Raspberry Pi 4 Tutorial - fatal error
6 years 2 weeks ago - 6 years 1 week ago #186282 by gbeck
Hello David
I've run into the very same issue today.
Raspberry Pi 4B boots into the graphical UI but mouse and keyboard will not work.
I am using the latest image from here: www.linuxcnc.org/iso/linuxcnc-2.8.0-pi4.zip .
Many thanks for any advice, Gero
Update: it seems to be related only to 8GB. I tried it with a 4GB RPI and it works well. I think its a kernel issue in this built.
Last edit: 6 years 1 week ago by gbeck.
6 years 2 weeks ago #186310 by oceax
Replied by oceax on topic Raspberry Pi 4 Tutorial
Same here, gui but no usb mouse and keyboard
6 years 1 week ago - 6 years 1 week ago #186648 by lumberjack_jeff
Thanks for the tutorial. I followed the tutorial in headless mode (ssh); ran into a problem. After building the preempt rt kernel, DEPMOD reported a different version (I didn't write it down). After installation and subsequent edit of the /boot/cmdline.txt to append the text, I did reboot, but the device is no longer accessible to the network - not via wifi and not via ethernet. Suggestions?
on edit:
Obtained a micro hdmi adapter so as to view the boot process, the device shuts down on a kernel panic.
Last edit: 6 years 1 week ago by lumberjack_jeff. Reason: new info
6 years 4 days ago - 6 years 4 days ago #187488 by idea
I'm also getting this same issue of no USB mouse / keyboard (all types) with my 8Gb version - straight from fresh SD card image - linuxcnc-2.8.0-pi4.img
Any ideas of how to fix?
This is not a power issue (that has been previously noted), running of 7A SMPS and also tried with 20Ahr battery pack with same result.
When plugging in usb mouse, the red sensor led lights up briefly before going out (all 4 usb ports).
Unable to set up remote access so impossible to generate any kind of dump.
Last edit: 6 years 4 days ago by idea.
6 years 4 days ago #187557 by andypugh
There are some ideas here, but they rely on SSH being available.
Do you have the same problem with a standard Raspbian install, or is it just the LinuxCNC image?
6 years 4 days ago #187561 by idea
i've made a separate thread to avoid clogging this one up
forum.linuxcnc.org/9-installing-linuxcnc...-on-raspberry-pi-8gb
Time to create page: 0.316 seconds
