Last update of LinuxCNC Raspberry Pi4 USB does not work
  • zz912
  • zz912's Avatar Topic Author
  • Platinum Member
  • Platinum Member
11 Jan 2021 13:20 #194900 by zz912
Thank you. I will try it.
  • zz912
  • Platinum Member
  • Platinum Member
11 Jan 2021 18:51 #194934 by zz912
After install the realtime kernel:
sudo apt-get install linux-image-4.19.71-rt24-v7l+
USB stoped work.
11 Jan 2021 18:55 #194935 by andypugh
Just to check, what does "uname -a" tell you?
I really thought that I had this fixed, but don't have the right Pi to test it on (I have 5 other models of Pi..)
  • zz912
  • Platinum Member
  • Platinum Member
11 Jan 2021 19:04 - 11 Jan 2021 19:40 #194936 by zz912
I can't figure out "uname -a" after install the realtime kernel, because I can't control RPI4 without a keyboard and mouse. Once the USB breaks I have to start with a new image.
Or do you want "uname -a" before install the realtime kernel?
I lost all my work before this update. Fortunately, I didn't do anything important at RPI.
I'm not a IT technik. I'm not a programmer. I am beginner.
If you want to test my hardware remotely this is not a problem. But I need to know what to do.
Last edit: 11 Jan 2021 19:40 by zz912.
11 Jan 2021 19:51 #194944 by andypugh
Get the Raspberry Pi Imager for a (non Pi) computer of your choice and install the standard Raspberry Pi OS.
www.raspberrypi.org/software/
Then try "sudo rpi-eeprom-update" and paste the result here.
Then you can try installing the realtime kernel, and see if USB still works.
The following user(s) said Thank You: zz912
  • zz912
  • Platinum Member
  • Platinum Member
11 Jan 2021 21:41 - 11 Jan 2021 21:56 #194961 by zz912
I made:
Result:
pi@raspberrypi:~ $ sudo rpi-eeprom-update
BCM2711 detected
Dedicated VL805 EEPROM detected
BOOTLOADER: up-to-date
CURRENT: Thu Sep  3 12:11:43 UTC 2020 (1599135103)
 LATEST: Thu Sep  3 12:11:43 UTC 2020 (1599135103)
 FW DIR: /lib/firmware/raspberrypi/bootloader/critical
VL805: up-to-date
CURRENT: 000138a1
 LATEST: 000138a1
Then:
sudo apt-get update
sudo apt-get upgrade
sudo apt-get dist-upgrade
Then:
BCM2711 detected
VL805: up-to-date
CURRENT: 000138a1
 LATEST: 000138a1
Then:
sudo reboot
USB working:
BCM2711 detected
CURRENT: Čt zář  3 12:11:43 UTC 2020 (1599135103)
 LATEST: Čt zář  3 12:11:43 UTC 2020 (1599135103)
VL805: up-to-date
CURRENT: 000138a1
 LATEST: 000138a1
Then:
sudo apt-key adv --keyserver hkp://keys.gnupg.net --recv-key 3cb9fd148f374fef
echo deb http://linuxcnc.org/ buster base 2.8-rtpreempt | sudo tee -a /etc/apt/sources.list.d/linuxcnc.list
sudo apt-get update
Then:
BCM2711 detected
VL805: up-to-date
CURRENT: 000138a1
 LATEST: 000138a1
Then:
Then:
BCM2711 detected
VL805: up-to-date
CURRENT: 000138a1
 LATEST: 000138a1
Then:
pi@raspberrypi:~ $ sudo apt-get install rpi-eeprom
Načítají se seznamy balíků… Hotovo
Vytváří se strom závislostí
Načítají se stavové informace… Hotovo
rpi-eeprom je již nejnovější verze (11.1-1).
0 aktualizováno, 0 nově instalováno, 0 k odstranění a 0 neaktualizováno.
Then:
sudo reboot
I will continue after reboot.
Last edit: 11 Jan 2021 21:56 by zz912.
  • zz912
  • Platinum Member
  • Platinum Member
11 Jan 2021 22:01 #194962 by zz912
USB dont work. :-(
11 Jan 2021 22:02 #194963 by andypugh
Are you able to ssh in to the Pi?
  • zz912
  • Platinum Member
  • Platinum Member
11 Jan 2021 22:14 #194965 by zz912
No, I dont know how.
14 Jan 2021 17:11 #195341 by andypugh
Can those with this problem please state exactly which model of Pi they are using?
One possible problem is that the 8GB Pi needs a 64bit kernel if it is going to address more than 4GB.
Time to create page: 0.880 seconds
