- Thank you received: 426
Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
1 year 9 months ago - 1 year 9 months ago #320270
Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!! was created by Cant do this anymore bye all
First lets talk about the images.
1: They are based on Debian repos built by a collection of custom scripts.
2: Whilst some images have been written to SD card via RPi Imager Balena Etcher is recommended.
2a: If you use Linux there are plenty of other tools, Ubuntu\Mint has USB Image writer.
3: If you use the RPi Imager any adding of user or wifi info does not work. As the image is a custom one, only the kernel is built from RPi Sources.
4: If you are using an Rpi5 & a 7c80 0r 7c81 the driver to be loaded is hm2_spix
5: If you are using an RPi4 & a 7c80 or 7c81 the driver to be loaded is hm2_rpsipi
6: The images now have the SPI interface enabled by default.
7: Location of config.txt /boot/broadcom/config.txt once again this is a custom build.
8: raspi-config is not in the image, the tool to use is menuconfig.
9: The default username is cnc.
10: The default password is cnc.
11: The images are not meant to be a fully fledged daily driver Operating System, the are just enough to run Linuxcnc.
Links to images:
www.linuxcnc.org/iso/rpi-5-debian-bookwo...25-01-27-0140.img.xz
www.linuxcnc.org/iso/rpi-5-debian-bookwo...7-0140.img.xz.sha256
www.linuxcnc.org/iso/rpi-4-debian-bookwo...23-11-17-1731.img.xz
www.linuxcnc.org/iso/rpi-4-debian-bookwo...7-0404.img.xz.sha256
Links to images:
Last edit: 1 year 9 months ago by Cant do this anymore bye all.
The following user(s) said Thank You: tommylight, elovalvo, ErwinCNC, MTTI, behai, bananun, Esz2
- Thank you received: 7491
1 year 9 months ago #320273
Replied by tommylight on topic Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
Should we nail it ...hmmm pin it ?
And adding the download link would be good.
Thank you.
Thank you.
The following user(s) said Thank You: Cant do this anymore bye all, behai
1 year 9 months ago #320282
Replied by Cant do this anymore bye all on topic Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
Pinium it
- bananun
1 year 9 months ago #320288
by bananun
Replied by bananun on topic Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
Thank you! Have you tried to install ethercat on these images? I can't get it to work. However on a older image (with older kernel) you have posted it works without issue.
1 year 9 months ago #320290
You know, that's not really helpful at all. Why is it no one wants to give any info that may help others diagnose a problem ? It's like pulling teeth, some kind of demented game.
1 year 8 months ago #320360
Thank you.
Done.Pinium it
Thank you.
