Last update of LinuxCNC Raspberry Pi4 USB does not work
- zz912
- Thank you received: 98
09 Jan 2021 16:16 #194602
by zz912
Last update of LinuxCNC Raspberry Pi4 USB does not work was created by zz912
Hello,
I used several month Pi4 + LinuxCNC + Mesa 7i96. All time it was working. I install image from here:
www.linuxcnc.org/iso/linuxcnc-2.8.0-pi4.zip
But the last update kill USB on RPI. RPI booted, but with out mouse and key I should only look on monitor. So, I had to make new image for SD card. It work again. I made "sudo apt-get update, upgrade" and after reboot the USB was killed again. I tried it several times.
I tried install:
downloads.raspberrypi.org/raspios_arm64/...os_arm64-2020-08-24/
USB worked. I tried reboot RPI several times and USB worked.
I tried install LinuxCNC:
linuxcnc.org/docs/2.8/html/getting-start...lling_on_raspbian_10
after reboot the RPI does not boot the system at all.
Can I ask anybodyfor help?
I tried install:
- Thank you received: 7490
09 Jan 2021 16:34 #194608
Replied by tommylight on topic Last update of LinuxCNC Raspberry Pi4 USB does not work
Title of the topic changed.
Why would you use such a miss leading and derogatory title?
Use the search function, there are at least two topics with the same subject here.
The following user(s) said Thank You: partec
- partec
- Thank you received: 27
09 Jan 2021 16:34 - 09 Jan 2021 16:37 #194609
by partec
Replied by partec on topic Last update of LinuxCNC killing my Raspberry Pi4
sorry
Last edit: 09 Jan 2021 16:37 by partec.
09 Jan 2021 16:36 #194610
- zz912
09 Jan 2021 16:41 #194612
by zz912
I'm sorry, I didn't mean to be rude. I am from the Czech Republic and my English is very bad.
Replied by zz912 on topic Last update of LinuxCNC Raspberry Pi4 USB does not work
09 Jan 2021 16:44 #194613
Oh well we can blame google for that then !
Ahoj Pane, jak se mate?
09 Jan 2021 16:45 #194614
Replied by tommylight on topic Last update of LinuxCNC killing my Raspberry Pi4
- zz912
09 Jan 2021 16:53 #194615
by zz912
Mám se dobře, děkuji za optání. Jak se máte vy? Setkal jste se někdy ve svém životě s češtinou, nebo s Českou Republikou?Ahoj Pane, jak se mate?
09 Jan 2021 16:58 #194618
Jsem byl v cheskou, nejvic v Brne!
- zz912
09 Jan 2021 17:02 - 09 Jan 2021 17:17 #194619
by zz912
A líbilo se Vám u nás? Jak dlouho jste u nás byl?
Klidně tohle vlákno můžete smazat, ať nedělá zde na fóru nepořádek.
Děkuji
Děkuji
Last edit: 09 Jan 2021 17:17 by zz912.
Time to create page: 0.170 seconds
