Ethercat HAL driver
- roschi
- Thank you received: 29
29 Dec 2014 04:49 - 29 Dec 2014 04:50 #54347
by roschi
Replied by roschi on topic Need help about installing linuxcnc-add-hal
my comments are based on the latest commit on github aschiffler
The add-hal-ethercat branch is merged to master.
Homing
- set both velocities (latch, search) in the ini file to zero --> simulation purpose, testing
- set search to zero and latch to 6.6 --> multi turn absolut encoders, position will taken from feedback as it is
- set search to zero and latch to 9.9 --> drive driven homing search motion, started by homing pin, finished by home-sw-in pin, (e.g. make use of wireing for overtravel switches directly to drive)
- set search to != zero and latch != 6.6 or 9.9 --> NC driven homing search motion, remember home-sw-in is active low, movement won't start if axis.N.home-sw-in is 0
Homing
Last edit: 29 Dec 2014 04:50 by roschi.
The following user(s) said Thank You: ccdodo
- ccdodo
29 Dec 2014 15:16 - 29 Dec 2014 15:20 #54357
by ccdodo
Replied by ccdodo on topic Need help about installing linuxcnc-add-hal
Hi Roschi,
Thanks for your help first. The home does move the joints after I modified the signals in hal file.
BUT the home procedure is not like what I expected: After the home button is pressed, two possible results will turn out according to different config:
A The joint moves to the home switch but makes no more move when it reaches the switch, and homing stays True.
B The joint moves to the home switch which is reused as limit switch, sets the current coordinate as HOME_OFFSET, shows the homed sign like BMW, and sent a limit error.
Different combinations of parameters in ini file are test:
home_sw & limit_sw are different | home_sw & limit_sw are the same
HM_OFFSET: 0 0 0 0 | 0 30 30 -30
SEARCH_VEL: 30 30 -30 -30 | 30 30 30 30
LATCH_VEL: -5 5 5 -5 | -5 -5 5 5
IGNORE LIMIT: Y Y Y Y | Y Y Y Y
Result: A A * * | B B B B
*) Homing is aborted manually as homing direction is wrong
The mechanism structure in my machine is like:
X+ [Axis end] joint home-sw limit-sw [Axis end] X-
In condition A, limit-sw is false when it is not touched and it is wired into t input port on EL2521, home-sw is true when it is not touched and it is wired into input port on EL1008.
In condition B, home-sw in A is disabled and limit-sw is reused as home-sw, the input is connected into t-not port in hal file as it has to be the opposite to limit-sw.
The results seem to show that the action used to find the exact position of home after the joint reached the home-sw is invalid.
It really confused me...
Last edit: 29 Dec 2014 15:20 by ccdodo. Reason: some content needs to be modified as spaces are ignored
- roschi
31 Dec 2014 03:39 #54432
by roschi
as I understand your post/problem above you use the "classic" homing sequence state machine. (LinuxCNC commands moves and recognize the switches)
I have modified this to my needs.
I have tested the "classic" homing so far but I can't reply 100% if it is doing all things right. For my config it does. ("classic" and my new variantes to state machine)
Please use the version for homing.c before my edits and look for common help on homing. ( link to correpondinf git hub file homing.c )
I think this is not a special topic which is connected to EtherCAT HAL Driver. Independent if you use the digital I/O via EtherCAT.
Hope that will help
Regards Andreas
Hope that will help
Regards Andreas
- sdfzz
02 Jan 2015 16:41 - 02 Jan 2015 16:43 #54484
by sdfzz
Replied by sdfzz on topic Ethercat HAL driver
First of all, thank you for your contribution.
However, I am having problems installing HAL-driver. I am planning to use LinuxCNC with EtherCAT slaves.
So, I've downloaded and installed LinuxCNC 2.6 LiveCD. Then, following roschi's tutorial, I downloaded EtherLab and "ec-debianize-master.zip".
I put "debian" folder from "ec-debianize-master.zip" inside Etherlab folder and ran the followings in terminal:
cd debian
sudo ./configure -a
However, I get error saying "sudo: ./configure: command not found"
Does anyone knows how to fix this? Any help will be appreciated
Thanks, Steve
cd debian
sudo ./configure -a
Thanks, Steve
Last edit: 02 Jan 2015 16:43 by sdfzz.
- mariusl
02 Jan 2015 17:28 #54486
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic Ethercat HAL driver
Is there a configure script in the directory?
