Mesa Configuration Tool
1 year 3 months ago - 1 year 3 months ago #332063 by PCW
Replied by PCW on topic Mesa Configuration Tool
The 24 isolated inputs are all controlled by the inmux pins.
I guess they could be named "TB5-1,12, TB6-1,24" rather than "internal"
in mesaflash...
Edit: pushed a change to mesaflash to rename 7I95/7I97/7C80  "internal"
pins to more informative names.
Last edit: 1 year 3 months ago by PCW.
The following user(s) said Thank You: tommylight, JT
1 year 3 months ago #332080 by ZXT
Replied by ZXT on topic Mesa Configuration Tool
Managed to get info by making a test config in MesaCT and then look in I/O.hal
Input 16, TB5
hm2_7i95.0.inmux.00.input-16
1 year 3 months ago #332090 by PCW
You can also get a list of all enabled hardware pins with:
halcmd show all | grep hm2
When LinuxCNC is running.
The following user(s) said Thank You: JT, ZXT
10 months 3 weeks ago #339780 by LearningLinuxCNC
I did not get a working stepper configuration out of MesaCT with a 7i76eu. I have posted the output and my working config here forum.linuxcnc.org/configuration-tools/5...erated-configuration
The output was supposed to be on the 02 stepper but it was connected to the 00 stepper. The feedback loop was not closed and it was not set to be in velocity mode. Look at the two configurations.
10 months 3 weeks ago #339911 by JT
Replied by JT on topic Mesa Configuration Tool
I fixed the missing 7i76eu from the stepper boards variable which caused a partial build of the main.hal file and leaving out the enable and the stepper setp lines.
JT
9 months 4 weeks ago #340927 by 5_Zylinder
Replied by 5_Zylinder on topic Mesa Configuration Tool
Hello,
I installed Debian 13 (Trixie) and the latest Linux CNC 2.9.8 today. Unfortunately, the Mesa Configuration tool won't install.
I get the message: mesact: Depends: phyton3-distro but it is not installable. Perhaps someone could give me an additional tip.
Time to create page: 0.242 seconds
