Ethercat HAL driver
- Thank you received: 4654
02 Feb 2015 17:31 - 02 Feb 2015 17:31 #55575
If the INI really sees this then it will see a latch-velocity of zero.
And this one really is zero.
Try non-zero values for all the velocities.
Replied by andypugh on topic Ethercat HAL driver
Typo?HOME_LATCH_BEL = 3.0
HOME_FINAL_VEL = 0.0
Last edit: 02 Feb 2015 17:31 by andypugh.
- sdfzz
02 Feb 2015 17:43 #55577
by sdfzz
Replied by sdfzz on topic Ethercat HAL driver
Thank you for the reply.. I found the problem.
I used LinuxCNC-add-hal-ethercat distribution from: github.com/aschiffler/linuxcnc/tree/add-hal-ethercat
And line 380 of linuxcnc/src/emc/motion/homing.c is commented out, preventing servos from searching for home.. (github.com/aschiffler/linuxcnc/blob/add-.../emc/motion/homing.c)
Regards,
Steve
Regards,
Steve
02 Feb 2015 17:47 #55578
Oh. No wonder I didn't guess!
- roschi
- Thank you received: 29
03 Feb 2015 04:12 #55600
by roschi
Replied by roschi on topic Ethercat HAL driver
The issue about the homing in the repos
is fixed
The intention to modify the homing source code was about the following cases:
- absolut / multi turn encoder --> HOME_SEARCH_VEL = 0.0 HOME_LATCH_VEL = 6.6; axis is homed at actual position feedback value; no movement
- drive driven homing sequence and switches connected directly to drives --> HOME_SEARCH_VEL = 0.0 HOME_LATCH_VEL = 9.9; NC waits for home-sw-in and assumes movement by the drive it self; axis is homed to position HOME_OFFSET (home-sw-in HAL pin is connected via EtherCAT to corresponding bit in status word of the drive)
- (Standard) NC driven homing sequence --> HOME_SEARCH_VEL != 0.0 HOME_LATCH_VEL != 0.0; NC commands the joint; axis is homed to position HOME_OFFSET
- (Standard) No homing needed / simulation --> HOME_SEARCH_VEL = 0.0 HOME_LATCH_VEL = 0.0
The following user(s) said Thank You: serdigi
03 Feb 2015 22:33 #55648
Magic numbers? Not normally recommended, because somebody might choose those numbers deliberately.
(I suppose that 99999999 and 66666666 would be OK, as nobody will ever home that fast.)
- sdfzz
04 Feb 2015 07:12 #55658
by sdfzz
Roschi,
Thank you for your reply. I was aware of 6.6 and 9.9 settings.... I saw it from your previous comments. I guess it is a way to select the desired homing mode, although without a proper documentation, it may cause confusions.
Also, thank you for the fix.
Regards,
Steve
Regards,
Steve
- sdfzz
04 Feb 2015 07:14 #55659
by sdfzz
Sascha,
I tried your new project. Installation was much easier, and now I can jog and home my axis.
Thank you!
Thank you!
- kyoshiro1108
10 Mar 2015 17:54 #56611
by kyoshiro1108
Replied by kyoshiro1108 on topic Ethercat HAL driver
the first error :Mailbox corrupt received
I've encountered this issue two month ago.
you need to contact the drive manufacturor and update your driver version to 2.0.0
- kyoshiro1108
10 Mar 2015 17:56 #56612
by kyoshiro1108
HI, about the Mailbox corrupt received error
Dear all,
Now I follow this post and Andreas's manual to connect Yaskawa servopack with linuxcnc, everthing goes well until :dmesg message shows:~/linuxcnc-ethercat/linuxcnc$ halrun rtapi:0 stopped msgd:0 stopped halcmd: loadrt threads name1=master period1=1000000 halcmd: loadusr -W lcec_conf ethercat_config_my.xml halcmd: loadrt lcec halcmd: addf lcec.read-all master halcmd: addf lcec.write-all master halcmd: start[705599.272444] EtherCAT 0: Link state of ecm0 changed to UP. [705599.280070] EtherCAT WARNING 0: 1 datagram TIMED OUT! [705599.292077] EtherCAT 0: 1 slave(s) responding on main device. [705599.292087] EtherCAT 0: Slave states on main device: INIT. [705599.292581] EtherCAT 0: Scanning bus. [705599.316499] EtherCAT 0: Bus scanning completed in 24 ms. [705599.316509] EtherCAT 0: Using slave 0 as DC reference clock. [705599.320410] EtherCAT 0: Slave states on main device: PREOP.