Ethercat HAL driver
31 Mar 2015 06:12 #57326 by sdfzz
Replied by sdfzz on topic Ethercat HAL driver
Hi, kyoshiro1108,
Would you please try typing "sudo ethercat start" on your terminal before running LinuxCNC?
Regards,
Steve
31 Mar 2015 12:34 #57341 by kyoshiro1108
Replied by kyoshiro1108 on topic Ethercat HAL driver
Hi, kyoshiro1108,
Regards,
Steve
The ethercat run on background when I boot up the computer.
so that I can execute ethercat slaves and ethercat master command.
but the problem still exist....
01 Apr 2015 13:47 #57363 by kyoshiro1108
I used the other command
$./configure --enable-simulator
to build linuxcnc and the error is .....
$ cd linuxcnc-add-hal-ethercat/
$ . scripts/rip-environment
$ halrun
halcmd: loadrt threads name1=master period1=1000000
halcmd: loadusr -W lcec_conf /home/oslab/Desktop/ethercat_config_my.xml
halcmd: loadrt lcec
lcec: dlopen: /home/oslab/linuxcnc-add-hal-ethercat/rtlib/lcec.so: cannot open shared object file: No such file or directory
<stdin>:3: /home/oslab/linuxcnc-add-hal-ethercat/bin/rtapi_app exited without becoming ready
<stdin>:3: insmod failed, returned -1
03 May 2015 07:19 #58343 by euerka
Replied by euerka on topic Ethercat HAL driver
I start to try Sittner new repository <github.com/sittner/linuxcnc-ethercat> , and make, make install.
Everything goes well until I try to load my configure xml, there are errors as follow:
halcmd: loadusr -W lcec_conf ethercat_config_my.xml
lcec_conf: ERROR: unexpected node master found
lcec_conf: ERROR: Parse error at line 1: parsing aborted
<stdin>:4: lcec_conf exited without becoming ready
My configure file as below:
<master idx="0" appTimePeriod="1000000" refClockSyncCycles="1">
<slave idx="0" type="generic" vid="00000539" pid="02200001" configPdos="true">
<syncManager idx="0" dir="out"/>
<syncManager idx="1" dir="in"/>
<syncManager idx="2" dir="out">
	<pdo idx="1602">
	<pdoEntry idx="6040" subIdx="00" bitLen="16" halPin="drivecontrol" halType="bit"/>
	<pdoEntry idx="60FF" subIdx="00" bitLen="32" halPin="velocity" halType="s32"/>
	</pdo>
</syncManager>
<syncManager idx="3" dir="in">
	<pdo idx="1A02">
	<pdoEntry idx="6041" subIdx="00" bitLen="16" halPin="drivestatus" halType="bit"/>
	<pdoEntry idx="6064" subIdx="00" bitLen="32" halPin="pos" halType="S32"/>
	</pdo>
</syncManager>
<dcConf assignActivate="300" sync0Cycle="*1" sync0Shift="0"/>
<sdoConfig idx="6060" subIdx="0">
	<sdoDataRaw data="08"/>
</sdoConfig
><sdoConfig idx="60C2" subIdx="1">
	<sdoDataRaw data="01"/>
</sdoConfig>
<sdoConfig idx="60C2" subIdx="2">
	<sdoDataRaw data="FD"/>
</sdoConfig>
</slave>
</master>
I think my configure file format should be OK, because I use it before. May I know how to test this new respository works ?
I already start ethercat,
ethercat master
or
ethercat slave -v
show normal.
By the way
sdfzz wrote:
Sorry...one more question..
when I tried roschi's sameple hal and ini files to load linuxcnc, i got errors:
my-mill.hal:4: execv(lcec_conf): No such file or directory
my-mill.hal:4: lcec_conf exited without becoming ready
This line gives the error: loadusr -W lcec_conf /root/linuxcnc/configs/my-mill/ethercat_config_n.xml
I did place the correct xml file inside my config folder.
I saw from one of the video that you run
/etc/init.d/ethercat start
before you run linuxcnc. However, for my case, there is no ethercat file in /etc/init.d. Is there any mistakes in my installation?
Regards,
Steve
I also meet this problem when I install hal on another computer.
Can u tell me how to solve it ?
Thank U.
After you install etherlab, the default directory will be /opt/etherlab
you can use soft link
sudo ln -s /opt/etherlab/etc/init.d/ethercat /etc/init.d/ethercat
Then you can start ethercat by
Hope it helps.
-Chengxi
03 May 2015 08:43 #58345 by euerka
I got the answer after I read the source code.
add
<masters>
</master>
in configure file to support multi-master.
19 May 2015 03:56 #58833 by pavel7890
Replied by pavel7890 on topic Ethercat HAL driver
I finally started to work out my indradrive ethercat project. I acquired Wasino gang lathe and want to use 2 axis servo and main spindle, all controlled by ethercat.
I started with main spindle. So far so good :) Just a bit playing with correct soft start/stop spindle procedure.
I guess I found a bug in sittners lcec_conf.c for scale and offset. Since I do not have any experience with git contribution i put it here:
// parse scale
if (strcmp(name, "scale") == 0) {
floatReq = 1;
p->floatScale = atof(val);
continue;
// parse offset
if (strcmp(name, "offset") == 0) {
floatReq = 1;
p->floatOffset = atof(val);
continue;
There was not continue; so it just parsed scale parameter with error.
Hope it helps.
20 May 2015 17:21 #58889 by sascha
Replied by sascha on topic Ethercat HAL driver
You are right, thank you.
I've took it into master: github.com/sittner/linuxcnc-ethercat/com...7da79e3406d6d881dc8b
26 May 2015 13:17 #59059 by bkt
Replied by bkt on topic Ethercat HAL driver
sorry at all .... I have not experience with ethercat ..... and i read some specification on linuxcnc doc ethercat, I have a doubt: How many drives can be connected to LinuxCNC with EtherCAT with safe/robust operation ?
06 Jun 2015 19:02 #59516 by a60081
Replied by a60081 on topic Ethercat HAL driver
I want to create two domain for pdos because the motor i used is required one domain(1600) for transfer, and another one for receive(1A00).
If only one domain, it will be synchronize error.
How could i edit it in lcec.c?
08 Jun 2015 23:11 - 08 Jun 2015 23:12 #59628 by narogon
Replied by narogon on topic Ethercat HAL driver
Check tutorial
step 9 parameter 4.
I think you mean sync managers when you say domains.
Last edit: 08 Jun 2015 23:12 by narogon.
The following user(s) said Thank You: a60081, Nico2017
Time to create page: 0.379 seconds
