ISO to test: Exegnulinux remasterd with LinuxCNC, a lots of tools and no systemd
5 years 11 months ago #188193 by partec
Danke, interessant und funktioniert, das Desktop Hintergrundbild allein ist einen Blick wert, ich habe auch bei devuan wiki hineingeschaut :)
nebenbei, ich war etwas erstaunt,
Wilkommen
bei der Oberflächenvorbereitung sollte noch deutsch verbessert werden
  • twoflowers
  • Topic Author
  • New Member
  • New Member
5 years 11 months ago - 5 years 11 months ago #188247 by twoflowers
Good you like it:)
Das TDE Projekt trinitydesktop.org freut sich über jeden, der an der Verbesserung der Übersetzung mitmacht - Kommunikation über die Mailingliste.
Last edit: 5 years 11 months ago by twoflowers.
5 years 10 months ago #191391 by whoppa
Wow this is great. I installed to a partition on my hard drive. As not so great with linux I struggled a bit to work out how to boot it. Then I found that In my existing install sudo update-grub did the trick. I imported my machine config and its running sweet. Thanks
5 years 10 months ago - 5 years 10 months ago #191413 by Clive S
(Note: Check GRUB settings)
I have tried this ISO and it seems to be snappy as Tom says.
But I am having trouble to get it to boot from the HD. I can see all the system files on the drive etc.
Can you please help with getting it to boot from the sata drive.
Edit: I copied the ISO to a USB with Win32DiskImager to make it bootable
Edit: If I install mint on another partition on the hard drive and use the boot menu on that I can then pick the appropriate boot to boot the the Exegnulinux system.
But I don't seem to be able to get the grub on its own.. I get the error PXE-E53 No boot file received
Last edit: 5 years 10 months ago by Clive S.
  • BeagleBrainz
  • New Member
  • New Member
5 years 10 months ago #191535 by BeagleBrainz
That's a little weird, that's the kind of error you would get if you were trying to boot a machine off a network.
  • twoflowers
  • Topic Author
  • New Member
  • New Member
5 years 7 months ago - 5 years 7 months ago #203983 by twoflowers
Spring 2021 update is here! Biggest changes: LinuxCNC 2.8.1, TDE 14.1 and all tools updateted to the latest version. Links in the first posting have been adapted.
Please try and report back :)
Last edit: 5 years 7 months ago by twoflowers.
Time to create page: 0.170 seconds