[color=#ff0000] [705602.382934] EtherCAT ERROR 0-0: Corrupt mailbox response received![/color] [705602.382945] EtherCAT DEBUG: 7E 00 01 00 00 63 00 80 04 00 00 00 01 10 05 00 [705602.382965] EtherCAT DEBUG: 00 07 45 72 72 6F 72 20 52 65 67 69 73 74 65 72 [705602.382983] EtherCAT DEBUG: 65 60 9A 60 B1 60 B2 60 B8 60 B9 60 BA 60 BC 60 [705602.383001] EtherCAT DEBUG: C1 60 C2 60 E0 60 E1 60 F4 60 FC 60 FD 60 FE 60 [705602.383019] EtherCAT DEBUG: FF 60 02 65 03 27 10 27 20 27 E0 27 3F 60 40 60 [705602.383037] EtherCAT DEBUG: 41 60 5A 60 5B 60 5C 60 5D 60 5E 60 60 60 61 60 [705602.383055] EtherCAT DEBUG: 62 60 63 60 64 60 65 60 66 60 67 60 68 60 6B 60 [705602.383073] EtherCAT DEBUG: 6C 60 6D 60 6E 60 71 60 72 60 74 60 76 60 77 60 [705670.466102] EtherCAT: Requesting master 0... [705670.466114] EtherCAT: Successfully requested master 0. [705670.466230] EtherCAT 0: Domain0: Logical address 0x00000000, 6 byte, expected working counter 1. [705670.466236] EtherCAT 0: Datagram domain0-0-main: Logical offset 0x00000000, 6 byte, type LWR. [705670.466290] EtherCAT 0: Master thread exited. [705670.466297] EtherCAT 0: Starting EtherCAT-OP thread. [705670.467927] EtherCAT WARNING 0: 1 datagram TIMED OUT! [705715.024606] EtherCAT WARNING: Datagram f1fadf0c (domain0-0-main) was SKIPPED 1 time. [705715.464737] EtherCAT WARNING 0: 3 datagrams UNMATCHED! [705716.183720] EtherCAT WARNING 0-0: Slave did not sync after 5000 ms. [705716.190654] EtherCAT 0: Domain 0: Working counter changed to 1/1. [705716.312261] EtherCAT 0: Slave states on main device: OP. [705716.349656] EtherCAT ERROR 0-0: AL status message 0x001A: "Synchronization error". [705716.353660] EtherCAT 0-0: Acknowledged state SAFEOP. [705716.464063] EtherCAT WARNING 0: 6 datagrams UNMATCHED! [705717.032627] EtherCAT WARNING: Datagram f1fadf0c (domain0-0-main) was SKIPPED 5 times. [705717.192606] EtherCAT 0: Domain 0: 3 working counter changes - now 0/1. [705717.464687] EtherCAT WARNING 0: 18 datagrams UNMATCHED! [705718.036643] EtherCAT WARNING: Datagram f1fadf0c (domain0-0-main) was SKIPPED 3 times. [705719.040649] EtherCAT WARNING: Datagram f1fadf0c (domain0-0-main) was SKIPPED 1 time. [705719.464082] EtherCAT WARNING 0: 3 datagrams UNMATCHED! [705721.492751] EtherCAT WARNING 0-0: Slave did not sync after 5000 ms. [705721.499648] EtherCAT 0: Domain 0: Working counter changed to 1/1. [705722.885394] EtherCAT 0: Domain 0: Working counter changed to 0/1. [705723.056714] EtherCAT WARNING: Datagram f1fadf0c (domain0-0-main) was SKIPPED 1 time. [705723.464068] EtherCAT WARNING 0: 3 datagrams UNMATCHED! [705723.888711] EtherCAT 0: Domain 0: Working counter changed to 1/1. [705726.893333] EtherCAT 0: Domain 0: Working counter changed to 0/1. [705726.901697] EtherCAT ERROR 0-0: AL status message 0x001A: "Synchronization error". [705726.904702] EtherCAT 0-0: Acknowledged state SAFEOP. [705727.072708] EtherCAT WARNING: Datagram f1fadf0c (domain0-0-main) was SKIPPED 1 time. [705727.464031] EtherCAT WARNING 0: 3 datagrams UNMATCHED! [705727.896710] EtherCAT 0: Domain 0: 2 working counter changes - now 0/1. [705731.088737] EtherCAT WARNING: Datagram f1fadf0c (domain0-0-main) was SKIPPED 1 time. [705731.464045] EtherCAT WARNING 0: 3 datagrams UNMATCHED !
There are two error as I analyzed, first of all [705602.382934] EtherCAT ERROR 0-0: Corrupt mailbox response received, Is it means there is something wrong with slave?
Second, there is sychronization error, what does it mean? I have to set slave as reference DC clock? DC cycle time is how much? please refer to ethercat_config_my.xml. I am trying to figure it out refer to William post and Ivan 's post ,since
Enable notLRW:yes shows by ethercat slave -v
I am appreciated anyone can give any solution I also will post it to etherlab mailing list.
Thanks!
- kyoshiro1108
30 Mar 2015 19:16 #57314
by kyoshiro1108
I also meet this problem when I install hal on another computer.
Can u tell me how to solve it ?
Thank U.
Sorry...one more question..
when I tried roschi's sameple hal and ini files to load linuxcnc, i got errors:
my-mill.hal:4: execv(lcec_conf): No such file or directory
my-mill.hal:4: lcec_conf exited without becoming ready
This line gives the error: loadusr -W lcec_conf /root/linuxcnc/configs/my-mill/ethercat_config_n.xml
I did place the correct xml file inside my config folder.
I saw from one of the video that you run
/etc/init.d/ethercat start
before you run linuxcnc. However, for my case, there is no ethercat file in /etc/init.d. Is there any mistakes in my installation?
Regards,
Steve
Thank U.
Time to create page: 0.249 seconds
