' to pdf Cannot convert 'gui/images/pyvcp-rth.png' to pdf Cannot convert 'gui/images/example-panel-small.png' to pdf Cannot convert 'gui/images/example-tabbed-small.png' to pdf Cannot convert 'gui/images/touchy-tab-33.png' to pdf Cannot convert 'gui/images/glade-manual-small.png' to pdf Cannot convert 'gui/images/hal-pin-change-66.png' to pdf Cannot convert 'gui/images/checkbutton.png' to pdf Cannot convert 'gui/images/radiobutton.png' to pdf Cannot convert 'gui/images/button.png' to pdf Cannot convert 'gui/images/hscale.png' to pdf Cannot convert 'gui/images/spinbutton.png' to pdf Cannot convert 'gui/images/Hal_Dial.png' to pdf Cannot convert 'gui/images/JogWheel.png' to pdf Cannot convert 'gui/images/SpeedControl.png' to pdf Cannot convert 'gui/images/leds.png' to pdf Cannot convert 'gui/images/progressbar2.png' to pdf Cannot convert 'gui/images/hal_hbar.png' to pdf Cannot convert 'gui/images/vscale.png' to pdf Cannot convert 'gui/images/hal_meter.png' to pdf Cannot convert 'gui/images/gremlin.png' to pdf Cannot convert 'gui/images/combi_dro.png' to pdf Cannot convert 'gui/images/iconview.png' to pdf Cannot convert 'gui/images/gtk-tooledit.png' to pdf Cannot convert 'gui/images/offsetpage.png' to pdf Cannot convert 'gui/images/hal_sourceview.png' to pdf Cannot convert 'gui/images/small-screenshot.png' to pdf Cannot convert 'gui/images/vcp-actions.png' to pdf Cannot convert 'gui/images/whoareyou.png' to pdf Cannot convert 'gui/images/speed.png' to pdf Cannot convert 'gui/images/oword.png' to pdf Cannot convert 'hal/images/remote-start.png' to pdf Cannot convert 'gui/images/vismach.png' to pdf Cannot convert 'drivers/images/5i20-halpins.png' to pdf Cannot convert 'drivers/images/pico-ppmc-math.png' to pdf Cannot convert 'drivers/images/pluto-pinout.png' to pdf Cannot convert 'drivers/images/pluto-step-pinout.png' to pdf Cannot convert 'drivers/images/pluto_step_waveform.png' to pdf Cannot convert 'drivers/images/GMsystem.png' to pdf Cannot convert 'drivers/images/GM_PCIpinout.png' to pdf Cannot convert 'drivers/images/GM_IOpinout.png' to pdf Cannot convert 'drivers/images/GM_AXISpinout.png' to pdf Cannot convert 'drivers/images/GM_AxisInterface.png' to pdf Cannot convert 'drivers/images/GM_RefSignals.png' to pdf Cannot convert 'drivers/images/GM_ENDSWpinout.png' to pdf Cannot convert 'drivers/images/GM_RS485topology.png' to pdf Cannot convert 'examples/images/spindle-math.png' to pdf Cannot convert 'ladder/images/ladder_action_load.png' to pdf Cannot convert 'ladder/images/ladder_action_loadbar.png' to pdf Cannot convert 'ladder/images/ladder_action_out.png' to pdf Cannot convert 'ladder/images/example_link_contact_coil.png' to pdf Cannot convert 'ladder/images/example_link_contact_coil2.png' to pdf Cannot convert 'ladder/images/example_link_contact_coil3.png' to pdf Cannot convert 'ladder/images/Default_Sections_Manager.png' to pdf Cannot convert 'ladder/images/Default_Section_Display.png' to pdf Cannot convert 'ladder/images/Bit_Status.png' to pdf Cannot convert 'ladder/images/watch_window.png' to pdf Cannot convert 'ladder/images/Default_Symbols_names.png' to pdf Cannot convert 'ladder/images/Editor.png' to pdf Cannot convert 'ladder/images/Config.png' to pdf Cannot convert 'ladder/images/ladder_action_load.png' to pdf Cannot convert 'ladder/images/ladder_action_loadbar.png' to pdf Cannot