Last update of LinuxCNC Raspberry Pi4 USB does not work
09 Jan 2021 17:18 #194624 by tommylight
Moc, je tam vyborne ! Asi 8 mesicu v celku, jsem byl vic jak 10 krat.
  • zz912
  • zz912's Avatar Topic Author
  • Platinum Member
  • Platinum Member
09 Jan 2021 17:24 #194626 by zz912
Tak až budete v česku, tak se můžete stavit.
10 Jan 2021 04:25 - 10 Jan 2021 04:34 #194680 by alkabal
Hi
I have the same problem
After sudo apt-get upgrade my Rpi4gb c03111 (rev 1.1) and now do not boot with my usb key.
So i have try to reinstall with iso official from linuxcnc server but same problem do not boot from USB.
After that i have install iso official from linuxcnc again on a sd-card, this boot correctly via sd-card but after another sudo apt-get upgrade now i have no more usb keyboard etc. (but they work fine before update)
I'm lost
pi@linuxcnc:~ $ lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
pi@linuxcnc:~ $ lsusb -v
Couldn't open device, some information will be missing
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceSubClass         0
  bDeviceProtocol         1 Single TT
  bMaxPacketSize0        64
  idVendor           0x1d6b Linux Foundation
  idProduct          0x0002 2.0 root hub
  bcdDevice            4.19
  iManufacturer           3
  iProduct                2
  iSerial                 1
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0019
    bNumInterfaces          1
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         9 Hub
      bInterfaceSubClass      0
      bInterfaceProtocol      0 Full speed (or root) hub
      iInterface              0
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0004  1x 4 bytes
        bInterval              12
Last edit: 10 Jan 2021 04:34 by alkabal.
  • zz912
  • Platinum Member
  • Platinum Member
10 Jan 2021 08:45 #194694 by zz912
My wife is to blame. Thanks to that, I pay much more attention her.
:-D
10 Jan 2021 23:48 #194817 by andypugh
Follow the install instructions here:
linuxcnc.org/docs/2.8/html/getting-start...lling_on_raspbian_10
I am working on a new SD card image, but it takes a few hours at a time to make one, then a few minutes to test it, and then another few hours to try again.
The process above will definitely work.
The following user(s) said Thank You: alkabal, snowgoer540
11 Jan 2021 00:52 #194833 by alkabal
Before that i have use again the official iso and only do apt-get update (without upgrade)
and i have installed the necessary for RIP successfuly
Many thanks for the work done and pointing a other solution !
  • zz912
  • Platinum Member
  • Platinum Member
11 Jan 2021 11:00 #194876 by zz912
Can I ask for an accurate Raspbian image that the upgrade works with?
11 Jan 2021 11:32 #194883 by alkabal
from offcial repo imo
  • zz912
  • Platinum Member
  • Platinum Member
11 Jan 2021 12:22 #194887 by zz912
11 Jan 2021 12:35 #194890 by alkabal
Time to create page: 0.156 seconds
