linuxcnc-2.8.0-pi4.img - no USB on raspberry pi 4 - 8GB & 2GB
5 years 6 months ago #206009 by tjtr33
Just in case the normal debian user is here
and sees the rpi imager is for ubuntu...
the github source
github.com/raspberrypi/rpi-imager
has details how to build raspberry pi imager for debian
also for Fedora/RHEL/CentOS Linux
hth
tomp
5 years 6 months ago - 5 years 6 months ago #206012 by tjtr33
I get erors building on debian 9 after deps installed
Generating qrc source rpi-imager_automoc.dir/qrc_translations_62PNPOSFFYCW6J.cpp RCC: Error in '/media/tomp/toms4T/2021/misc-15apr2021/misc-emc/rpi4-andySezThisJustWorks/rpi-imager-for-debian/rpi-imager-qml/obj-x86_64-linux-gnu/translations.qrc': Cannot find file 'rpi-imager_de.qm' AUTORCC: error: process for rpi-imager_automoc.dir/qrc_translations_62PNPOSFFYCW6J.cpp failed: RCC: Error in '/media/tomp/toms4T/2021/misc-15apr2021/misc-emc/rpi4-andySezThisJustWorks/rpi-imager-for-debian/rpi-imager-qml/obj-x86_64-linux-gnu/translations.qrc': Cannot find file 'rpi-imager_de.qm' rcc failed...
tomp ( who will try with dd )
Last edit: 5 years 6 months ago by tjtr33.
5 years 6 months ago #206085 by elovalvo
activa73 wrote: Hello,
I have install Linuxcnc-2.8.1-pi4.img on my pi4 4 Go.
I prepared a SD image, downloadable at the following link:
Linuxcnc_2.8.1_5.10.25-rt35.img
is based on Linux raspberrypi 5.10.25-rt35-v7+ with PREEMPT_RT and LinuxCNC 2.8.1 installed following this link
Installing on Raspian10
I checked operation on Raspberry Pi 4 with 2GB and 4GB.
I don't have a Raspberry Pi 4 with 8GB, so I invite you to check if and how it works.
5 years 5 months ago - 5 years 5 months ago #210587 by Stepping3D
Initial test on RPi 8GB has USB and everything working using this image, thanks! Will add feedback if there's anything that comes up...
Note: Had to add "boot_delay=1" to config.txt after enabling RTC or it booted to rainbow screen, but everything else is great.
Last edit: 5 years 5 months ago by Stepping3D.
5 years 4 months ago #212085 by Craig E
Hey everyone I finally have my machine built but I can't get LinuxCNC to run.
I thought I would try down loading a fresh image so followed this link Linuxcnc_2.8.1_5.10.25-rt35.img but it took me to lcnc_2.8.1_rt64.img file. I gave it a try seem so go good until I shut down and try to reboot then this happens. see image attached.
Any ideas on how to fix it or dose anyone have a good rpi4 image? I am using Mesa 7i96 and I just can't seem to get it to work.
I have re imaged it 3 time this happens every time after everything is installed and updated
4 years 9 months ago #230773 by COFHAL
Time to create page: 0.427 seconds