convert 'ladder/images/AssignCompare-Ladder.png' to pdf Cannot convert 'ladder/images/Assignment_Expression.png' to pdf Cannot convert 'ladder/images/Comparison_Expression.png' to pdf Cannot convert 'ladder/images/Config-io.png' to pdf Cannot convert 'ladder/images/Config-com.png' to pdf Cannot convert 'ladder/images/modbus_register_setting.png' to pdf Cannot convert 'ladder/images/modbus_com_setting.png' to pdf Cannot convert 'ladder/images/stepconf_ladder.png' to pdf Cannot convert 'ladder/images/Section_Display_Grid.png' to pdf Cannot convert 'ladder/images/Editor_NO_Input.png' to pdf Cannot convert 'ladder/images/Section_Display_Build01.png' to pdf Cannot convert 'ladder/images/Section_Display_Build02.png' to pdf Cannot convert 'ladder/images/Section_Display_Build03.png' to pdf Cannot convert 'ladder/images/SaveAs.png' to pdf Cannot convert 'ladder/images/wrapping-counter.png' to pdf Cannot convert 'ladder/images/extra-pulse-reject.png' to pdf Cannot convert 'ladder/images/EStop_Section_Display.png' to pdf Cannot convert 'ladder/images/axis_cl-estop.png' to pdf Cannot convert 'ladder/images/Tmr_Section_Display.png' to pdf Cannot convert 'hal/images/hal_circuit_concept.png' to pdf Cannot convert 'hal/images/remote-start.png' to pdf Cannot convert 'hal/images/HAL_Configuration.png' to pdf Cannot convert 'hal/images/signal-direction.png' to pdf Cannot convert 'hal/images/halmeter-select.png' to pdf Cannot convert 'hal/images/halmeter-1.png' to pdf Cannot convert 'hal/images/halscope-01.png' to pdf Cannot convert 'hal/images/halscope-02.png' to pdf Cannot convert 'hal/images/halscope-03.png' to pdf Cannot convert 'hal/images/halscope-04.png' to pdf Cannot convert 'hal/images/halscope-05.png' to pdf Cannot convert 'hal/images/halscope-06.png' to pdf Cannot convert 'hal/images/halscope-07.png' to pdf Cannot convert 'hal/images/halscope-08.png' to pdf Cannot convert 'hal/images/halscope-09.png' to pdf Cannot convert 'hal/images/halscope-10.png' to pdf Cannot convert 'hal/images/halscope-11.png' to pdf Cannot convert 'hal/images/hal-meter01.png' to pdf Cannot convert 'hal/images/hal-meter02.png' to pdf Cannot convert 'hal/images/sim_pin.png' to pdf Cannot convert 'hal/images/simulate_probe.png' to pdf Cannot convert 'hal/images/hal-histogram.png' to pdf Cannot convert 'hal/images/halshow-1.png' to pdf Cannot convert 'hal/images/halshow-3.png' to pdf Cannot convert 'hal/images/halshow-2.png' to pdf Cannot convert 'hal/images/halshow-4.png' to pdf Cannot convert 'hal/images/stepgen-block-diag.png' to pdf Cannot convert 'hal/images/stepgen-type0.png' to pdf Cannot convert 'hal/images/stepgen-type2-4.png' to pdf Cannot convert 'hal/images/stepgen-type5-10.png' to pdf Cannot convert 'hal/images/stepgen-type11-14.png' to pdf Cannot convert 'hal/images/encoder-block-diag.png' to pdf Cannot convert 'hal/images/pid-block-diag.png' to pdf Cannot convert 'hal/images/velocity-01.png' to pdf Cannot convert 'hal/images/softstart-scope.png' to pdf Cannot convert 'motion/images/bipod.png' to pdf Cannot convert 'motion/images/kinematics-math-01.png' to pdf Cannot convert 'motion/images/kinematics-math-02.png' to pdf Cannot convert 'motion/images/kinematics-math-03.png' to pdf Cannot convert 'motion/images/kinematics-math-04.png' to pdf Cannot convert 'motion/images/kinematics-math-05.png' to pdf Cannot convert 