Last update of LinuxCNC Raspberry Pi4 USB does not work
28 Jan 2021 00:05 #196860
Yes, Pi400 remains a problem. (I have one)
But the Pi400 _probably_ isn't a good CNC controller candidate?
Replied by andypugh on topic Last update of LinuxCNC Raspberry Pi4 USB does not work
Today test with brand new pi 400 using :
www.linuxcnc.org/temp/image_2021-01-20-linuxcnc-pi4-3G.zip.
28 Jan 2021 00:14 #196862
The LinuxCNC docs now point at a (renamed) version of the 3G limited image, with warnings that it is known to not work on all variants.
linuxcnc.org/docs/2.8/html/getting-start...tml#_normal_download
- rsaccon
28 Jan 2021 00:48 #196867
by rsaccon
Replied by rsaccon on topic Last update of LinuxCNC Raspberry Pi4 USB does not work
andypugh, according to my latest test (see my previous post), the www.linuxcnc.org/temp/image_2021-01-20-linuxcnc-pi4-3G.zip does work on Pi 8GB. Wlan and USB are ok.
22 Feb 2021 09:32 #199691
There might be a fix in the kernel discussed here:
github.com/kdoren/linux/discussions/3#discussioncomment-389373
There is a downloadable kernel image deb here:
github.com/kdoren/linux/releases/tag/5.10.16-rt30
(I have not tried it)
- Juice
22 Feb 2021 17:59 - 22 Feb 2021 19:29 #199742
by Juice
Replied by Juice on topic Last update of LinuxCNC Raspberry Pi4 USB does not work
EDIT: Apologies for the redundant post, the 2.8.1 image works for me. linuxcnc.org/downloads/ still only shows 2.8.0 which is where the confusion occured. I found the 2.8.1 image in the end at linuxcnc.org/docs/2.8/html/getting-start...tml#_normal_download
Hi I'm having the same issue (no mouse, no keyboard) with the raspberry pi 4b 4Gb model.
I'm able to ssh in to the pi, here is the output for uname -a:Here is also the output of lsmod just incase it helps:I'm happy to help you get any more information
pi@raspberrypi:~ $ uname -a
Linux raspberrypi 4.19.71-rt24-v7l+ #1 SMP PREEMPT RT Fri Jan 1 21:15:16 GMT 2021 armv7l GNU/Linuxpi@raspberrypi:~ $ lsmod
Module Size Used by
bnep 20480 2
hci_uart 40960 1
btbcm 16384 1 hci_uart
serdev 20480 1 hci_uart
bluetooth 380928 24 hci_uart,bnep,btbcm
ecdh_generic 28672 1 bluetooth
8021q 32768 0
garp 16384 1 8021q
stp 16384 1 garp
llc 16384 2 garp,stp
brcmfmac 315392 0
brcmutil 20480 1 brcmfmac
sha256_generic 20480 0
cfg80211 634880 1 brcmfmac
vc4 176128 0
rfkill 28672 6 bluetooth,cfg80211
bcm2835_codec 36864 0
drm_kms_helper 184320 1 vc4
bcm2835_v4l2 45056 0
v4l2_mem2mem 24576 1 bcm2835_codec
bcm2835_mmal_vchiq 32768 2 bcm2835_codec,bcm2835_v4l2
v4l2_common 16384 1 bcm2835_v4l2
v3d 65536 0
snd_soc_core 184320 1 vc4
videobuf2_dma_contig 20480 1 bcm2835_codec
videobuf2_vmalloc 16384 1 bcm2835_v4l2
snd_compress 20480 1 snd_soc_core
gpu_sched 28672 1 v3d
videobuf2_memops 16384 2 videobuf2_dma_contig,videobuf2_vmalloc
snd_bcm2835 24576 1
snd_pcm_dmaengine 16384 1 snd_soc_core
videobuf2_v4l2 24576 3 bcm2835_codec,bcm2835_v4l2,v4l2_mem2mem
