LinuxCNC on Raspberry Pi 5
2 years 7 months ago #295124 by Cant do this anymore bye all
Provide more information, typically the whole debug message. As there is very very little information there.
  • Krister
  • New Member
  • New Member
2 years 7 months ago #295209 by Krister
Replied by Krister on topic LinuxCNC on Raspberry Pi 5
Hi here are the whole error file
  • Krister
  • New Member
  • New Member
2 years 7 months ago #295211 by Krister
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.1
Machine configuration directory is '/home/cnc/linuxcnc/configs/my-svarv'
Machine configuration file is 'my-svarv.ini'
INIFILE=/home/cnc/linuxcnc/configs/my-svarv/my-svarv.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=
DISPLAY=axis
COORDINATES=X Z
KINEMATICS=trivkins coordinates=XZ
Starting LinuxCNC...
CANNOT FIND FILE FOR:Min_svarv.hal
Debug file information:
Note: Using POSIX realtime
1653
Stopping realtime threads
Unloading hal components
2 years 7 months ago #295215 by Cant do this anymore bye all
Cannot find file for:Min_svarv.hal
This file needs to be in the same folder as your ini and main Hal files.
Could be a typo in your ini file.
If you see a line stating it can’t find a file or a pin doesn’t exist that is the error. Mostly it will be a typo somewhere.
  • Krister
  • New Member
  • New Member
2 years 7 months ago #295327 by Krister
Yes its the capital letter syndrom ,I find it
  • Krister
  • New Member
  • New Member
2 years 7 months ago #295329 by Krister
I try to convert a mill setup to a Lathe setup . And now next problem , what is this meaning
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.1
VERSION=1.1
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=
DISPLAY=axis
COORDINATES=X Z
Found file(REL): ./Min_svarv.hal
Found file(REL): ./custom.hal
Starting DISPLAY program: axis
task: 119 cycles, min=0.000009, max=0.015490, avg=0.008914, 0 latency excursions (> 10x expected cycle time of 0.010000s)
note: MAXV max: 6.000 units/sec 360.000 units/min
note: LJOG max: 6.000 units/sec 360.000 units/min
note: LJOG default: 3.000 units/sec 180.000 units/min
note: jog_order='ZX'
note: jog_invert={'X'}
pyvcp_options.hal:11: parameter or pin 'scale.0.gain' not found
3224
3258
Were is the pin 'scale.0.gain to be ?
Time to create page: 0.190 seconds
