Raspberry Pi 4 Tutorial - fatal error
6 years 3 months ago #174058 by moonco
Replied by moonco on topic Raspberry Pi 4 Tutorial
Thank you! I assume if I am using ssh I can scp the file from my host computer to the rpi home folder, then run sudo apt install?
6 years 3 months ago #174060 by phillc54
Replied by phillc54 on topic Raspberry Pi 4 Tutorial
Yes, if it is in your home directory you may need to enter it as:
sudo apt install ./<the_name_of_the_file>.deb
6 years 3 months ago #174185 by moonco
Thank you for your help Phill. Installing those files didn't do the trick. Do you have any other suggestions? The last thing to build correctly is here:
uild the book set list... xsltproc -o doclist.txt --xinclude --xincludestyle doclist.xsl /home/pi/emc/docs/src/Master_Documentation.xml Build the listings... xsltproc -o listings.xml --xinclude --xincludestyle --param current.dir '/home/pi/emc/docs/src' /usr/share/dblatex/xsl/common/mklistings.xsl /home/pi/emc/docs/src/Master_Documentation.xml xsltproc -o Master_Documentation.rtex --xinclude --xincludestyle --param current.dir '/home/pi/emc/docs/src' --param listings.xml '/tmp/tmplkwzHj/listings.xml' /tmp/tmplkwzHj/custom.xsl /home/pi/emc/docs/src/Master_Documentation.xml XSLT stylesheets DocBook - LaTeX 2e (0.3.10) =================================================== Pixel unit not handled (replaced by pt)
Above that I don't see any errors, seams to all compile correctly. When I ran
sudo apt install ./<filename>
after copying the files onto the pi could I have installed them in the wrong place or does the nature of that call put the files where they need to go for the build?
Pixel unit not handled (replaced by pt) Pixel unit not handled (replaced by pt) Pixel unit not handled (replaced by pt) Pixel unit not handled (replaced by pt) Pixel unit not handled (replaced by pt) Pixel unit not handled (replaced by pt) Pixel unit not handled (replaced by pt) Pixel unit not handled (replaced by pt) Pixel unit not handled (replaced by pt) Pixel unit not handled (replaced by pt) Pixel unit not handled (replaced by pt) Pixel unit not handled (replaced by pt) Pixel unit not handled (replaced by pt) Pixel unit not handled (replaced by pt) Cannot convert 'common/images/emc2-intro.png' to pdf Cannot convert 'user/images/whatstep1.png' to pdf Cannot convert 'gui/images/axis.png' to pdf Cannot convert 'gui/images/touchy.png' to pdf Cannot convert 'gui/images/gscreen-mill.png' to pdf Cannot convert 'gui/images/gmoccapy_3_axis.png' to pdf Cannot convert 'gui/images/ngcgui.png' to pdf Cannot convert 'gui/images/axis-pyvcp.png' to pdf Cannot convert 'gui/images/axis-gladevcp.png' to pdf Cannot convert 'user/images/naive-cam.png' to pdf inkscape -z -D --export-pdf=fig0.pdf /home/pi/emc/docs/src/user/images/mill-diagram_en.svg inkscape -z -D --export-pdf=fig1.pdf /home/pi/emc/docs/src/user/images/lathe-diagram_en.svg Image 'images/configuration-selector.png' not found Cannot convert 'getting-started/images/configuration-selector.png' to pdf Cannot convert 'config/images/stepconf-start_en.png' to pdf Cannot convert 'config/images/stepconf-base_en.png' to pdf Cannot convert 'config/images/latency-test_en.png' to pdf Cannot convert 'config/images/stepconf-parallel-1_en.png' to pdf Cannot convert 'config/images/stepconf-parallel-2_en.png' to pdf Cannot convert 'config/images/stepconf-axis-x_en.png' to pdf Cannot convert 'config/images/stepconf-x-test_en.png' to pdf Cannot convert 'config/images/stepconf-spindle_en.png' to pdf Cannot convert 'config/images/stepconf-options_en.png' to pdf inkscape -z -D --export-pdf=fig2.pdf /home/pi/emc/docs/src/config/images/switch-nc-series_en.svg inkscape -z -D --export-pdf=fig3.pdf /home/pi/emc/docs/src/config/images/switch-no-parallel_en.svg Cannot convert 'config/images/pncconf-splash.png' to pdf Cannot convert 'config/images/pncconf-basic.png' to pdf Cannot convert 'config/images/pncconf-external.png' to pdf Cannot convert 'config/images/pncconf-gui.png' to pdf Cannot convert 'config/images/pncconf-mesa-config.png' to pdf Cannot convert 'config/images/pncconf-mesa-io2.png' to pdf Cannot convert 'config/images/pncconf-mesa-io3.png' to pdf Cannot convert 