Last update of LinuxCNC Raspberry Pi4 USB does not work
- pauluzs
19 Jan 2021 02:59 - 19 Jan 2021 03:00 #195866
by pauluzs
For Which model raspberry , what eeprom version and also the kernel version used?
Replied by pauluzs on topic Last update of LinuxCNC Raspberry Pi4 USB does not work
Hi
Just tried with fresh official debian 32bits using the guide and sdcard
linuxcnc.org/docs/2.8/html/getting-start...lling_on_raspbian_10
After rebooting on the 6e step, no more usb no keyboard/touchscreen.
only using apt-get update
Last edit: 19 Jan 2021 03:00 by pauluzs.
- alkabal
- Thank you received: 52
19 Jan 2021 03:02 - 19 Jan 2021 03:18 #195867
by alkabal
Replied by alkabal on topic Last update of LinuxCNC Raspberry Pi4 USB does not work
My unit is : Rpi4gb c03111 (rev 1.1)
The memory trick work fine i get USB working again after rebooting
The built in firmware from linuxcnc document
reboot after linuxcnc USB work
tomorrow try apt-get upgrade
Linux linuxcnc 4.19.71-rt24-v7l+ #4 SMP PREEMPT RT Thu Apr 30 22:00:15 CDT 2020 armv7l GNU/LinuxBCM2711 detected
Dedicated VL805 EEPROM detected
BOOTLOADER: up-to-date
CURRENT: Thu 03 Sep 2020 12:11:43 PM UTC (1599135103)
LATEST: Thu 16 Apr 2020 05:11:26 PM UTC (1587057086)
FW DIR: /lib/firmware/raspberrypi/bootloader/critical
VL805: up-to-date
CURRENT: 000138a1
LATEST: 000137adreboot after linuxcnc USB work
Last edit: 19 Jan 2021 03:18 by alkabal.
20 Jan 2021 08:30 #195976
I have never had any problem with that model running the LinuxCNC image...
Anyway, I have built a new SD card image, and kicked off the build of a second with the memory limit.
I did plan to put them both on the server for testing, but something has come up here and I am going to be away from my computers for a few days.
Replied by andypugh on topic Last update of LinuxCNC Raspberry Pi4 USB does not work
The following user(s) said Thank You: zz912
- alkabal
20 Jan 2021 09:04 #195979
by alkabal
I never get problem before, but from some time i get no more usb as you can see after installing kernel on official debian, or after apt-get upgrad with your image.
Maybe this is because i have updated the boot eeprom, i really do not know why but for sure i get usb problem recently with this old model.
Many thanks for the work done, I hope to you nothing bad is happened !
22 Jan 2021 01:20 #196172
There is a new SD card image here:
www.linuxcnc.org/temp/image_2021-01-20-linuxcnc-pi4-3G.zip
It works for me on an old Pi4 4GB and a new Pi4 2GB. Both as a fresh install and after apt-get update / apt-get upgrade.
I would appreciate it if owners of new 4GB Pi, 8GB Pi and Pi3 could test it and report back.
The following user(s) said Thank You: elovalvo, zz912, rsaccon
- szech713
22 Jan 2021 03:24 #196176
by szech713
Replied by szech713 on topic Last update of LinuxCNC Raspberry Pi4 USB does not work
Running the new image
It works on my Pi4B 4GB. Fresh install and after apt-get update / apt-get upgrade
- zz912
- Thank you received: 98
22 Jan 2021 06:54 #196180
by zz912
Replied by zz912 on topic Last update of LinuxCNC Raspberry Pi4 USB does not work
It works on my Pi4 4GB too. Thank you.
- rsaccon
22 Jan 2021 15:16 #196233
by rsaccon
Replied by rsaccon on topic Last update of LinuxCNC Raspberry Pi4 USB does not work
I tried on my Pi4 8Gb, USB works, unfortunately wlan does not work. With the released LinuxCNC 2.8.0 and 2.8.1 images for Pi I had no problems with wlan, but USB did not work. Is there any specific info from logfiles or output from network commands you want me to post here ?
22 Jan 2021 18:41 #196256
I see the same issue with my Pi400.
At least there is a workaround for Wlan, you can use ethernet or a plug-in WiFi dongle.
How could you tell that WiFi worked without USB to cycle through the setup and type in passwords?
- zz912
22 Jan 2021 20:08 #196268
by zz912
I have the same problem with wlan.
I think I had problems with wlan in December, but I thought it was a bad wifi-router. USB probably worked for me at the time, but not wlan.
I wanted an RPI4 + mesa 7i96 to drive the lathe, but the RPI was so slow, so I didn't use it and used a desktop computer. That's why I wasn't interested in wifi. Then I wanted to find out in January why RPI4 + mesa 7i96 was unusable, but there was a problem with USB that blocked my entire RPI4.
My chromium browser didn't work. I reinstalled it, but it didn't help. That's why I installed firefox-esr
Time to create page: 0.138 seconds