Regards
Marius
www.bluearccnc.com
- sdfzz
02 Jan 2015 18:13 #54488
by sdfzz
Thank you for your reply
There is a configure file inside debian folder. There are 10 files and 2 folders inside debian folder.
- sdfzz
06 Jan 2015 18:13 #54646
by sdfzz
UPDATE:
I've been testing the installation on Ubuntu 12.04 LTS with LinuxCNC 2.6 installed (3.4-9-rtai-686-pae).
I'm stuck at the step where I place "debian" folder inside "ethercat-1.5.2" folder and do configuration and packaging.
1. "debian" folder from ec-debianize-master.zip
--> at "./configure -a"
2. "debian" folder from linuxcnc-add-hal-ethercat.zip
--> at dpkg-buildpackage
cd src && ./autogen.sh
/bin/sh: 1: cd: can't cd to src
make: *** [clean] Error 2
dpkg-buildpackage: error: debian/rules clean gave error exit status 2
3. "debian" folder from linuxcnc-master.zip
4. debian folder in linuxcnc-master/src/hal/drivers/ethercat/master/
--> there is no configure file
it seems quiet strange for case 2 and 3 that the dpkg-buildpackage command asks for src/autogen.sh....the file is in linuxCNC directory, not in etherCAT. It sounds like dpkg-buildpackage command is trying to install LinuxCNC...
If you successed in installing EtherCAT driver for LinuxCNC, would you please let me know of your set up? Like kernel/RTAI version, LinuxCNC version and OS?
I've tried this on LinuxCNC Live CD(Debian) and Ubuntu (12.04 LTS) and both systems failed.
Regards,
Steve
Regards,
Steve
- roschi
07 Jan 2015 20:34 #54709
by roschi
Replied by roschi on topic Ethercat HAL driver
Hi Steve,
So if you have checked all posts and tutorials find in this thread and have no succes. Here are the principal steps:
- Install LinuxCNC from Live CD --> get running OS with RTAI
- Download, Build, Install and test the EtherCAT Master (IgH EtherLAB) --> configure EtherCAT Master (MAC, start on boot time, kernel modul ec_master and e.g. ec_e1000e are loaded)
- Get / Download the source for LinuxCNC with EtherCAT HAL Driver
- Build LinuxCNC; the build process have to know where are the Header files from EtherCAT are stored.
Perhaps see also the Paper from 'narogon' Control de movimientos mediante bus EtherCAT y LinuxCNC were also step by step is presented
Up to now you have to rebuild LinuxCNC from source
In previous discussions in this thread there was the topic about including the EtherCAT driver in official releases. But this is not possible due to license issues.
Perhaps some one on the fourm can give a recommendation on how to proced for deploy adidtional binaries (RT-Modules, Kernel Modulkes) to just use the 'lcec' module in HAL config without recompiling LinuxCNC
Regards Andreas
Regards Andreas
- sdfzz
08 Jan 2015 14:22 #54742
by sdfzz
roschi, thank you for your reply
I tried again with LinuxCNC liveCD with ubuntu 10.04, and the installation was much more smooth
One thing was that when compiling "debian" folder from "ec-debianize-master.zip", I had to set the configure file to be "executable as program" to avoid permission denied problem.
Now I've finished installing linuxCNC
I don't have actual hardware yet, so I guess I will have to wait to test my system.
One question though...how do you configure your system? It's a big question, and there are some good materials in the tutorial file, and it seems to me that the key factor is creating hal and xml files. So, I can create a config from 'stepconf wizard' and modify it so that it works with ethercat devices?
Regards,
Steve
Regards,
Steve
- sdfzz
08 Jan 2015 15:05 #54744
by sdfzz
Sorry...one more question..
when I tried roschi's sameple hal and ini files to load linuxcnc, i got errors:
my-mill.hal:4: execv(lcec_conf): No such file or directory
my-mill.hal:4: lcec_conf exited without becoming ready
This line gives the error: loadusr -W lcec_conf /root/linuxcnc/configs/my-mill/ethercat_config_n.xml
I did place the correct xml file inside my config folder.
I saw from one of the video that you run
/etc/init.d/ethercat start
before you run linuxcnc. However, for my case, there is no ethercat file in /etc/init.d. Is there any mistakes in my installation?
Regards,
Steve
Regards,
Steve
Time to create page: 0.855 seconds