'config/images/pncconf-mesa-io4.png' to pdf Cannot convert 'config/images/pncconf-parport.png' to pdf Cannot convert 'config/images/pncconf-axis-drive.png' to pdf Cannot convert 'config/images/pncconf-scale-calc.png' to pdf Cannot convert 'config/images/pncconf-axis-config.png' to pdf Cannot convert 'config/images/pncconf-diagram-lathe.png' to pdf Cannot convert 'config/images/pncconf-spindle-config.png' to pdf Cannot convert 'config/images/pncconf-advanced.png' to pdf Cannot convert 'config/images/pncconf-hal.png' to pdf inkscape -z -D --export-pdf=fig4.pdf /home/pi/emc/docs/src/lathe/images/tool-positions_en.svg inkscape -z -D --export-pdf=fig5.pdf /home/pi/emc/docs/src/lathe/images/tool-pos-1_en.svg inkscape -z -D --export-pdf=fig6.pdf /home/pi/emc/docs/src/lathe/images/tool-pos-2_en.svg inkscape -z -D --export-pdf=fig7.pdf /home/pi/emc/docs/src/lathe/images/tool-pos-3_en.svg inkscape -z -D --export-pdf=fig8.pdf /home/pi/emc/docs/src/lathe/images/tool-pos-4_en.svg inkscape -z -D --export-pdf=fig9.pdf /home/pi/emc/docs/src/lathe/images/tool-pos-5_en.svg inkscape -z -D --export-pdf=fig10.pdf /home/pi/emc/docs/src/lathe/images/tool-pos-6_en.svg inkscape -z -D --export-pdf=fig11.pdf /home/pi/emc/docs/src/lathe/images/tool-pos-7_en.svg inkscape -z -D --export-pdf=fig12.pdf /home/pi/emc/docs/src/lathe/images/tool-pos-8_en.svg inkscape -z -D --export-pdf=fig13.pdf /home/pi/emc/docs/src/lathe/images/control-point_en.svg inkscape -z -D --export-pdf=fig14.pdf /home/pi/emc/docs/src/lathe/images/ramp-entry_en.svg inkscape -z -D --export-pdf=fig15.pdf /home/pi/emc/docs/src/lathe/images/ramp-cut_en.svg inkscape -z -D --export-pdf=fig16.pdf /home/pi/emc/docs/src/lathe/images/radius-1_en.svg inkscape -z -D --export-pdf=fig17.pdf /home/pi/emc/docs/src/lathe/images/radius-2_en.svg inkscape -z -D --export-pdf=fig18.pdf /home/pi/emc/docs/src/lathe/images/radius-3_en.svg inkscape -z -D --export-pdf=fig19.pdf /home/pi/emc/docs/src/lathe/images/radius-4_en.svg Cannot convert 'plasma/images/primer_torch-head.png' to pdf Cannot convert 'plasma/images/primer_cut-angularity.png' to pdf Cannot convert 'plasma/images/primer_volts-height.png' to pdf Cannot convert 'plasma/images/primer_ohmic-sensing.png' to pdf Cannot convert 'plasma/images/primer_hypersensing.png' to pdf Cannot convert 'plasma/images/primer_thc-delay.png' to pdf Cannot convert 'plasma/images/primer_kerf-cross.png' to pdf Cannot convert 'gui/images/axis.png' to pdf convert /home/pi/emc/docs/src/gui/images/tool_estop.gif fig20.pdf convert-im6.q16: attempt to perform an operation not allowed by the security policy `PDF' @ error/constitute.c/IsCoderAuthorized/408. Unexpected error occured convert /home/pi/emc/docs/src/gui/images/tool_power.gif fig21.pdf convert-im6.q16: attempt to perform an operation not allowed by the security policy `PDF' @ error/constitute.c/IsCoderAuthorized/408. Unexpected error occured convert /home/pi/emc/docs/src/gui/images/tool_open.gif fig22.pdf convert-im6.q16: attempt to perform an operation not allowed by the security policy `PDF' @ error/constitute.c/IsCoderAuthorized/408. Unexpected error occured convert /home/pi/emc/docs/src/gui/images/tool_reload.gif fig23.pdf convert-im6.q16: attempt to perform an operation not allowed by the security policy `PDF' @ error/constitute.c/IsCoderAuthorized/408. Unexpected error occured convert /home/pi/emc/docs/src/gui/images/tool_run.gif fig24.pdf convert-im6.q16: attempt to perform an operation not allowed by the security policy `PDF' @ error/constitute.c/IsCoderAuthorized/408. Unexpected error occured convert /home/pi/emc/docs/src/gui/images/tool_step.gif fig25.pdf convert-im6.q16: attempt to perform an operation not allowed by the security policy `PDF' @ error/constitute.c/IsCoderAuthorized/408. Unexpected error occured convert /home/pi/emc/docs/src/gui/images/tool_pause.gif fig26.pdf convert-im6.q16: attempt to perform an operation not allowed by the security policy `PDF' @ error/constitute.c/IsCoderAuthorized/408. Unexpected error occured convert /home/pi/emc/docs/src/gui/images/tool_stop.gif fig27.pdf convert-im6.q16: attempt to perform an operation not allowed by the security policy `PDF' @ error/constitute.c/IsCoderAuthorized/408. Unexpected error occured convert /home/pi/emc/docs/src/gui/images/tool_blockdelete.gif fig28.pdf convert-im6.q16: attempt to perform an operation not allowed by the security policy `PDF' @ error/constitute.c/IsCoderAuthorized/408. Unexpected error occured convert /home/pi/emc/docs/src/gui/images/tool_optpause.gif fig29.pdf convert-im6.q16: attempt to perform an operation not allowed by the security policy `PDF' @ error/constitute.c/IsCoderAuthorized/408. Unexpected error occured convert /home/pi/emc/docs/src/gui/images/tool_zoomin.gif fig30.pdf convert-im6.q16: attempt to perform an operation not allowed by the security policy `PDF' @ error/constitute.c/IsCoderAuthorized/408. Unexpected error occured convert /home/pi/emc/docs/src/gui/images/tool_zoomout.gif fig31.pdf convert-im6.q16: attempt to perform an operation not allowed by the security policy `PDF' @ error/constitute.c/IsCoderAuthorized/408. Unexpected error occured convert /home/pi/emc/docs/src/gui/images/tool_axis_z.gif fig32.pdf convert-im6.q16: attempt to perform an operation not allowed by the security policy `PDF' @ error/constitute.c/IsCoderAuthorized/408. Unexpected error occured convert /home/pi/emc/docs/src/gui/images/tool_axis_z2.gif fig33.pdf convert-im6.q16: attempt to perform an operation not allowed by the security policy `PDF' @ error/constitute.c/IsCoderAuthorized/408. Unexpected error occured convert /home/pi/emc/docs/src/gui/images/tool_axis_x.gif fig34.pdf convert-im6.q16: attempt to perform an operation not allowed by the security policy `PDF' @ error/constitute.c/IsCoderAuthorized/408. Unexpected error occured convert /home/pi/emc/docs/src/gui/images/tool_axis_y.gif fig35.pdf convert-im6.q16: attempt to perform an operation not allowed by the security policy `PDF' @ error/constitute.c/IsCoderAuthorized/408. Unexpected error occured convert /home/pi/emc/docs/src/gui/images/tool_axis_p.gif fig36.pdf convert-im6.q16: attempt to perform an operation not allowed by the security policy `PDF' @ error/constitute.c/IsCoderAuthorized/408. Unexpected error occured convert /home/pi/emc/docs/src/gui/images/tool_rotate.gif fig37.pdf convert-im6.q16: attempt to perform an operation not allowed by the security policy `PDF' @ error/constitute.c/IsCoderAuthorized/408. Unexpected error occured convert /home/pi/emc/docs/src/gui/images/tool_clear.gif fig38.pdf convert-im6.q16: attempt to perform an operation not allowed by the security policy `PDF' @ error/constitute.c/IsCoderAuthorized/408. Unexpected error occured Cannot convert 'gui/images/axis-homed.png' to pdf Cannot convert 'gui/images/axis-limit.png' to pdf Cannot convert 'gui/images/axis-machineorigin.png' to pdf Cannot convert 'gui/images/axis-outofrange.png' to pdf Cannot convert 'gui/images/axis-currentandselected.png' to pdf Cannot convert 'gui/images/touchoff.png' to pdf Cannot convert 'gui/images/axis-mdi.png' to pdf Cannot convert 'gui/images/axis-emc-status.png' to pdf Cannot convert 'gui/images/manual-tool-change.png' to pdf Cannot convert 'gui/images/axis-lathe-tool.png' to pdf Cannot convert 'gui/images/axis-foam.png' to pdf Cannot convert 'gui/images/holes.png' to pdf Cannot convert 'gui/images/gmoccapy_5_axis.png' to pdf Cannot convert 'gui/images/gmoccapy_3_axis.png' to pdf Cannot convert 'gui/images/gmoccapy_ntb_preview_maximized_2.png' to pdf Cannot convert 'gui/images/gmoccapy_ntb_preview.png' to pdf Cannot convert 'gui/images/gmoccapy_with_left_box_in_edit_mode.png' to pdf Cannot convert 'gui/images/gmoccapy_with_right_panel_in_MDI_mode.png' to pdf Cannot convert 'gui/images/gmoccapy_mdi_hidden_keyboard.png' to pdf Cannot convert 'gui/images/gmoccapy_getting_macro_info.png' to pdf Cannot convert 'gui/images/gmoccapy_0_9_7_sim_hardware_button.png' to pdf Cannot convert 'gui/images/manual_toolchange.png' to pdf Cannot convert 'gui/images/gmoccapy_0_9_7_tool_info.png' to pdf Cannot convert 'gui/images/sketch_auto_tool_measurement.png' to pdf Cannot convert 'gui/images/gmoccapy_settings_button.png' to pdf Cannot convert 'gui/images/gmoccapy_settings_appearance.png' to pdf Cannot convert 'gui/images/gmoccapy_file_selection_dialog_with_keyboard.png' to