'motion/images/kinematics-math-06.png' to pdf Cannot convert 'motion/images/kinematics-math-07.png' to pdf Cannot convert 'motion/rv-6sl/rv-6sl-001.jpg' to pdf Cannot convert 'motion/rv-6sl/rv-6sl-002.jpg' to pdf Cannot convert 'motion/rv-6sl/rv-6sl-003.jpg' to pdf Cannot convert 'motion/rv-6sl/rv-6sl-004.jpg' to pdf Cannot convert 'motion/rv-6sl/rv-6sl-005.jpg' to pdf Cannot convert 'motion/rv-6sl/rv-6sl-006.jpg' to pdf Cannot convert 'motion/rv-6sl/rv-6sl-007.jpg' to pdf Cannot convert 'motion/rv-6sl/rv-6sl-008.jpg' to pdf Cannot convert 'motion/rv-6sl/rv-6sl-009.jpg' to pdf Cannot convert 'motion/rv-6sl/rv-6sl-010.jpg' to pdf Cannot convert 'motion/rv-6sl/rv-6sl-011.jpg' to pdf Cannot convert 'motion/rv-6sl/rv-6sl-012.jpg' to pdf Cannot convert 'motion/rv-6sl/rv-6sl-013.jpg' to pdf Cannot convert 'motion/rv-6sl/rv-6sl-014.jpg' to pdf Cannot convert 'motion/rv-6sl/rv-6sl-015.jpg' to pdf Cannot convert 'motion/rv-6sl/rv-6sl-016.jpg' to pdf Cannot convert 'motion/rv-6sl/rv-6sl-017.jpg' to pdf Cannot convert 'motion/rv-6sl/rv-6sl-018.jpg' to pdf Cannot convert 'motion/5-axis-figures/equation__1.png' to pdf Cannot convert 'motion/5-axis-figures/Figure-1.png' to pdf Cannot convert 'motion/5-axis-figures/equation__2.png' to pdf Cannot convert 'motion/5-axis-figures/equation__3.png' to pdf Cannot convert 'motion/5-axis-figures/Figure-2.png' to pdf Cannot convert 'motion/5-axis-figures/equation__4.png' to pdf Cannot convert 'motion/5-axis-figures/equation__5.png' to pdf Cannot convert 'motion/5-axis-figures/Figure-3.png' to pdf Cannot convert 'motion/5-axis-figures/Figure-4.png' to pdf Cannot convert 'motion/5-axis-figures/equation__6.png' to pdf Cannot convert 'motion/5-axis-figures/equation__7.png' to pdf Cannot convert 'motion/5-axis-figures/equation__8.png' to pdf Cannot convert 'motion/5-axis-figures/equation__9.png' to pdf Cannot convert 'motion/5-axis-figures/equation__10.png' to pdf Cannot convert 'motion/5-axis-figures/equation__11.png' to pdf Cannot convert 'motion/5-axis-figures/equation__12.png' to pdf Cannot convert 'motion/5-axis-figures/equation__13.png' to pdf Cannot convert 'motion/5-axis-figures/equation__14.png' to pdf Cannot convert 'motion/5-axis-figures/equation__15.png' to pdf Cannot convert 'motion/5-axis-figures/equation__16.png' to pdf Cannot convert 'motion/5-axis-figures/equation__17.png' to pdf Cannot convert 'motion/5-axis-figures/Figure-5.png' to pdf Cannot convert 'motion/5-axis-figures/Figure-6.png' to pdf Cannot convert 'motion/5-axis-figures/equation__18.png' to pdf Cannot convert 'motion/5-axis-figures/equation__19.png' to pdf Cannot convert 'motion/5-axis-figures/equation__20.png' to pdf Cannot convert 'motion/5-axis-figures/equation__21.png' to pdf Cannot convert 'motion/5-axis-figures/equation__22.png' to pdf Cannot convert 'motion/5-axis-figures/equation__23.png' to pdf Cannot convert 'motion/5-axis-figures/equation__24.png' to pdf Cannot convert 'motion/5-axis-figures/equation__25.png' to pdf Cannot convert 'motion/5-axis-figures/equation__26.png' to pdf Cannot convert 'motion/5-axis-figures/equation__27.png' to pdf Cannot convert 'motion/5-axis-figures/Figure-7.png' to pdf Cannot convert 'motion/5-axis-figures/Figure-8.png' to pdf Cannot convert 'motion/5-axis-figures/equation__28.png' to pdf Cannot convert 'motion/5-axis-figures/equation__29.png' to pdf Cannot convert 