Raspberry Pi 4 Tutorial - fatal error
6 years 1 month ago #183533 by phillc54
There is a mention of cpuinfo here:
github.com/LinuxCNC/linuxcnc/pull/941
The following user(s) said Thank You: wiremonkey
6 years 1 month ago #183536 by wiremonkey
Thanks phillc54. I'm just learning this stuff. So a request was submitted to pull the changed code into the main code. When do changes make it out to the .iso file on linuxcnc.org/iso/ ? I see the pi4 iso's up there are from 9/14. Does these pull request merges happen once a week or on a schedule?
6 years 1 month ago - 6 years 1 month ago #183537 by phillc54
There is no schedule but you can follow this trail:
It was merged here:
if you do run in place then you can pull and build
github.com/LinuxCNC/linuxcnc/commits/2.8
It is still being built for buster i386 and amd64 but the armhf package is built:
see bottom right
Edit: it has finished...
buildbot.linuxcnc.org/buildbot/grid
It is available for armhf here:
buildbot.linuxcnc.org/dists/buster/2.8-r...inary-armhf/?C=M;O=D
so you could update now
Edit: you can if you have Buildbot set as your repositery
Last edit: 6 years 1 month ago by phillc54.
6 years 1 month ago - 6 years 1 month ago #183539 by wiremonkey
Oooooola! My very own buildbot!
I don't know what that is, but I'm on it...
Er, well dang, it's a bit over my head to compile the .iso myself. I tried to find a walk through but can't. It's OK, I can wait a bit.
Last edit: 6 years 1 month ago by wiremonkey.
6 years 1 month ago #183542 by phillc54
6 years 1 month ago #183602 by wiremonkey
This is very helpful! Thanks!
Time to create page: 0.288 seconds
