LinuxCNC on Raspberry Pi 5
2 years 8 months ago - 2 years 8 months ago #294184 by Joha
Replied by Joha on topic LinuxCNC on Raspberry Pi 5
Anyone getting errors when using QtPlasmac on the image ( RPI5 image) linked to earlier in this thread?
I have tested to run Linux CNC with one of the "Sim" configs and then it starts, but when i run the wizard and selecting the QtPlasmac GUI then i receive this error when starting linuxCNC based on the config i created during the pncconf wizard:
"[QTvcp.QTVCP.LIB.SYS_NOTIFY][[33mWARNING[0m]  Desktop Notify not available:: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Notifications was not provided by any .service files (sys_notify.py:71)"
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.10.0~pre0
Machine configuration directory is '/home/admin/linuxcnc/configs/my_LinuxCNC_machine'
Machine configuration file is 'my_LinuxCNC_machine.ini'
INIFILE=/home/admin/linuxcnc/configs/my_LinuxCNC_machine/my_LinuxCNC_machine.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
DISPLAY=qtvcp qtplasmac
COORDINATES=XYYZ
KINEMATICS=trivkins coordinates=XYYZ
Starting LinuxCNC...
linuxcncsvr (6484) emcsvr: machine 'my_LinuxCNC_machine'  version '1.1'
milltask (6498) task: machine 'my_LinuxCNC_machine'  version '1.1'
halui (6500) halui: machine 'my_LinuxCNC_machine'  version '1.1'
Found file(REL): ./my_LinuxCNC_machine.hal
Found file(lib): /usr/share/linuxcnc/hallib/qtplasmac_comp.hal
Found file(REL): ./custom.hal
USRMOT: ERROR: command 30 timeout
emcMotionInit: emcTrajInit failed
Starting DISPLAY program: qtvcp
task: main loop took 0.103235 seconds
command (EMC_TASK_PLAN_EXECUTE) cannot be executed until the machine is out of E-stop and turned on
task: main loop took 0.754576 seconds
Running HAL shutdown script
task: 0 cycles, min=0.000013, max=0.754576, avg=-1.000000, 2 latency excursions (> 10x expected cycle time of 0.010000s)
identityKinematicsSetup: coordinates:XYYZ
   Joint 0 ==> Axis X
   Joint 1 ==> Axis Y
   Joint 2 ==> Axis Y
   Joint 3 ==> Axis Z
identityKinematicsSetup: Recommend: kinstype=both
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 10.10.10.10: INFO: Hardware address (MAC): 00:60:1b:16:02:7a
hm2_eth: discovered 7I96
hm2/hm2_7i96.0: Low Level init 0.15
hm2/hm2_7i96.0: Smart Serial Firmware Version 43
hm2/hm2_7i96.0: 51 I/O Pins used:
hm2/hm2_7i96.0:     IO Pin 000 (TB3-01): IOPort
hm2/hm2_7i96.0:     IO Pin 001 (TB3-02): IOPort
hm2/hm2_7i96.0:     IO Pin 002 (TB3-03): IOPort
hm2/hm2_7i96.0:     IO Pin 003 (TB3-04): IOPort
hm2/hm2_7i96.0:     IO Pin 004 (TB3-05): IOPort
hm2/hm2_7i96.0:     IO Pin 005 (TB3-06): IOPort
hm2/hm2_7i96.0:     IO Pin 006 (TB3-07): IOPort
hm2/hm2_7i96.0:     IO Pin 007 (TB3-08): IOPort
hm2/hm2_7i96.0:     IO Pin 008 (TB3-09): IOPort
hm2/hm2_7i96.0:     IO Pin 009 (TB3-10): IOPort
hm2/hm2_7i96.0:     IO Pin 010 (TB3-11): IOPort
hm2/hm2_7i96.0:     IO Pin 011 (TB3-13/TB3-14): SSR #0, pin Out-00 (Output)
hm2/hm2_7i96.0:     IO Pin 012 (TB3-15/TB3-16): SSR #0, pin Out-01 (Output)
hm2/hm2_7i96.0:     IO Pin 013 (TB3-17/TB3-18): SSR #0, pin Out-02 (Output)
hm2/hm2_7i96.0:     IO Pin 014 (TB3-19/TB3-20): SSR #0, pin Out-03 (Output)