raspberrypi_hwmon 16384 0
syscopyarea 16384 1 drm_kms_helper
snd_pcm 98304 4 vc4,snd_pcm_dmaengine,snd_bcm2835,snd_soc_core
drm 442368 5 v3d,vc4,gpu_sched,drm_kms_helper
hwmon 16384 1 raspberrypi_hwmon
videobuf2_common 45056 4 bcm2835_codec,bcm2835_v4l2,v4l2_mem2mem,videobuf2_v4l2
sysfillrect 16384 1 drm_kms_helper
drm_panel_orientation_quirks 16384 1 drm
sysimgblt 16384 1 drm_kms_helper
snd_timer 32768 1 snd_pcm
videodev 200704 6 bcm2835_codec,v4l2_common,videobuf2_common,bcm2835_v4l2,v4l2_mem2mem,videobuf2_v4l2
fb_sys_fops 16384 1 drm_kms_helper
vc_sm_cma 36864 1 bcm2835_mmal_vchiq
snd 73728 7 snd_compress,snd_timer,snd_bcm2835,snd_soc_core,snd_pcm
media 36864 3 bcm2835_codec,videodev,v4l2_mem2mem
rpivid_mem 16384 0
uio_pdrv_genirq 16384 0
fixed 16384 0
uio 20480 1 uio_pdrv_genirq
i2c_dev 20480 0
ip_tables 24576 0
x_tables 32768 1 ip_tables
ipv6 454656 30
Last edit: 22 Feb 2021 19:29 by Juice. Reason: fixed the issue, probably didn't do enough reading before I posted :/
- cakeslob
- Thank you received: 280
26 Feb 2021 01:56 #200167
by cakeslob
Are people having issues with 5.4.87-rt48? I have full 8gb of ram and usb
Replied by cakeslob on topic Last update of LinuxCNC Raspberry Pi4 USB does not work
- tjtr33
- Thank you received: 54
15 Apr 2021 16:44 #206019
by tjtr33
Replied by tjtr33 on topic Last update of LinuxCNC Raspberry Pi4 USB does not work
following the link
drive.google.com/file/d/1xsBfr4HsNsnG4tK...N27/view?usp=sharing
gets you
no preview available
file is in owner's trash
so
no solution here, move along
tomp
gets you
so
tomp
- tjtr33
15 Apr 2021 17:03 #206022
by tjtr33
the image at
is a 404 not found
and the image
www.linuxcnc.org/iso/linuxcnc-2.8.1-pi4.zip
does 'work'
it gets you an image that has usb and wifi
but has memory limited to 3078 in config-rt.txt.
so
there is no fix for the usb wifi memory problem
there is a work-around for the usb and wifi problem,
and that 'fix' requires limiting memory on 4 and 8 gig Pi's,
I followed both threads end to end hoping for better..
But, better does not exist yet ( 15apr2021 )
tomp
is a 404 not found
and the image
does 'work'
so
tomp
- elovalvo
- Thank you received: 127
16 Apr 2021 06:37 #206086
by elovalvo
I've already answered you at this link
forum.linuxcnc.org/9-installing-linuxcnc...-2gb?start=50#206085
Replied by elovalvo on topic Last update of LinuxCNC Raspberry Pi4 USB does not work
the image at
is a 404 not found
and the image
does 'work'
so
tomp
The following user(s) said Thank You: tjtr33
- tjtr33
18 Apr 2021 16:31 #206315
by tjtr33
Thanks, I will try your newest 64 bit image
I thought we were asked to continue on a different thread
Andy Pugh wrote
Also, can we move this discussion to one thread, ie this one:
forum.linuxcnc.org/9-installing-linuxcnc...-work?start=0#194602
Sorry I missed your post, thanks for the work.
I will monitor the suggested thread .
TomP
TomP
Time to create page: 0.363 seconds
