Mesa Configuration Tool
1 year 4 months ago - 1 year 4 months ago #331008 by SebastianM
Replied by SebastianM on topic Mesa Configuration Tool
Another remark.. not sure if that me misunderstanding anything or if its another bug, but witih MesaCT I generated a config to set my outputs 0-7 to sinking and 8-15 to sourcing.
This were the generated lines:
setp hm2_7i76e.0.7i76.0.0.output_sink 0xff00
setp hm2_7i76e.0.7i76.0.0.output_source 0xff
isnt this "the wrong order"? imho this sets 0-7 to source and 8-15 to sink.. right?
Last edit: 1 year 4 months ago by SebastianM.
1 year 4 months ago #331010 by JT
Replied by JT on topic Mesa Configuration Tool
I was generating the bit string backwards which only worked right if all output types were the same. I just fixed that with PCW's help. The inputs and outputs hal has just been fixed as well.
JT
The following user(s) said Thank You: SebastianM
1 year 3 months ago - 1 year 3 months ago #331557 by AirRacer
Replied by AirRacer on topic Mesa Configuration Tool
I’ve just discovered that the Mesa Configuration Tool (at least the version available prior to 8/19/2024) does not configure the manual tool change section correctly.  I recently discovered this when my file did not stop at the M6 command and continued on to the next set of code.  I was able to look at a .hal file set up with pncconfig and copy the manual tool change section from there and now everything works correctly (I get the manual tool change pop up window when the M6 command is encountered). This is a Mill setup that uses the AXIS GUI.
Here are the two configurations:
Pncconfig version that works:
#  ---manual tool change signals---
net tool-change-request    <= iocontrol.0.tool-change
net tool-change-confirmed  => iocontrol.0.tool-changed
net tool-number            <= iocontrol.0.tool-prep-number
#  ---Use external manual tool change dialog---
net tool-change-request    =>  hal_manualtoolchange.change
net tool-change-confirmed  <=  hal_manualtoolchange.changed
net tool-number            =>  hal_manualtoolchange.number
#  ---ignore tool prepare requests---
net tool-prepare-loopback   iocontrol.0.tool-prepare      =>  iocontrol.0.tool-prepared
Mesa Configuration Tool version that doesn’t invoke the manual tool change pop-up or pause the code at M6:
#  Manual Tool Change Dialog
# create signals for tool loading loopback
net tool-prep-loop iocontrol.0.tool-prepare => iocontrol.0.tool-prepared
net tool-change-loop iocontrol.0.tool-change => iocontrol.0.tool-changed
 Regards,
Skylor
Last edit: 1 year 3 months ago by AirRacer.
1 year 3 months ago #331855 by JT
Thanks for the report, this has been fixed.
JT
The following user(s) said Thank You: AirRacer
1 year 3 months ago - 1 year 3 months ago #332056 by ZXT
Replied by ZXT on topic Mesa Configuration Tool
Hello guys! I've just noticed that I/O map for 7i95T from Mesa Configuration tool 2.1.7 is not complete.
The I/O map is missing connector TB5 and TB6 or am i just looking at it wrong?
Or is it because I'll have to configure inputs & outputs under the 7i95t tab to get pin names in my I/O.hal?
Firmware: 7i95t_1pwmd.bin Configuration Name: HOSTMOT2 General configuration information:   BoardName : MESA7I95   FPGA Size: 20 KGates   FPGA Pins: 256   Number of IO Ports: 2   Width of one I/O port: 29   Clock Low frequency: 100.0000 MHz   Clock High frequency: 200.0000 MHz   IDROM Type: 3   Instance Stride 0: 4   Instance Stride 1: 64   Register Stride 0: 256   Register Stride 1: 256 Modules in configuration:   Module: DPLL   There are 1 of DPLL in configuration   Version: 0   Registers: 7   BaseAddress: 7000   ClockFrequency: 100.000 MHz   Register Stride: 256 bytes   Instance Stride: 4 bytes   Module: WatchDog   There are 1 of WatchDog in configuration   Version: 0   Registers: 3   BaseAddress: 0C00   ClockFrequency: 100.000 MHz   Register Stride: 256 bytes   Instance Stride: 4 bytes   Module: IOPort   There are 2 of IOPort in configuration   Version: 0   Registers: 5   BaseAddress: 1000   ClockFrequency: 100.000 MHz   Register Stride: 256 bytes   Instance Stride: 4 bytes   Module: MuxedQCount   There are 6 of MuxedQCount in configuration   Version: 4   Registers: 5   BaseAddress: 3600   ClockFrequency: 100.000 MHz   Register Stride: 256 bytes   Instance Stride: 4 bytes   Module: MuxedQCountSel   There are 1 of MuxedQCountSel in configuration   Version: 0   Registers: 0   BaseAddress: 0000   ClockFrequency: 100.000 MHz   Register Stride: 256 bytes   Instance Stride: 4 bytes   Module: PWM   There are 1 of PWM in configuration   Version: 0   Registers: 5   BaseAddress: 4100   ClockFrequency: 200.000 MHz   Register Stride: 256 bytes   Instance Stride: 4 bytes   Module: SSerial   There are 1 of SSerial in configuration   Version: 0   Registers: 6   BaseAddress: 5B00   ClockFrequency: 100.000 MHz   Register Stride: 256 bytes   Instance Stride: 64 bytes   Module: StepGen   There are 6 of StepGen in configuration   Version: 2   Registers: 10   BaseAddress: 2000   ClockFrequency: 100.000 MHz   Register Stride: 256 bytes   Instance Stride: 4 bytes   Module: SSR   There are 1 of SSR in configuration   Version: 0   Registers: 2   BaseAddress: 7D00   ClockFrequency: 100.000 MHz   Register Stride: 256 bytes   Instance Stride: 4 bytes   Module: InMux   There are 1 of InMux in configuration   Version: 0   Registers: 5   BaseAddress: 8000   ClockFrequency: 100.000 MHz   Register Stride: 256 