pdf Cannot convert 'gui/images/gmoccapy_settings_hardware.png' to pdf Cannot convert 'gui/images/gmoccapy_settings_advanced.png' to pdf Cannot convert 'gui/images/gmoccapy_lathe.png' to pdf Cannot convert 'gui/images/gmoccapy_back_tool_lathe.png' to pdf Cannot convert 'gui/images/gmoccapy_plasma.png' to pdf Cannot convert 'gui/images/strange_numbers.png' to pdf Cannot convert 'gui/images/ngcgui.png' to pdf Image 'gui/images/tool_estop.gif' already converted as fig20.pdf Image 'gui/images/tool_power.gif' already converted as fig21.pdf Image 'gui/images/tool_run.gif' already converted as fig24.pdf Cannot convert 'gui/images/ngcgui-db25-1.png' to pdf Cannot convert 'gui/images/ngcgui-db25-2.png' to pdf Cannot convert 'gui/images/ngcgui-db25-3.png' to pdf Cannot convert 'gui/images/touchy.png' to pdf Cannot convert 'gui/images/gscreen-mill.png' to pdf Cannot convert 'gui/images/silverdragon.png' to pdf Cannot convert 'gui/images/spartan.png' to pdf Cannot convert 'gui/images/gaxis.png' to pdf Cannot convert 'gui/images/industrial.png' to pdf Cannot convert 'gui/images/tester.png' to pdf Cannot convert 'gui/images/tester_editor.png' to pdf Cannot convert 'gui/images/tkemc.png' to pdf Cannot convert 'gui/images/tkemc-interp.png' to pdf Cannot convert 'gui/images/tkemc-override-limits.png' to pdf Cannot convert 'gui/images/tkemc-mdi.png' to pdf Cannot convert 'plasma/images/plasmac_configurator_home_new.png' to pdf Cannot convert 'plasma/images/plasmac_configurator_new.png' to pdf Cannot convert 'plasma/images/plasmac_config.png' to pdf Cannot convert 'plasma/images/plasmac_run.png' to pdf Cannot convert 'plasma/images/plasmac_monitor.png' to pdf Cannot convert 'plasma/images/plasmac_buttons_a.png' to pdf Cannot convert 'plasma/images/plasmac_buttons_g.png' to pdf Cannot convert 'plasma/images/plasmac_control_a.png' to pdf Cannot convert 'plasma/images/plasmac_control_g.png' to pdf Cannot convert 'plasma/images/plasmac_stats.png' to pdf Cannot convert 'plasma/images/plasmac_extras.png' to pdf Cannot convert 'plasma/images/plasmac_configurator_home_used.png' to pdf Cannot convert 'plasma/images/plasmac_configurator_upgrade.png' to pdf Cannot convert 'plasma/images/plasmac_configurator_home_used.png' to pdf Cannot convert 'plasma/images/plasmac_configurator_reconfigure.png' to pdf Cannot convert 'plasma/images/plasmac_material_main.png' to pdf Cannot convert 'plasma/images/plasmac_material_dialogs.png' to pdf Cannot convert 'plasma/images/plasmac_rs485_pmx.png' to pdf Cannot convert 'plasma/images/plasmac_rs485_sunnix.png' to pdf Cannot convert 'plasma/images/plasmac_rs485_dtech.png' to pdf Cannot convert 'plasma/images/plasmac_reed_arc_ok.png' to pdf Cannot convert 'gcode/images/offsets.png' to pdf Cannot convert 'gcode/images/polar01.png' to pdf Cannot convert 'gcode/images/polar02.png' to pdf inkscape -z -D --export-pdf=fig39.pdf /home/pi/emc/docs/src/gcode/images/g2_en.svg inkscape -z -D --export-pdf=fig40.pdf /home/pi/emc/docs/src/gcode/images/g2-3_en.svg Cannot convert 'gcode/images/nurbs01.png' to pdf inkscape -z -D --export-pdf=fig41.pdf /home/pi/emc/docs/src/gcode/images/g76-threads_en.svg Cannot convert 'gcode/images/g76-01.png' to pdf inkscape -z -D --export-pdf=fig42.pdf /home/pi/emc/docs/src/gcode/images/eight-holes_en.svg inkscape -z -D --export-pdf=fig43.pdf /home/pi/emc/docs/src/gcode/images/twelve-holes_en.svg inkscape -z -D --export-pdf=fig44.pdf /home/pi/emc/docs/src/gcode/images/g81mult_en.svg inkscape -z -D --export-pdf=fig45.pdf /home/pi/emc/docs/src/gcode/images/g81ex1_en.svg inkscape -z -D --export-pdf=fig46.pdf /home/pi/emc/docs/src/gcode/images/g81ex2_en.svg inkscape -z -D --export-pdf=fig47.pdf /home/pi/emc/docs/src/gcode/images/g81_en.svg inkscape -z -D --export-pdf=fig48.pdf /home/pi/emc/docs/src/gcode/images/g81a_en.svg Cannot convert 'gui/images/image-to-gcode.png' to pdf Cannot convert 'gui/images/i2g-roughing.png' to pdf Cannot convert 'gcode/images/ToolTable-TouchOff.png' to pdf inkscape -z -D --export-pdf=fig49.pdf /home/pi/emc/docs/src/gcode/images/comp-path_en.svg inkscape -z -D --export-pdf=fig50.pdf /home/pi/emc/docs/src/gcode/images/comp02_en.svg Cannot