RPI4 - Debian / LinuxCNC / EtherCAT / XFCE
- ftree
- Thank you received: 10
16 May 2022 01:31 - 21 May 2022 23:59 #243060
by ftree
RPI4 - Debian / LinuxCNC / EtherCAT / XFCE was created by ftree
Hi!
Using a guide on here from rodw I've made a fork of rpi-image-builder to make an "RPI4 bookworm" bootable image file
Your HOST machine should be Debian Bullseye until further notice
22/05/2020 - bumped to new components
debian bookworm
kernel 5.15.40-rt43 ( processor.max_cstate=1 , isolcpus=2,3 )
lxqt 1.1.0
ethercat 1.5.2-32
linuxcnc-uspace linuxcnc-uspace-dev mesaflash
linuxcnc-ethercat
See github.com/djsftree/rpi-img-builder
Sucessfully builds on bullseye host. See instructions at top of README.
Writing to a card now.
debian bookworm
lxqt 1.1.0
ethercat 1.5.2-32
linuxcnc-ethercat
Last edit: 21 May 2022 23:59 by ftree.
- Thank you received: 4149
16 May 2022 04:37 #243065
Replied by rodw on topic RPI4 - Debian Bookworm / LinuxCNC / EtherCAT / XFCE
Very cool.
Does this include the PREEMPT_RT kernel patch?
Do you build this on the PI or on AMD64 with a cross compiler?
- ftree
16 May 2022 09:31 - 16 May 2022 09:47 #243071
by ftree
Replied by ftree on topic RPI4 - Debian Bookworm / LinuxCNC / EtherCAT / XFCE
Builds on AMD64 hosts with cross compiler. The ./install grabs all cross dependencies.
github.com/djsftree/rpi-img-builder/blob/master/install
github.com/djsftree/rpi-img-builder/blob.../scripts/.ccompile64
Your repo script is here
github.com/djsftree/rpi-img-builder/blob...userscripts/uscripts
Includes PREEMPT_RT kernel patch - yes. In the instructiions we pull the 5.15.36 merge from rasberrypi/linux
github.com/raspberrypi/linux/commit/ac27...47aeb491137bf3e9216a
rpi-img-builder patches 5.15.36 to 5.15.36-rt41with the files in
github.com/djsftree/rpi-img-builder/tree.../patches/userpatches
I'm using kdoren rt64 config for now but will update that soon
github.com/djsftree/rpi-img-builder/blob...onfig/rt64_defconfig
Last edit: 16 May 2022 09:47 by ftree.
- ftree
16 May 2022 09:54 - 16 May 2022 09:57 #243072
by ftree
I think the stage here needs a little work
github.com/djsftree/rpi-img-builder/blob...scripts/uscripts#L44
We're not pickng up the key stored.
Should this be
deb [signed-by=/usr/share/keyrings/ethercat.gpg] ... .... ?
Should this be
Last edit: 16 May 2022 09:57 by ftree.
16 May 2022 10:11 #243074
Not sure. Are there any questions to answer on the apt-get ethercat lines?
16 May 2022 11:59 #243077
Ok I tried this on a Debian Bookworm PC with kernel = 5.17
It failed with message saying "The OS you are running is not supported"
edited the script and changed bullseye to bookworm in the script and I got past that but every other command failed.
So it seems this is for Bullseye. Maybe you should update the title of this thread..
I will try on another machine tomorrow.... I think I have a bullseye PC somewhere.
I am not really sure what is going on here with the scripts so its hard for me to comment on possible issues..
- ftree
16 May 2022 12:04 - 16 May 2022 12:08 #243078
by ftree
Last edit: 16 May 2022 12:08 by ftree.
- ftree
16 May 2022 14:12 #243082
by ftree
Until I can figure out how to import the right keys from EtherLab repo
github.com/djsftree/rpi-img-builder/comm...ed32642c661b2b26291b
echo "deb [allow-insecure=yes] https://download.opensuse.org/repositories/home:/bone11111:/branches:/science:/EtherLab/Debian_11/ ./" >> /etc/apt/sources.list
apt update --allow-unauthenticated
apt install -y --allow-unauthenticated ethercat-dkms libethercat libethercat-dev ethercat-masterPlease Log in or Create an account to join the conversation.
- ftree
16 May 2022 14:23 - 16 May 2022 14:24 #243083
by ftree
Last edit: 16 May 2022 14:24 by ftree.
- ftree
16 May 2022 15:09 #243084
by ftree
Tested - boots to login ok!
Time to create page: 0.225 seconds