bytes   Instance Stride: 4 bytes   Module: LED   There are 1 of LED in configuration   Version: 0   Registers: 1   BaseAddress: 0200   ClockFrequency: 100.000 MHz   Register Stride: 256 bytes   Instance Stride: 4 bytes Configuration pin-out: IO Connections for Step/DIR+Serial+Encoders -> 7I95_0 Pin#                  I/O   Pri. func    Sec. func        Chan     Sec. Pin func   Sec. Pin Dir TB3-2,3                 0   IOPort       StepGen          0        Step/Table1     (Out) TB3-4,5                 1   IOPort       StepGen          0        Dir/Table2      (Out) TB3-8,9                 2   IOPort       StepGen          1        Step/Table1     (Out) TB3-10,11               3   IOPort       StepGen          1        Dir/Table2      (Out) TB3-14,15               4   IOPort       StepGen          2        Step/Table1     (Out) TB3-16,17               5   IOPort       StepGen          2        Dir/Table2      (Out) TB3-20,21               6   IOPort       StepGen          3        Step/Table1     (Out) TB3-22,23               7   IOPort       StepGen          3        Dir/Table2      (Out) TB4-2,3                 8   IOPort       StepGen          4        Step/Table1     (Out) TB4-4,5                 9   IOPort       StepGen          4        Dir/Table2      (Out) TB4-8,9                10   IOPort       PWM              0        PWM             (Out) TB4-10,11              11   IOPort       PWM              0        Dir             (Out) TB2-14,15              12   IOPort       SSerial          0        RXData0         (In) TB4-16,17              13   IOPort       SSerial          0        TXData0         (Out) Internal               14   IOPort       SSerial          0        TXEn0           (Out) TB4-20,21              15   IOPort       SSerial          0        RXData1         (In) TB4-22,23              16   IOPort       SSerial          0        TXData1         (Out) Internal               17   IOPort       SSerial          0        TXEn1           (Out) TB1-1,2,9,10           18   IOPort       MuxedQCount      0        MuxQ-A          (In) TB1-4,5,12,13          19   IOPort       MuxedQCount      0        MuxQ-B          (In) TB1-7,8,15,16          20   IOPort       MuxedQCount      0        MuxQ-IDX        (In) TB1-17,18 TB2-1,2      21   IOPort       MuxedQCount      1        MuxQ-A          (In) TB1-20,21 TB2-4,5      22   IOPort       MuxedQCount      1        MuxQ-B          (In) TB1-23,24,TB2-7,8      23   IOPort       MuxedQCount      1        MuxQ-IDX        (In) TB2-9,10,17,18         24   IOPort       MuxedQCount      2        MuxQ-A          (In) TB2-11,12,20,21        25   IOPort       MuxedQCount      2        MuxQ-B          (In) TB2-15,16,23,24        26   IOPort       MuxedQCount      2        MuxQ-IDX        (In) Internal               27   IOPort       MuxedQCountSel   0        MuxSel0         (Out) Internal               28   IOPort       InMux            0        Addr0           (Out) IO Connections for I/O+Expansion -> 7I95_1 Pin#                  I/O   Pri. func    Sec. func        Chan     Sec. Pin func   Sec. Pin Dir Internal               29   IOPort       InMux            0        Addr1           (Out) Internal               30   IOPort       InMux            0        Addr2           (Out) Internal               31   IOPort       InMux            0        Addr3           (Out) Internal               32   IOPort       InMux            0        Addr4           (Out) Internal               33   IOPort       InMux            0        Data0           (In) TB3-13,14              34   IOPort       SSR              0        Out-00          (Out) TB3-15,16              35   IOPort       SSR              0        Out-01          (Out) TB3-17,18              36   IOPort       SSR              0        Out-02          (Out) TB3-19,20              37   IOPort       SSR              0        Out-03          (Out) TB3-21,22              38   IOPort       SSR              0        Out-04          (Out) TB3-23,24              39   IOPort       SSR              0        Out-05          (Out) Internal               40   IOPort       SSR              0        AC Ref          (Out) P1-01/DB25-01          41   IOPort       None            P1-02/DB25-14          42   IOPort       None            P1-03/DB25-02          43   IOPort       None            P1-04/DB25-15          44   IOPort       None            P1-05/DB25-03          45   IOPort       None            P1-06/DB25-16          46   IOPort       None            P1-07/DB25-04          47   IOPort       None            P1-08/DB25-17          48   IOPort       None            P1-09/DB25-05          49   IOPort       None            P1-11/DB25-06          50   IOPort       None            P1-13/DB25-07          51   IOPort       None            P1-15/DB25-08          52   IOPort       None            P1-17/DB25-09          53   IOPort       None            P1-19/DB25-10          54   IOPort       None            P1-21/DB25-11          55   IOPort       None            P1-23/DB25-12          56   IOPort       None            P1-25/DB25-13          57   IOPort       None
Last edit: 1 year 3 months ago by JT. Reason: add code tags
1 year 3 months ago #332062 by JT
It's a mystery to me, that's what the mesaflash command returns
mesaflash --addr 10.10.10.10 --device 7i95t --readhmid
Maybe PCW can shed some light on that?
JT
Time to create page: 0.297 seconds
