The BOOT is a different partition with the config.txt and i must to remove the card from the RPi5 and use a card reader. It is not comfortable to make and test the changes...
Before the file was created in the sytems boot folder
So, how can I open this config.txt on the RPi5?
You are right. There is a config.txt file and it looks like the opened one on the PC via card reader.should be in /boot/broadcom/
its just a txt so opening shouldn't be an issue, at least not for me and my installation on pi5
I'm always use sudo to edit files for network, autologin and else.
You can edit the file whilst the system is running only thing is you'll have to open it as superuser....use sudo, if you don't know how to do that just google "sudo". It'll be easier as you'll find something you can understand.
Never, ever runCode:sudo rm -rf / as you'll destroy your system, just in case you see someone recommending doing this.
Any ideas?
How to change the resolution, orientation and make it sound?
