LinuxCNC on Raspberry Pi 5
2 years 6 months ago - 2 years 6 months ago #298352 by elovalvo
Replied by elovalvo on topic LinuxCNC on Raspberry Pi 5
Hi I have make two linuxcnc on raspberry pi 5 both on a HAT from bot 2 byte page byte2bot.com/products/parallel-port-raspberry-pi-hat and the mill setup is working fine and the other is a lathe setup , the lathe setup is working but I dont understand why I cant get the spindle indexing work in labour ,i dont understand the behavior of that part in the Hal file and why it dont show upp in the Hal test window as working
File Name: My-lathe-KT.zip
File Size:7.28 KB
File Name: My-Mill.zip
File Size:7.37 KB
I hope som helpfull can help me with this matter
Sinserly Krister
You can try with the image for Pi5 (Lcnc292_pi5.img) that you find at this link:
forum.linuxcnc.org/9-installing-linuxcnc...i-5?start=170#295779
Last edit: 2 years 6 months ago by elovalvo.
2 years 6 months ago #298355 by xenon-alien
Raspberry Pi doesn't use grub
Resolution is a issue with this image
You may have to enable sound see
www.raspberrypi.com/documentation/computers/config_txt.html
Is it possible to solve the resolution issue with the rotation?
I have tried the config.txt, but without success... what did i wrong?
2 years 6 months ago #298357 by xenon-alien
How to use this image, to configure it?
Is there a step by step instructions?
There are a lot of Youtube videos, but none helps with this image...
2 years 6 months ago #298358 by Cant do this anymore bye all
You'll have to look around in /boot
Sorry should have mentioned that.
2 years 6 months ago #298360 by xenon-alien
The boot also empty
But at last i can create the config.txt
After reboot no changes...
2 years 6 months ago #298361 by xenon-alien
The BOOT is a different partition with the config.txt and i must to remove the card from the RPi5 and use a card reader. It is not comfortable to make and test the changes...
Before the file was created in the sytems boot folder
So, how can I open this config.txt on the RPi5?
Time to create page: 0.461 seconds