convert 'gcode/images/outside-comp.png' to pdf Cannot convert 'gcode/images/inside-comp.png' to pdf Cannot convert 'gui/images/tooledit.png' to pdf Cannot convert 'gui/images/tooledit-sort.png' to pdf Cannot convert 'gui/images/tooledit-columns.png' to pdf Cannot convert 'config/images/servo-feedback.png' to pdf Cannot convert 'config/images/pid-feedback.png' to pdf Cannot convert 'config/images/latency-test_en.png' to pdf Cannot convert 'config/images/latency-plot.png' to pdf Cannot convert 'config/images/latency-histogram.png' to pdf Cannot convert 'config/images/step-calc-inch-math.png' to pdf Cannot convert 'config/images/step-calc-mm-math.png' to pdf Cannot convert 'config/images/encoder-counts-math.png' to pdf Cannot convert 'config/images/p-term.png' to pdf Cannot convert 'config/images/i-term.png' to pdf Cannot convert 'config/images/i-term.png' to pdf Cannot convert 'config/images/p-term.png' to pdf Cannot convert 'config/images/i-term.png' to pdf Cannot convert 'config/images/ff2.png' to pdf Cannot convert 'config/images/output-offset.png' to pdf Cannot convert 'config/images/scale-math.png' to pdf Cannot convert 'config/images/calibration-1.png' to pdf Cannot convert 'config/images/calibration-2.png' to pdf Cannot convert 'config/images/calibration-3.png' to pdf Cannot convert 'config/images/encoder-scale.png' to pdf Cannot convert 'config/images/stepper-scale.png' to pdf Cannot convert 'config/images/encoder-scale.png' to pdf Cannot convert 'config/images/HomeAxisTravel_V2.png' to pdf Cannot convert 'config/images/HomeAxisTravel_V3.png' to pdf Cannot convert 'config/images/emc2-motion-homing-diag.png' to pdf Cannot convert 'remap/images/debug_embedded_python.png' to pdf Cannot convert 'gui/images/pyvcp_group.png' to pdf Cannot convert 'gui/images/pyvcp_mypanel.png' to pdf Cannot convert 'gui/images/pyvcp_axis_lathe.png' to pdf Cannot convert 'gui/images/pyvcp_label.png' to pdf Cannot convert 'gui/images/pyvcp_led.png' to pdf Cannot convert 'gui/images/pyvcp_rectled.png' to pdf Cannot convert 'gui/images/pyvcp_button.png' to pdf Cannot convert 'gui/images/pyvcp_checkbutton.png' to pdf Cannot convert 'gui/images/pyvcp_radiobutton.png' to pdf Cannot convert 'gui/images/pyvcp_number.png' to pdf Cannot convert 'gui/images/pyvcp_s32.png' to pdf Cannot convert 'gui/images/pyvcp_bar.png' to pdf Cannot convert 'gui/images/pyvcp_meter.png' to pdf Cannot convert 'gui/images/pyvcp_spinbox.png' to pdf Cannot convert 'gui/images/pyvcp_scale.png' to pdf Cannot convert 'gui/images/pyvcp_dial.png' to pdf Cannot convert 'gui/images/pyvcp_jogwheel.png' to pdf Cannot convert 'gui/images/pyvcp_image01.png' to pdf Cannot convert 'gui/images/pyvcp_image02.png' to pdf Cannot convert 'gui/images/pyvcp_image_u32_01.png' to pdf Cannot convert 'gui/images/pyvcp_image01.png' to pdf Cannot convert 'gui/images/pyvcp_image02.png' to pdf Cannot convert 'gui/images/pyvcp_borders.png' to pdf Cannot convert 'gui/images/pyvcp_hbox.png' to pdf Cannot convert 'gui/images/pyvcp_vbox.png' to pdf Cannot convert 'gui/images/pyvcp_labelframe.png' to pdf Cannot convert 'gui/images/pyvcp_table.png' to pdf Cannot convert 'gui/images/pyvcp_tabs1.png' to pdf Cannot convert 'gui/images/pyvcp_tabs2.png' to pdf Cannot convert 'gui/images/pyvcp_tabs3.png' to pdf Cannot convert 'gui/images/xyz_ACO.png' to pdf Cannot convert 'gui/images/xyz_buttons.png' to pdf Cannot convert 'gui/images/ptest.png' to pdf Cannot convert 'gui/images/ptest-final.png' to pdf Cannot convert 'gui/images/gs2_panel.png' to pdf Cannot convert 'gui/images/pyvcp-rth.png' to pdf Cannot convert 'gui/images/example-panel-small.png' to pdf Cannot convert 'gui/images/example-tabbed-small.png' to pdf Cannot convert 'gui/images/touchy-tab-33.png' to pdf Cannot convert 'gui/images/glade-manual-small.png' to pdf Cannot convert 'gui/images/hal-pin-change-66.png' to pdf Cannot convert 'gui/images/checkbutton.png' to pdf Cannot convert 'gui/images/radiobutton.png' to pdf Cannot convert 'gui/images/button.png' to pdf Cannot convert 'gui/images/hscale.png' to pdf Cannot convert 'gui/images/spinbutton.png' to pdf Cannot convert 'gui/images/Hal_Dial.png' to pdf Cannot convert 