LinuxCNC on Debian 10 Buster quick and easy install
- Thank you received: 7001
03 May 2020 17:03 #166518
Replied by tommylight on topic LinuxCNC on Debian 10 Buster quick and easy install
What computer ? Anything from the last 10 or more years should be fine with 64 bit versions.Probably a silly question but I am upgrading an i386 system from 2.7 to 2.9 in order to run the fancy plasmac config on my plasma gantry. I assume I should download an i386 iso rather than the recommended amd64 link?
- Plasmaguy
- Thank you received: 9
03 May 2020 20:42 #166539
by Plasmaguy
Replied by Plasmaguy on topic LinuxCNC on Debian 10 Buster quick and easy install
It's a Dell Vostro 220 I bought a few years ago for cheap and has been a workhorse running LCNC v 2.7 since 2017ish.
04 May 2020 00:48 #166556
Download the ISO, write it to a USB and try to boot it, it should boot just fine.
The following user(s) said Thank You: Plasmaguy
- Plasmaguy
04 May 2020 04:09 - 04 May 2020 04:09 #166568
by Plasmaguy
I got it to boot and completed through;
cd Downloads
sudo gdebi python-gtksourceview2_2.10.1-3_amd64.deb
Now at the next point I am getting the message;
plaz@plaz-pc:~/Downloads$ sudo gdebi linuxcnc-uspace_2.8.0~pre1.5649.gec411a428_amd64.deb
gdebi error, file not found: linuxcnc-uspace_2.8.0~pre1.5649.gec411a428_amd64.deb
The required file is located in my download folder along with the one that has already processed, any idea what might be the problem? I have tried both 2.9 & 2.8 versions to the same result.
cd Downloads
Last edit: 04 May 2020 04:09 by Plasmaguy.
04 May 2020 10:36 #166605
Most probably wrong file name, check the build numbers if they correspond between the downloaded file and the one you are trying to install.
- Plasmaguy
04 May 2020 13:10 - 04 May 2020 13:23 #166617
by Plasmaguy
The numbers seem to match. I only downloaded what was linked in the original post.
I did notice a discrepancy between was comes up when I enter the uname -a command and what is shown in the OP.
plaz@plaz-pc:~$ uname -a
Linux plaz-pc 4.19.0-8-rt-amd64 #1 SMP PREEMPT RT Debian 4.19.98-1+deb10u1 (2020-04-27) x86_64 GNU/Linux
vs.
Should say "Linux some_name 4.19.0-8-rt-amd64 #1 SMP PREEMPT RT Debian 4.19.98-1 (2020-01-26) x86_64 GNU/Linux
vs.
Last edit: 04 May 2020 13:23 by Plasmaguy. Reason: add info
04 May 2020 15:06 #166626
That should work, the issue above is due to miss typed name of the file not residing in the Downloads folder.
- Plasmaguy
04 May 2020 17:46 #166645
by Plasmaguy
I'm sorry but I do not understand.
I tried this on another computer with 64 bit system with the same result.
I followed the directions correctly (I think) so what do I need to do to get it working?
04 May 2020 18:55 #166657
in terminal
cd Downloads
ls
what does it show ?
cd Downloads
ls
what does it show ?
- Plasmaguy
04 May 2020 20:18 #166673
by Plasmaguy
I went another way and installed the linux mint you linked to here
forum.linuxcnc.org/9-installing-linuxcnc...er-mint-iso?start=10
without any problem.
Thank you!
Thank you!
Time to create page: 0.154 seconds