hm2/hm2_7i96.0:     IO Pin 015 (TB3-21/TB3-22): SSR #0, pin Out-04 (Output)
hm2/hm2_7i96.0:     IO Pin 016 (TB3-23/TB3-24): SSR #0, pin Out-05 (Output)
hm2/hm2_7i96.0:     IO Pin 017 (TB1-02/TB1-03): StepGen #0, pin Step (Output)
hm2/hm2_7i96.0:     IO Pin 018 (TB1-04/TB1-05): StepGen #0, pin Direction (Output)
hm2/hm2_7i96.0:     IO Pin 019 (TB1-08/TB1-09): StepGen #1, pin Step (Output)
hm2/hm2_7i96.0:     IO Pin 020 (TB1-10/TB1-11): StepGen #1, pin Direction (Output)
hm2/hm2_7i96.0:     IO Pin 021 (TB1-14/TB1-15): StepGen #2, pin Step (Output)
hm2/hm2_7i96.0:     IO Pin 022 (TB1-16/TB1-17): StepGen #2, pin Direction (Output)
hm2/hm2_7i96.0:     IO Pin 023 (TB1-20/TB1-21): StepGen #3, pin Step (Output)
hm2/hm2_7i96.0:     IO Pin 024 (TB1-22-TB1-23): StepGen #3, pin Direction (Output)
hm2/hm2_7i96.0:     IO Pin 025 (TB2-02/TB2-03): StepGen #4, pin Step (Output)
hm2/hm2_7i96.0:     IO Pin 026 (TB2-04/TB2-05): StepGen #4, pin Direction (Output)
hm2/hm2_7i96.0:     IO Pin 027 (TB2-07/TB2-08): Encoder #0, pin A (Input)
hm2/hm2_7i96.0:     IO Pin 028 (TB2-10/TB2-11): Encoder #0, pin B (Input)
hm2/hm2_7i96.0:     IO Pin 029 (TB2-13/TB2-14): Encoder #0, pin Index (Input)
hm2/hm2_7i96.0:     IO Pin 030 (TB2-16/TB2-17): IOPort
hm2/hm2_7i96.0:     IO Pin 031 (TB2-18/TB2-19): IOPort
hm2/hm2_7i96.0:     IO Pin 032 (internal): IOPort
hm2/hm2_7i96.0:     IO Pin 033 (internal): SSR #0, pin AC Ref (internal) (Output)
hm2/hm2_7i96.0:     IO Pin 034 (P1-01/DB25-01): IOPort
hm2/hm2_7i96.0:     IO Pin 035 (P1-02/DB25-14): IOPort
hm2/hm2_7i96.0:     IO Pin 036 (P1-03/DB25-02): IOPort
hm2/hm2_7i96.0:     IO Pin 037 (P1-04/DB25-15): IOPort
hm2/hm2_7i96.0:     IO Pin 038 (P1-05/DB25-03): IOPort
hm2/hm2_7i96.0:     IO Pin 039 (P1-06/DB25-16): IOPort
hm2/hm2_7i96.0:     IO Pin 040 (P1-07/DB25-04): IOPort
hm2/hm2_7i96.0:     IO Pin 041 (P1-08/DB25-17): IOPort
hm2/hm2_7i96.0:     IO Pin 042 (P1-09/DB25-05): IOPort
hm2/hm2_7i96.0:     IO Pin 043 (P1-11/DB25-06): IOPort
hm2/hm2_7i96.0:     IO Pin 044 (P1-13/DB25-07): IOPort
hm2/hm2_7i96.0:     IO Pin 045 (P1-15/DB25-08): IOPort
hm2/hm2_7i96.0:     IO Pin 046 (P1-17/DB25-09): IOPort
hm2/hm2_7i96.0:     IO Pin 047 (P1-19/DB25-10): IOPort
hm2/hm2_7i96.0:     IO Pin 048 (P1-21/DB25-11): IOPort
hm2/hm2_7i96.0:     IO Pin 049 (P1-23/DB25-12): IOPort
hm2/hm2_7i96.0:     IO Pin 050 (P1-25/DB25-13): IOPort
hm2/hm2_7i96.0: registered
hm2_eth: in hm2_eth_reset
hm2_eth: HostMot2 ethernet driver unloaded
hm2: unloading
Debug file information:
Note: Using POSIX realtime
[QTvcp.QTVCP.LIB.AUDIO_PLAYER][[33mWARNING[0m]  audio alerts - Is python3-gst1.0 installed? (audio_player.py:37)
[7550:1:0224/111931.818897:FATAL:page_allocator_internals_posix.h(169)] Check failed: . : Invalid argument (22)
/usr/bin/linuxcnc: line 968:  7417 Segmentation fault      $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS
6488
6498
Stopping realtime threads
Unloading hal components
Info report created by linuxcnc_info:
The file:    /tmp/linuxcnc_info.txt
can be posted to a forum or a web site like:
      pastebin.com
in order to provide information about the linuxcnc
system and configuration.