'gui/images/JogWheel.png' to pdf Cannot convert 'gui/images/SpeedControl.png' to pdf Cannot convert 'gui/images/leds.png' to pdf Cannot convert 'gui/images/progressbar2.png' to pdf Cannot convert 'gui/images/hal_hbar.png' to pdf Cannot convert 'gui/images/vscale.png' to pdf Cannot convert 'gui/images/hal_meter.png' to pdf Cannot convert 'gui/images/gremlin.png' to pdf Cannot convert 'gui/images/combi_dro.png' to pdf Cannot convert 'gui/images/iconview.png' to pdf Cannot convert 'gui/images/gtk-tooledit.png' to pdf Cannot convert 'gui/images/offsetpage.png' to pdf Cannot convert 'gui/images/hal_sourceview.png' to pdf Cannot convert 'gui/images/small-screenshot.png' to pdf Cannot convert 'gui/images/vcp-actions.png' to pdf Cannot convert 'gui/images/whoareyou.png' to pdf Cannot convert 'gui/images/speed.png' to pdf Cannot convert 'gui/images/oword.png' to pdf Cannot convert 'hal/images/remote-start.png' to pdf Cannot convert 'gui/images/vismach.png' to pdf Cannot convert 'drivers/images/5i20-halpins.png' to pdf Cannot convert 'drivers/images/pico-ppmc-math.png' to pdf Cannot convert 'drivers/images/pluto-pinout.png' to pdf Cannot convert 'drivers/images/pluto-step-pinout.png' to pdf Cannot convert 'drivers/images/pluto_step_waveform.png' to pdf Cannot convert 'drivers/images/GMsystem.png' to pdf Cannot convert 'drivers/images/GM_PCIpinout.png' to pdf Cannot convert 'drivers/images/GM_IOpinout.png' to pdf Cannot convert 'drivers/images/GM_AXISpinout.png' to pdf Cannot convert 'drivers/images/GM_AxisInterface.png' to pdf Cannot convert 'drivers/images/GM_RefSignals.png' to pdf Cannot convert 'drivers/images/GM_ENDSWpinout.png' to pdf Cannot convert 'drivers/images/GM_RS485topology.png' to pdf Cannot convert 'examples/images/spindle-math.png' to pdf Cannot convert 'ladder/images/ladder_action_load.png' to pdf Cannot convert 'ladder/images/ladder_action_loadbar.png' to pdf Cannot convert 'ladder/images/ladder_action_out.png' to pdf Cannot convert 'ladder/images/example_link_contact_coil.png' to pdf Cannot convert 'ladder/images/example_link_contact_coil2.png' to pdf Cannot convert 'ladder/images/example_link_contact_coil3.png' to pdf Cannot convert 'ladder/images/Default_Sections_Manager.png' to pdf Cannot convert 'ladder/images/Default_Section_Display.png' to pdf Cannot convert 'ladder/images/Bit_Status.png' to pdf Cannot convert 'ladder/images/watch_window.png' to pdf Cannot convert 'ladder/images/Default_Symbols_names.png' to pdf Cannot convert 'ladder/images/Editor.png' to pdf Cannot convert 'ladder/images/Config.png' to pdf Cannot convert 'ladder/images/ladder_action_load.png' to pdf Cannot convert 'ladder/images/ladder_action_loadbar.png' to pdf Cannot convert 'ladder/images/AssignCompare-Ladder.png' to pdf Cannot convert 'ladder/images/Assignment_Expression.png' to pdf Cannot convert 'ladder/images/Comparison_Expression.png' to pdf Cannot convert 'ladder/images/Config-io.png' to pdf Cannot convert 'ladder/images/Config-com.png' to pdf Cannot convert 'ladder/images/modbus_register_setting.png' to pdf Cannot convert 'ladder/images/modbus_com_setting.png' to pdf Cannot convert 'ladder/images/stepconf_ladder.png' to pdf Cannot convert 'ladder/images/Section_Display_Grid.png' to pdf Cannot convert 'ladder/images/Editor_NO_Input.png' to pdf Cannot convert 'ladder/images/Section_Display_Build01.png' to pdf Cannot convert 'ladder/images/Section_Display_Build02.png' to pdf Cannot convert 'ladder/images/Section_Display_Build03.png' to pdf Cannot convert 'ladder/images/SaveAs.png' to pdf Cannot convert 'ladder/images/wrapping-counter.png' to pdf Cannot convert 'ladder/images/extra-pulse-reject.png' to pdf Cannot convert 'ladder/images/EStop_Section_Display.png' to pdf Cannot convert 'ladder/images/axis_cl-estop.png' to pdf Cannot convert 'ladder/images/Tmr_Section_Display.png' to pdf Cannot convert 'hal/images/hal_circuit_concept.png' to pdf Cannot convert 'hal/images/remote-start.png' to pdf Cannot convert 'hal/images/HAL_Configuration.png' to pdf Cannot convert 'hal/images/signal-direction.png' to pdf Cannot convert 'hal/images/halmeter-select.png' to pdf Cannot convert 'hal/images/halmeter-1.png' to pdf Cannot convert 