Ethercat HAL driver
24 Sep 2015 12:29 #62936 by cgc
Replied by cgc on topic Ethercat HAL driver
This servo controller has a Ethercat interface. Why do you not use this?
24 Sep 2015 21:44 - 24 Sep 2015 21:57 #62945 by CNCDestroyer
Replied by CNCDestroyer on topic Ethercat HAL driver
Hey guys,
the slaves are shown in terminal.
ethercat@Ethercat:~$ ethercat slaves
0  0:0  PREOP  +  EK1100 EtherCAT-Koppler (2A E-Bus)
1  0:1  PREOP  +  EL1018 8K. Dig. Eingang 24V, 10�s
2  0:2  PREOP  +  EL2008 8K. Dig. Ausgang 24V, 0.5A
i cant start the example.
I searched for a solution but i found nothing in the web.
i want to test the i/o for a new solution for my milling machine. don't now how without example.
Warning: Spoiler!
Thanks for helping =)
Last edit: 24 Sep 2015 21:57 by CNCDestroyer.
26 Sep 2015 19:21 #63021 by boyzo
Replied by boyzo on topic Ethercat HAL driver
Problem: lcec: disagrees about version of symbol hal_param_float_newf
Hello,
I installed LinuxCNC fresh from LiveCD 2.7. Then I installed ethercat as from wiki.linuxcnc.org/cgi-bin/wiki.pl?EtherCatDriver
I connect Beckhoff devices and issue comand:
ethercat slaves
0 7:0 PREOP + EK1100 EtherCAT-Koppler (2A E-Bus)
1 7:1 PREOP + EL2008 8K. Dig. Ausgang 24V, 0.5A
2 7:2 PREOP + EL1008 8Ch. Dig. Input 24V, 3ms
I created test-conf.xml:
<masters>
<master idx="0" appTimePeriod="1000000" refClockSyncCycles="1000">
<slave idx="0" type="EK1100" />
<slave idx="1" type="EL2008" />
<slave idx="2" type="EL1008" />
</master>
</masters>
and created test.hal:
loadrt trivkins
loadrt motmod servo_period_nsec=1000000 num_joints=3
loadusr -W lcec_conf test-conf.xml
loadrt lcec
then I issue: halrun test.hal:
Error: could not insert module /usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/lcec.ko: Invalid parameters
test.hal:20: exit value: 1
test.hal:20: insmod for lcec failed, returned -1
See the output of 'dmesg' for more information.
relevant dmseg output (before all is OK):
[15258.829139] RTAI[math]: loaded.
[15258.987667] lcec: disagrees about version of symbol hal_param_float_newf
[15258.987678] lcec: Unknown symbol hal_param_float_newf (err -22)
[15258.987689] lcec: disagrees about version of symbol hal_pin_u32_newf
[15258.987694] lcec: Unknown symbol hal_pin_u32_newf (err -22)
[15258.987769] lcec: disagrees about version of symbol hal_param_bit_newf
[15258.987775] lcec: Unknown symbol hal_param_bit_newf (err -22)
[15258.987809] lcec: disagrees about version of symbol hal_param_s32_newf
[15258.987815] lcec: Unknown symbol hal_param_s32_newf (err -22)
[15258.987854] lcec: disagrees about version of symbol hal_pin_s32_newf
[15258.987860] lcec: Unknown symbol hal_pin_s32_newf (err -22)
[15258.987917] lcec: disagrees about version of symbol hal_pin_bit_newf
[15258.987923] lcec: Unknown symbol hal_pin_bit_newf (err -22)
[15258.988121] lcec: disagrees about version of symbol hal_param_u32_newf
[15258.988127] lcec: Unknown symbol hal_param_u32_newf (err -22)
[15259.125902] RTAI[math]: unloaded.
Anybody any suggestion?
Thanks for help
28 Sep 2015 00:07 #63073 by cgc
Please post your ini, hal and xml complete
regards Frank
28 Sep 2015 01:33 #63080 by boyzo
I do not have .ini, xml and hal is complete in my original post. I minimize this for the first test, before I go complex.
What I think is that I should work with linuxcnc 2.6, not 2.7. I did fresh install 2.6, but now I can not install ethercat as it seems package repository is down. I get 502 Bad Gateway error.
Regards Bojan
28 Sep 2015 16:26 #63117 by cgc
it is running with 2.7,
you need this in your hal-file: (with complete path to the xml !!)
loadusr -W lcec_conf /home/fb/linuxcnc/configs/ethercat/ethercat-conf.xml
loadrt lcec
loadrt trivkins
loadrt motmode base_period_nsec=0 servo_period_nsec=1000000 num_joints=3
addf lcec.read-all servo-thread
addf lcec.write-all servo-thread
I think, the xml is ok
The following user(s) said Thank You: Nico2017
28 Sep 2015 17:13 #63122 by boyzo
I have my test-conf.xml in my current directory so I do not need path to xml.
I can not test as I do not have 2.7 anymore, and I can not install in 2.6 as I get 502 Bad Gateway error on package repository. Do you think addf would make the difference?
28 Sep 2015 18:38 #63132 by boyzo
Solved.
Package repository is back. I install ethercat on 2.6 and I do not get any errors. It seems the driver is not compatible with 2.7.
28 Sep 2015 18:40 #63134 by andypugh
Replied by andypugh on topic Ethercat HAL driver
That seems strange. I can't off-hand think of anything which would have changed to affect that.
28 Sep 2015 19:55 #63138 by cgc
You're right, I have the same errors with 2.7 :-(
regards Frank
Time to create page: 0.369 seconds