                Date: Sat 24 Feb 11:20:03 CET 2024
            UTC Date: Sat 24 Feb 10:20:03 UTC 2024
        this program: /usr/bin/linuxcnc_info
              uptime: 11:20:03 up 35 min, 1 user, load average: 11.61, 10.04, 5.41
     lsb_release -sa: Debian Debian GNU/Linux 12 (bookworm) 12 bookworm
            linuxcnc: /usr/bin/linuxcnc
                 pwd: /home/admin/linuxcnc/configs/my_LinuxCNC_machine
                USER: admin
             LOGNAME: admin
                HOME: /home/admin
              EDITOR:
              VISUAL:
            LANGUAGE:
                TERM: dumb
           COLORTERM:
             DISPLAY: :1
             DESKTOP: LXDE-pi-wayfire
/usr/bin/linuxcnc_info: line 133: xdpyinfo: command not found
        display size:
                PATH: /usr/bin:/home/admin/linuxcnc/configs/my_LinuxCNC_machine/bin:/usr/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
uname items:
         nodename -n: pilinuxcnc
      kernel-name -s: Linux
      kernel-vers -v: #1 SMP PREEMPT_RT Thu Dec 7 13:43:31 CET 2023
          machine -m: aarch64
        processor -p: unknown
         platform -i: unknown
      oper system -o: GNU/Linux
/proc items:
             cmdline: coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 smsc95xx.macaddr=2C:CF:67:01:28:6E vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000 console=ttyAMA10,115200 console=tty1 root=PARTUUID=a8df8bc3-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles isolcpus=2,3 max.processor.cstate=1 cfg80211.ieee80211_regdom=SE
          model name:
               cores:
             cpu MHz:
             parport:
              serial:
Versions:
                 gcc: gcc (Debian 12.2.0-14) 12.2.0
              python: Python 3.11.2
                 git: git version 2.39.2
          git commit: NA
                 tcl: 8.6
                  tk: 8.6
               glade: not_in_PATH
linuxcnc_var all:
     LINUXCNCVERSION: 2.10.0~pre0
LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp
LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples
            REALTIME: /usr/lib/linuxcnc/realtime
                 RTS: uspace
          HALLIB_DIR: /usr/share/linuxcnc/hallib
              PYTHON: /usr/bin/python3
dpkg -l '*linuxcnc*':
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name                Version       Architecture Description
un  linuxcnc            <none>        <none>       (no description available)
un  linuxcnc-dev        <none>        <none>       (no description available)
un  linuxcnc-doc        <none>        <none>       (no description available)
un  linuxcnc-doc-en     <none>        <none>       (no description available)
un  linuxcnc-doc-es     <none>        <none>       (no description available)
un  linuxcnc-doc-fr     <none>        <none>       (no description available)
un  linuxcnc-sim        <none>        <none>       (no description available)
un  linuxcnc-sim-dev    <none>        <none>       (no description available)
ii  linuxcnc-uspace     1:2.10.0~pre0 arm64        motion controller for CNC machines and robots
ii  linuxcnc-uspace-dev 1:2.10.0~pre0 arm64        PC based motion controller for real-time Linux
Last edit: 2 years 8 months ago by Joha.
2 years 8 months ago #294224 by cakeslob
Replied by cakeslob on topic LinuxCNC on Raspberry Pi 5
joha , install notification-daemon?
2 years 8 months ago #294229 by Joha
sudo apt install notification-daemon still produces the same error message after installation.
Is any configuration of the notification-daemon needed or should a installation be enough?
What I see is the linuxcnc startup logo and then the same error message is received. Same as before.
2 years 8 months ago #294565 by cakeslob
you probably need to run the daemon before qt, its probably in start menu
2 years 8 months ago #294584 by rodw
Replied by rodw on topic LinuxCNC on Raspberry Pi 5
There is a script mentioned on tthe qtplasmac docs page for installing QT. Maybe find it and give it a try
  • Krister
  • New Member
  • New Member
2 years 7 months ago #295121 by Krister
Replied by Krister on topic LinuxCNC on Raspberry Pi 5
HI i am trying to use rapberry pi 5 and Linuxcnc and i made sucsess with my instalation of 3 axis mill config but when I make a new setup for my lathe I get this mesege .
4652
Can anyone point me in the right direction so I can try to solve this
Regards Krister
Time to create page: 0.408 seconds