'hal/images/halscope-01.png' to pdf Cannot convert 'hal/images/halscope-02.png' to pdf Cannot convert 'hal/images/halscope-03.png' to pdf Cannot convert 'hal/images/halscope-04.png' to pdf Cannot convert 'hal/images/halscope-05.png' to pdf Cannot convert 'hal/images/halscope-06.png' to pdf Cannot convert 'hal/images/halscope-07.png' to pdf Cannot convert 'hal/images/halscope-08.png' to pdf Cannot convert 'hal/images/halscope-09.png' to pdf Cannot convert 'hal/images/halscope-10.png' to pdf Cannot convert 'hal/images/halscope-11.png' to pdf Cannot convert 'hal/images/hal-meter01.png' to pdf Cannot convert 'hal/images/hal-meter02.png' to pdf Cannot convert 'hal/images/sim_pin.png' to pdf Cannot convert 'hal/images/simulate_probe.png' to pdf Cannot convert 'hal/images/hal-histogram.png' to pdf Cannot convert 'hal/images/halshow-1.png' to pdf Cannot convert 'hal/images/halshow-3.png' to pdf Cannot convert 'hal/images/halshow-2.png' to pdf Cannot convert 'hal/images/halshow-4.png' to pdf Cannot convert 'hal/images/stepgen-block-diag.png' to pdf Cannot convert 'hal/images/stepgen-type0.png' to pdf Cannot convert 'hal/images/stepgen-type2-4.png' to pdf Cannot convert 'hal/images/stepgen-type5-10.png' to pdf Cannot convert 'hal/images/stepgen-type11-14.png' to pdf Cannot convert 'hal/images/encoder-block-diag.png' to pdf Cannot convert 'hal/images/pid-block-diag.png' to pdf Cannot convert 'hal/images/velocity-01.png' to pdf Cannot convert 'hal/images/softstart-scope.png' to pdf Cannot convert 'motion/images/bipod.png' to pdf Cannot convert 'motion/images/kinematics-math-01.png' to pdf Cannot convert 'motion/images/kinematics-math-02.png' to pdf Cannot convert 'motion/images/kinematics-math-03.png' to pdf Cannot convert 'motion/images/kinematics-math-04.png' to pdf Cannot convert 'motion/images/kinematics-math-05.png' to pdf Cannot convert 'motion/images/kinematics-math-06.png' to pdf Cannot convert 'motion/images/kinematics-math-07.png' to pdf Cannot convert 'motion/rv-6sl/rv-6sl-001.jpg' to pdf Cannot convert 'motion/rv-6sl/rv-6sl-002.jpg' to pdf Cannot convert 'motion/rv-6sl/rv-6sl-003.jpg' to pdf Cannot convert 'motion/rv-6sl/rv-6sl-004.jpg' to pdf Cannot convert 'motion/rv-6sl/rv-6sl-005.jpg' to pdf Cannot convert 'motion/rv-6sl/rv-6sl-006.jpg' to pdf Cannot convert 'motion/rv-6sl/rv-6sl-007.jpg' to pdf Cannot convert 'motion/rv-6sl/rv-6sl-008.jpg' to pdf Cannot convert 'motion/rv-6sl/rv-6sl-009.jpg' to pdf Cannot convert 'motion/rv-6sl/rv-6sl-010.jpg' to pdf Cannot convert 'motion/rv-6sl/rv-6sl-011.jpg' to pdf Cannot convert 'motion/rv-6sl/rv-6sl-012.jpg' to pdf Cannot convert 'motion/rv-6sl/rv-6sl-013.jpg' to pdf Cannot convert 'motion/rv-6sl/rv-6sl-014.jpg' to pdf Cannot convert 'motion/rv-6sl/rv-6sl-015.jpg' to pdf Cannot convert 'motion/rv-6sl/rv-6sl-016.jpg' to pdf Cannot convert 'motion/rv-6sl/rv-6sl-017.jpg' to pdf Cannot convert 'motion/rv-6sl/rv-6sl-018.jpg' to pdf Cannot convert 'motion/5-axis-figures/equation__1.png' to pdf Cannot convert 'motion/5-axis-figures/Figure-1.png' to pdf Cannot convert 'motion/5-axis-figures/equation__2.png' to pdf Cannot convert 'motion/5-axis-figures/equation__3.png' to pdf Cannot convert 'motion/5-axis-figures/Figure-2.png' to pdf Cannot convert 'motion/5-axis-figures/equation__4.png' to pdf Cannot convert 'motion/5-axis-figures/equation__5.png' to pdf Cannot convert 'motion/5-axis-figures/Figure-3.png' to pdf Cannot convert 'motion/5-axis-figures/Figure-4.png' to pdf Cannot convert 'motion/5-axis-figures/equation__6.png' to pdf Cannot convert 'motion/5-axis-figures/equation__7.png' to pdf Cannot convert 'motion/5-axis-figures/equation__8.png' to pdf Cannot convert 'motion/5-axis-figures/equation__9.png' to pdf Cannot convert 'motion/5-axis-figures/equation__10.png' to pdf Cannot convert 'motion/5-axis-figures/equation__11.png' to pdf Cannot convert 'motion/5-axis-figures/equation__12.png' to pdf Cannot convert 'motion/5-axis-figures/equation__13.png' to pdf Cannot convert 'motion/5-axis-figures/equation__14.png' to pdf Cannot convert 'motion/5-axis-figures/equation__15.png' to pdf Cannot convert 'motion/5-axis-figures/equation__16.png' to pdf Cannot convert 