linuxcnc-2.8.0-pi4.img - no USB on raspberry pi 4 - 8GB & 2GB
5 years 11 months ago #188768 by idea
I found the following at - wiki.debian.org/RaspberryPi4
- USB doesn't work up to kernel 5.7 for the hardware variant of PI4 with 8GB RAM
- This issue has a fix in kernel 5.8 (currently in experimental): lkml.org/lkml/2020/5/5/998
But I'm not clear if the build image here is running debian
5 years 11 months ago #188831 by cakeslob
so no usb period after startup? do they power up at all?
i havent tried it on my 8gb yet, but here is what rpi forum says, seems related to the topic at hand
www.raspberrypi.org/forums/viewtopic.php?t=287340
www.raspberrypi.org/forums/viewtopic.php?t=285563
5 years 11 months ago #188837 by idea
My 8GB powers up all the way through to the desktop, just fails to start USB during boot (see errors logged above), so no keyboard / mouse.
5 years 11 months ago #189150 by BrettB
Hi all,
Having the same issue with my pi4 8GB. No USB after boot.
What's the current workaround? I'm very new to LinuxCNC so this also my first install.
Kind regards,
Brett.
5 years 11 months ago #189785 by idea
No work around that i have seen yet, i've not had time to see how a manual install works.
5 years 11 months ago #190548 by idea
So i downloaded [2020-08-20-raspios-buster-armhf.img] and followed the instructions [ gnipsel.com/linuxcnc/uspace/rpi4-rt.html ] to install PREEMPT RT, no issues in compiling and installing, at reboot i got the errors
xhci_hcd 0000:01:00.0: can't setup: -110
xhci_hcd 0000:01:00.0: init 0000:01:00.0 fail, -110
And the machine fails to boot any further, intermittetent green flashing light. So looks like an issue with the RT kernel. This is likely because using external USB SSD.
I also tried the pre-made iso [ unofficialpi.org/Distros/RealtimePi/nightly/ ] which gave a whole load of other errors and failed to boot any further.
Submitted bug report [ github.com/raspberrypi/linux/issues/3976 ]
Time to create page: 0.164 seconds