'motion/5-axis-figures/equation__30.png' to pdf Cannot convert 'motion/5-axis-figures/equation__31.png' to pdf Cannot convert 'motion/5-axis-figures/equation__32.png' to pdf Cannot convert 'motion/5-axis-figures/equation__33.png' to pdf Cannot convert 'motion/5-axis-figures/equation__34.png' to pdf Cannot convert 'motion/5-axis-figures/equation__35.png' to pdf Cannot convert 'motion/5-axis-figures/equation__36.png' to pdf Cannot convert 'motion/5-axis-figures/equation__37.png' to pdf Cannot convert 'motion/5-axis-figures/equation__38.png' to pdf Cannot convert 'motion/5-axis-figures/Figure-9.png' to pdf Cannot convert 'motion/5-axis-figures/Figure-10.png' to pdf Cannot convert 'motion/5-axis-figures/Figure-11.png' to pdf Build Master_Documentation.pdf built-in module pdftex registered no support found for ifthen no support found for ifxetex no support found for fontspec no support found for xltxtra no support found for fontenc no support found for inputenc no support found for fancybox built-in module makeidx registered no support found for emc2 building additional files... checking if compiling is necessary... the output file doesn't exist pdflatex -interaction=batchmode Master_Documentation.tex pdflatex failed A possible reason for transformation failure is invalid DocBook (as reported by xmllint) Erroa2x: ERROR: "dblatex" -t pdf -p "/etc/asciidoc/dblatex/asciidoc-dblatex.xsl" -s "/etc/asciidoc/dblatex/asciidoc-dblatex.sty" -P doc.publisher.show=0 -P latex.output.revhistory=0 -s ../docs/src/emc2.sty -P latex.hyperparam=colorlinks,linkcolor=blue,filecolor=blue,urlcolor=blue,citecolor=blue -V "/home/pi/emc/docs/src/Master_Documentation.xml" returned non-zero exit status 1 r: pdflatex compilation failed make[1]: *** [../docs/src/Submakefile:443: ../docs/src/Master_Documentation.pdf] Error 1 make[1]: Leaving directory '/home/pi/emc/src' make: *** [debian/rules:34: build-stamp] Error 2 dpkg-buildpackage: error: debian/rules build subprocess returned exit status 2 debuild: fatal error at line 1182: dpkg-buildpackage -us -uc -ui failed
6 years 3 months ago #174347 by phillc54
That looks more like an error that you would get while building a package rather than one from installing a package.
6 years 2 months ago #177688 by kramerda
Replied by kramerda on topic Raspberry Pi 4 Tutorial
When installing the RT kernel - setting up options - from JTs tutorial
There is a command for
KERNEL=kernel7l.
From the font used in the tutorial (and same reading the Raspberry kernel instructions for the Rpi4) I can't tell if 'kernel seven one or kernel seven 'ell'
Both documents use a type with serifs for the one and the letter 'l'.
6 years 2 months ago #177722 by phillc54
lowercase L
6 years 2 months ago #177760 by kramerda
OK I hope someone can help a novice here. - with my Linuxcnc install per JT.
1. I have the same question at BlueChicago on May 12. I'm at the point where I'm ready to run debian/configure uspace. Using nano debian/configure, I searched and found the two lines to delete (with the python-vte | girl.2-vte-2.91 difference). I removed them, did an exit with save.....
2. the next step debian/configure uspace
leaves me hanging with the following
PACKAGE: command not found
with a few more 'not found' following.
Not smart enough to know if these issues are related. ?????
Time to create page: 0.500 seconds
