ISO to test: Exegnulinux remasterd with LinuxCNC, a lots of tools and no systemd
5 years 6 months ago #205358 by clifo
/usr/bin/latency-test /etc/init.d/realtime: line 112: /usr/bin/lsmod: No such file or directory /etc/init.d/realtime: line 112: /usr/bin/grep: No such file or directory /etc/init.d/realtime: line 112: /usr/bin/lsmod: No such file or directory /etc/init.d/realtime: line 112: /usr/bin/grep: No such file or directory /etc/init.d/realtime: line 112: /usr/bin/lsmod: No such file or directory /etc/init.d/realtime: line 112: /usr/bin/grep: No such file or directory /etc/init.d/realtime: line 112: /usr/bin/lsmod: No such file or directory /etc/init.d/realtime: line 112: /usr/bin/grep: No such file or directory /etc/init.d/realtime: line 112: /usr/bin/lsmod: No such file or directory /etc/init.d/realtime: line 112: /usr/bin/grep: No such file or directory insmod: ERROR: could not insert module /usr/realtime-4.14.174-rtai-amd64/modules/rtai_hal.ko: File exists
  • twoflowers
  • Topic Author
  • New Member
  • New Member
5 years 6 months ago #205359 by twoflowers
The SHA checksum of the image is correct?
5 years 6 months ago #205371 by clifo
  • twoflowers
  • Topic Author
  • New Member
  • New Member
5 years 6 months ago #205375 by twoflowers
Thank you for testing. The lines with "/usr/bin/" are not quite cosmetic, but you should be able to run "latency-test" after rebooting, as long as you did not run any other realtime-application. Can you try this (rebooting and running latency-test only) and report back?
I just patched /etc/init.d/realtime to use the correct path, so it will be corrected in the next version.
5 years 6 months ago #205393 by clifo
  • twoflowers
  • Topic Author
  • New Member
  • New Member
5 years 6 months ago #205527 by twoflowers
Ok, I found it. Looks like refracta breaks linuxcnc (RTAI) - but I have not found what exactly breaks. So in the meantime this is a workaround - you need working internet for this:
Boot from ISO and open a terminal.
$ sudo apt update $ sudo apt reinstall linuxcnc $ latency-test
Time to create page: 0.264 seconds