'motion/5-axis-figures/equation__17.png' to pdf Cannot convert 'motion/5-axis-figures/Figure-5.png' to pdf Cannot convert 'motion/5-axis-figures/Figure-6.png' to pdf Cannot convert 'motion/5-axis-figures/equation__18.png' to pdf Cannot convert 'motion/5-axis-figures/equation__19.png' to pdf Cannot convert 'motion/5-axis-figures/equation__20.png' to pdf Cannot convert 'motion/5-axis-figures/equation__21.png' to pdf Cannot convert 'motion/5-axis-figures/equation__22.png' to pdf Cannot convert 'motion/5-axis-figures/equation__23.png' to pdf Cannot convert 'motion/5-axis-figures/equation__24.png' to pdf Cannot convert 'motion/5-axis-figures/equation__25.png' to pdf Cannot convert 'motion/5-axis-figures/equation__26.png' to pdf Cannot convert 'motion/5-axis-figures/equation__27.png' to pdf Cannot convert 'motion/5-axis-figures/Figure-7.png' to pdf Cannot convert 'motion/5-axis-figures/Figure-8.png' to pdf Cannot convert 'motion/5-axis-figures/equation__28.png' to pdf Cannot convert 'motion/5-axis-figures/equation__29.png' to pdf Cannot convert 'motion/5-axis-figures/equation__30.png' to pdf Cannot convert 'motion/5-axis-figures/equation__31.png' to pdf Cannot convert 'motion/5-axis-figures/equation__32.png' to pdf Cannot convert 'motion/5-axis-figures/equation__33.png' to pdf Cannot convert 'motion/5-axis-figures/equation__34.png' to pdf Cannot convert 'motion/5-axis-figures/equation__35.png' to pdf Cannot convert 'motion/5-axis-figures/equation__36.png' to pdf Cannot convert 'motion/5-axis-figures/equation__37.png' to pdf Cannot convert 'motion/5-axis-figures/equation__38.png' to pdf Cannot convert 'motion/5-axis-figures/Figure-9.png' to pdf Cannot convert 'motion/5-axis-figures/Figure-10.png' to pdf Cannot convert 'motion/5-axis-figures/Figure-11.png' to pdf Build Master_Documentation.pdf built-in module pdftex registered no support found for ifthen no support found for ifxetex no support found for fontspec no support found for xltxtra no support found for fontenc no support found for inputenc no support found for fancybox built-in module makeidx registered no support found for emc2 building additional files... checking if compiling is necessary... the output file doesn't exist pdflatex -interaction=batchmode Master_Documentation.tex pdflatex failed A possible reason for transformation failure is invalid DocBook (as reported by xmllint) Erroa2x: ERROR: "dblatex" -t pdf -p "/etc/asciidoc/dblatex/asciidoc-dblatex.xsl" -s "/etc/asciidoc/dblatex/asciidoc-dblatex.sty" -P doc.publisher.show=0 -P latex.output.revhistory=0 -s ../docs/src/emc2.sty -P latex.hyperparam=colorlinks,linkcolor=blue,filecolor=blue,urlcolor=blue,citecolor=blue -V "/home/pi/emc/docs/src/Master_Documentation.xml" returned non-zero exit status 1 r: pdflatex compilation failed make[1]: *** [../docs/src/Submakefile:443: ../docs/src/Master_Documentation.pdf] Error 1 make[1]: Leaving directory '/home/pi/emc/src' make: *** [debian/rules:34: build-stamp] Error 2 dpkg-buildpackage: error: debian/rules build subprocess returned exit status 2 debuild: fatal error at line 1182: dpkg-buildpackage -us -uc -ui failed
6 years 3 months ago - 6 years 3 months ago #174191 by phillc54
What error did you get?
I am not following, did you compile on one machine then copy the deb fiiles to another?
EDIT: I see that neither 2.8 or master packages are building correctly on the Buildbot as well.
If you want to compile locally why not just do a run in place install and forget about using packages. If you want to use packages then use the prebuilt ones I linked to earlier.
Last edit: 6 years 3 months ago by phillc54.
6 years 3 months ago #174252 by tommylight
6 years 3 months ago #174325 by moonco
I was able to get LinuxCNC running. I am not sure if there are any issues yet as the same error occurred.
I just ignored the error and continued this time.
This time i followed the tutorial but replaced the next lines in the tutorial with the files from the buildbot as follows.
sudo dpkg -i linuxcnc-uspace_2.8.0_pre1.5983.g19a686b67_armhf.deb sudo dpkg -i llinuxcnc-doc-en_2.8.0_pre1.5983.g19a686b67_all.deb
I was able to open Linuxcnc after doing this.
Time to create page: 0.150 seconds
