RPI4 - Debian / LinuxCNC / EtherCAT / XFCE
23 May 2022 11:34 #243604 by rodw
Time for me to reinstall your image.  Its broken :(
My Pi is pretty broken with all the stuff I've built on it. Just have to find some time...
23 May 2022 15:31 - 23 May 2022 15:32 #243620 by ftree
Replied by ftree on topic RPI4 - Debian / LinuxCNC / EtherCAT / XFCE
I have compile deb packages for rpi like so. I pushed the the wheel build var though to debuild with --set-envvar=“VTK_WHEEL_BUILD=ON” as it doesn’t look like Debian enable that salsa.debian.org/science-team/vtk9/-/raw/master/debian/rules
apt install -y chrpath cmake debhelper-compat default-jdk default-libmysqlclient-dev dh-sequence-python3 doxygen-latex \
ghostscript gnuplot-nox graphviz hdf5-tools dh-sequence-javahelper libalglib-dev javahelper libavcodec-dev \
libavformat-dev libavutil-dev libdigest-md5-perl libdouble-conversion-dev libeigen3-dev libexpat-dev \
libfontconfig1-dev libfreetype6-dev libftgl-dev libgdal-dev libgl1-mesa-dev libgl-dev libgl2ps-dev \
libglew-dev libglu1-mesa-dev libglu-dev libhdf5-openmpi-dev libhpdf-dev libjpeg-dev libjs-mathjax \
libjsoncpp-dev liblz4-dev libmrmpi-dev libnetcdf-cxx-legacy-dev libnetcdf-dev libogg-dev libosmesa6-dev \
libpng-dev libpq-dev libproj-dev libsqlite3-dev libswscale-dev libtbb-dev libtheora-dev \
libtiff-dev libutfcpp-dev libx11-dev libxdmf-dev libxml2-dev libxpm-dev libxt-dev lzma mpi-default-dev \
pkg-config python3-dev python3-matplotlib python3-mpi4py qtbase5-dev libqt5opengl5 \
r-base-core r-base-dev r-base xauth xvfb
git clone https://salsa.debian.org/science-team/vtk9.git
cd vtk9
dch -a "compiled by djsftree"
debuild -i -us -uc -b --set-envvar="VTK_WHEEL_BUILD=ON"
/usr/lib/python3 -m pip install wheel
/usr/lib/python3 setup.py bdist_wheel
/usr/lib/python3 -m pip install dist/vtk-*.whl
This at least maintains deb packaging :-)
Last edit: 23 May 2022 15:32 by ftree.
23 May 2022 20:09 - 23 May 2022 20:10 #243637 by ftree
The wheel is in
build/dist
on my pi it is called
vtk-9.1.20220518.dev0-cp310-cp310-linux_aarch64.whl
So tonight I'll be onto installing qtpyvcp
Can you share that whl ?  I'm struggling to get vtk compiled.
Last edit: 23 May 2022 20:10 by ftree.
23 May 2022 20:22 #243639 by rodw
Contact me via my web site  here
www.vmn.com.au/contact
or use the chat
and I'll share my stuff in Google Drive.
24 May 2022 06:57 #243666 by rodw
hmm, unmet build dependencies right near the end
qtdeclarative5-dev tcl-dev tk-dev
01 Jun 2022 15:37 - 01 Jun 2022 15:40 #244380 by ajsinfotech
Replied by ajsinfotech on topic RPI4 - Debian / LinuxCNC / EtherCAT / XFCE
Hi elovalvo
Who/where was this installed?
cd /usr/lib/python3/dist-packages/qtvcp/designer
I mean the qtvcp thing.
Last edit: 01 Jun 2022 15:40 by ajsinfotech.
01 Jun 2022 18:46 #244390 by elovalvo
Replied by elovalvo on topic RPI4 - Debian / LinuxCNC / EtherCAT / XFCE
Qtvcp is installed with Linuxcnc
The LinuxCNC installation procedure creates automatically the structure and related files
01 Jun 2022 19:18 #244396 by ajsinfotech
Ok.
So much compilations and installations got me a little confused, sorry.
Many thanks elovalvo!
11 Dec 2022 14:15 #259192 by hamed
Replied by hamed on topic RPI4 - Debian / LinuxCNC / EtherCAT / XFCE
   hello
   i use your code for installing on rpi
   but i have an error after running this command:
sudo make image board=bcm2711
    the error is this:
Setting up python3-matplotlib (3.5.2-4) ...
Processing triggers for libglib2.0-0:arm64 (2.74.2-1) ...
Processing triggers for libc-bin (2.36-6) ...
Processing triggers for man-db (2.11.1-1) ...
/usr/bin/mandb: can't write to /var/cache/man/82238: No space left on device
/usr/bin/mandb: can't create index cache /var/cache/man/82238: No space left on devic        e
Setting up glib-networking:arm64 (2.74.0-1) ...
Processing triggers for fontconfig (2.13.1-4.5) ...
Setting up libsoup2.4-1:arm64 (2.74.3-1) ...
Setting up gstreamer1.0-plugins-good:arm64 (1.20.3-1+b1) ...
Setting up libsoup-3.0-0:arm64 (3.2.2-1) ...
Setting up libgssdp-1.6-0:arm64 (1.6.2-2) ...
Setting up libgupnp-1.6-0:arm64 (1.6.2-1) ...
Setting up libgupnp-igd-1.0-4:arm64 (1.2.0-3) ...
Setting up libnice10:arm64 (0.1.18-2) ...
Setting up gstreamer1.0-plugins-bad:arm64 (1.20.3-2+b1) ...
+ python3 -m pip install /root/userscripts/vtk-9.1.20220601.dev0-cp310-cp310-linux_aa        rch64.whl
Processing /root/userscripts/vtk-9.1.20220601.dev0-cp310-cp310-linux_aarch64.whl
Installing collected packages: vtk
ERROR: Could not install packages due to an OSError: [Errno 28] No space left on device
make: *** [Makefile:132: image] Error 1
  i have enough space on sd card (64GB)
   but i think your volume that  specified for installing vtk is not enough
  my report of sd card is:
hamed@raspberrypi:~/Downloads/rpi-img-builder-master $  df -Bm
Filesystem     1M-blocks   Used Available Use% Mounted on
/dev/root         59626M 18837M    38311M  33% /
devtmpfs           3745M     0M     3745M   0% /dev
tmpfs              3907M     0M     3907M   0% /dev/shm
tmpfs              1563M     2M     1562M   1% /run
tmpfs                 5M     1M        5M   1% /run/lock
/dev/mmcblk0p1      255M    72M      184M  29% /boot
tmpfs               782M     1M      782M   1% /run/user/1000
/dev/loop1p1       4610M     1M     4356M   1% /home/hamed/Downloads/rpi-img-builder-master/sysroot
/dev/loop2p1        256M    56M      201M  22% /home/hamed/Downloads/rpi-img-builder-master/p1
/dev/loop2p2       7161M  7142M        0M 100% /home/hamed/Downloads/rpi-img-builder-master/p2
at first thanks for your great job
but if you have any point for solving my problem, please help me.
Time to create page: 0.162 seconds
