Ethercat HAL driver
- DaPeace
03 Dec 2015 10:37 #66275
by DaPeace
Replied by DaPeace on topic Ethercat HAL driver
Hey Guys, short question: Im playing around with Ethercat-Components at the moment.
I want to get rid of the LPT-Interface of my mill and drive the stepper with EL2024 Output-Clamps and some Buttons with EL1008.
Ive put all together and i see the devices when i run ethercat slaves
I use the generic-driver. I tried an old macbook and a virtual machine on a newer macbook with linuxcnc 2.6 and 2.7. I can list all clamps here too but when i start linuxcnc the complete system hangs and i need to reset the pc.
Do i need one of that intel-nic's or is the generic driver ok for that kind of application?
Is it possible to use the output-clamps for driving step and directions signals at all?
Regards, Jan
Regards, Jan
- Thank you received: 4654
03 Dec 2015 16:29 #66289
Replied by andypugh on topic Ethercat HAL driver
I would be very surprised if a VM could drive the ethernet port in real-time.
Also, the real-time kernel in a VM will not be real-time.
As it sounds like you have two Macbooks, I suggest converting one to "real" Linux (assuming it is Intel)
- DaPeace
04 Dec 2015 05:44 #66356
by DaPeace
Ive used the vmware-macbook just for testing and configuring because the place around the machine is not enough to set it up at the machine-computer. BUT one macbook drives a vm and the other macbook runs linuxcnc nativly.
Both have the same problem. Both use the generic-driver and none of them hast a intel-networkcard.
So you think i will need one of the intel or realtek-cards to use that beckhoff-stuff?
- narogon
- Thank you received: 14
04 Dec 2015 14:08 - 04 Dec 2015 14:09 #66380
by narogon
Why don't you try to configure the ethercat HAL component from HAL console (executing halrun) before try it with linuxcnc?.
Create a .hal file with
You can load the file doing halrun -I halfile.hal and check some values with halscope or halmeter
Best regards.
Replied by narogon on topic Ethercat HAL driver
Regards, Jan
loadusr -W lcec_conf yourXMLfile
loadrt lcec
loadrt trivkins
loadrt motmod base_period_nsec=0 servo_period_nsec=1000000 num_joints=1
addf lcec.read-all servo-thread
addf lcec.write-all servo-thread
startYou can load the file doing halrun -I halfile.hal and check some values with halscope or halmeter
Best regards.
Last edit: 04 Dec 2015 14:09 by narogon.
- DaPeace
04 Dec 2015 15:42 - 04 Dec 2015 15:52 #66389
by DaPeace
Ive now tried that out. Ive used the macbook with native linuxcnc 2.6 and the millingcomputer with 2.7 and i get a kernelpanic on both devices. i can start axis for example with very basic hal-file or i can run halrun and after a while i get that kernalpanic. when its not crashing right after start i can open hal-overview and i can trigger the inputs and see that they are reacting. but after max. 2mins i get that kernel panic.
Following Crashlog i get:
Crashlog
When i put your code into a basic-halfile and start it i get a kernelpanic instantly.
At the end of the trace it says Code: Bad EIP value.
Crashlog
Last edit: 04 Dec 2015 15:52 by DaPeace.
- wazjebk
- Thank you received: 3
05 Dec 2015 12:00 #66449
by wazjebk
Replied by wazjebk on topic Ethercat HAL driver
Dear all,
I have the same issue on D525MW motherboard with integrated network card and generic driver. I already try to put inside some other PCI card but I have still same issue as Dapeace - above.
Best regards.
Best regards.
- DaPeace
05 Dec 2015 15:12 #66456
by DaPeace
Did you try one of the intel-cards and use the e100 or e1000-driver or did you only try another card with generic-driver? I think about getting a intel-card and try out again.
- wazjebk
05 Dec 2015 16:02 #66460
by wazjebk
I just try another card with generic driver.
Best regards.
Best regards.
- DaPeace
05 Dec 2015 16:32 #66465
by DaPeace
Ok so there is a chance a intelcard could fix that.. i will try to get one on monday and report here if it works..
if someone has another solutions for that it would be very nice to know
- wazjebk
06 Dec 2015 15:58 #66510
by wazjebk
Hi again,
today I once again try pci network card Tenda L8139D together with 8139too driver and system works without crashing now for more than 4 hours. I think that generic driver was not suitable for non of the cards.
Best regards.
Best regards.
The following user(s) said Thank You: Nico2017
Time to create page: 0.376 seconds
