Ethercat HAL driver
5 years 9 months ago #195639 by JKAVS
Replied by JKAVS on topic Ethercat HAL driver
The problem must be caused by not having edited the MASTER0_DEVICE. I'll try again today.
5 years 9 months ago #195644 by JKAVS
Now it works. I did a clean reinstall and now the lights on the EK1100 show that the bus is working and the LinuxCNC also opens and HAL configuration shows lcec.
What next? Should I get some IO module and connect it to the EK1100 and try whether I can actually do something useful over Ethercat?
About the drivers: Currently there seems to be not that many drivers for stepper and servo drives. Does the .c file of the actual driver contain the same information as the XML file for the generic driver?
5 years 9 months ago #195651 by chimeno
Replied by chimeno on topic Ethercat HAL driver
Hello @CORBETT @JKAVS,
I don't know if all the devices can work with the linuxcnc-ethercat version but most work.
I think that sometimes they get confused about the generic issue, one thing is the network card, which can be generic or specific, it affects somewhat the performance especially if you have many devices but I think that really with the "generic" you have enough for linuxcnc,
the other issue is the generic driver for the device, which if it does not appear in the programmed list, you can use it without knowing how to program in C, quite useful for beginners, although it is a bit difficult to understand at first.
About the automatic installation of GROITUS, I don't know how it works.
the EK1100 device is only an interface, by itself it does nothing.
About the .xml file I have never used it, I always use the device manual and the commands included in
ethercat -h
, for complicated devices I use TWINCAT3
Greeting
Chimeno
The following user(s) said Thank You: CORBETT
5 years 9 months ago #195692 by CORBETT
Replied by CORBETT on topic Ethercat HAL driver
@JKAVS
Ok good deal, glad you got it working... Yes I would get a EL1008 or something simple for input and you can get it figured out. That would be a easy terminal to get going... and you can use it in the future.... wouldn't be wasted.
Glad Chimeno got with you on the "generic" driver as he is verse in it.
Robert
5 years 9 months ago - 5 years 9 months ago #195828 by chimeno
Hello @sqmathlete,
I have gotten the EL5101 with a HONNER 58-11141-3000 encoder, in case you need any help.
Greeting
Chimeno
Last edit: 5 years 9 months ago by chimeno.
5 years 9 months ago #196061 by CORBETT
@JKAVS
I remember you wanting to do a super simple system back a few months ago. I had put this together before the holidays, but got busy and did not put it up... but since you were back on recently wanted to share this idea.
Ok you wanted to keep it super simple with EtherCAT and the big problem was finding ECAT VFD's that are affordable. This is still not super affordable, but gives another avenue. Andy (andypugh) posted in the past about Modbus using USB. Here is the link on the forum from Andy...
forum.linuxcnc.org/10-advanced-configura...-for-vfds-etc#181516
Here is my layout for using a AIO touchscreen computer with ECAT and Modbus.. would tie the limit switches back into the amps, but only show the basic setup.
The following user(s) said Thank You: chimeno
Time to create page: 0.253 seconds
