Ethercat HAL driver
11 years 1 month ago #63140
Replied by andypugh on topic Ethercat HAL driver
This looks like lcec needs to be re-compiled with the 2.7 headers.
- boyzo
- Thank you received: 3
11 years 1 month ago #63150
by boyzo
Replied by boyzo on topic Ethercat HAL driver
I will stay with 2.6 until driver will be available for 2.7.
I know I can do it by myself, but I need to load all headers and setup dev. environment.
Maybe Sascha will be able to do it.
- boyzo
11 years 4 weeks ago #63336
by boyzo
Hello Frank,
I tested Beckhoff Ethercat. It works fine and I plan to continue with EM7004 as you suggested( I will get one for test this days). Do you have any hal configuration for driving axis with EM7004?
Thank you.
Regards Bojan
cgc wrote: This servo controller has a Ethercat interface. Why do you not use this?
Hello Frank,
Thank you.
Regards Bojan
- cgc
- Thank you received: 10
11 years 4 weeks ago #63340
by cgc
Replied by cgc on topic Ethercat HAL driver
Hello Bojan,
I have not test this before, but it is in the modul list, i think, it is not complicate.
Maybe this:
<masters>
<master idx="0" appTimePeriod="1000000" refClockSyncCycles="1000">
<slave idx="0" type="EM7004" />
</master>
</masters>
Regards Frank
Maybe this:
<masters>
</master>
</masters>
Regards Frank
- boyzo
10 years 11 months ago #65837
by boyzo
Hello,
I saw Sascha post "fixed debien dependencies for linuxcnc 2.7 userspace version" in its git repository.
How can I install this fix on installed ethercat driver on 2.7 linuxcnc?
Regards
Regards
- cgc
10 years 11 months ago - 10 years 11 months ago #65861
by cgc
Install linuxcnc-dev before
Download the source with : git clone ....
change to the directory: linuxcnc-ethercat
delete old installation: make clean
compile the source with: sudo make install
regards Frank
regards Frank
Last edit: 10 years 11 months ago by cgc.
Time to create page: 0.344 seconds
