Ethercat HAL driver
- euerka
11 years 9 months ago #55419
by euerka
Understand, Thanks for your explaination.
Yes, I tried it. It works well with Twincat, I can rotate the motor. Maybe I have to come back and try again, because I just tried it, never figure out how does it work and how to write .xml files.
I am not clear out this, I will read .xml from vendor creafully and to see how.
-chengxi
Replied by euerka on topic Ethercat HAL driver
narogon wrote: Two DC lines have no sense for me, the parser is going to read one and overwrite the info in the second line.
narogon wrote: In any case have you tried to connect and get the OP mode using TwinCAT from Beckhoff? It helps me a lot to understand what was happening and how to write the .xml files.
narogon wrote: Other possible error is that you are using fixed pdo configuration 1602 but you don't specify to the slave configuring parameter with sdoconfig
-chengxi
- narogon
- Thank you received: 14
11 years 9 months ago #55421
by narogon
I've read quickly the manual of your servo, check 0x1c12 and 0x1c13 entries. I think you must configure them before sync mode using sdo.
Sorry I'm from my phone and can't describe it better.
Replied by narogon on topic Ethercat HAL driver
-chengxi
- sascha
- Thank you received: 29
11 years 9 months ago #55424
by sascha
Replied by sascha on topic Ethercat HAL driver
Dear all,
to be able to better coordinate future development and for easier setup I've decided to build up a separate project for the Ethercat HAL driver stuff. Please find the new repos (including new devices, functions and bugfixes) here:
github.com/sittner/linuxcnc-ethercat
So, if you have new functions, device drivers or fixes please feel free to fork and send me pull requests.
I also have set up a simple Debian repos (currently without keys) which is intended to be used with the current LinuxCNC Debian Wheezy based dist. This way installation should be very easy:
After installation you will find some examples in /usr/share/linuxcnc-ethercat/examples.
Have Fun & Kind Regards
Sascha
- create a file "/etc/apt/sources.list.d/linuxcnc-mds.list":
Code:deb http://repo.modusoft.de/linuxcnc/wheezy ./
- # sudo apt-get update
- # sudo apt-get install linuxcnc-ethercat
The etherlabmaster should be installed automaticaly.
Currently you will get a warning about missing key. - edit /etc/default/ethercat to match your setup
- # sudo update-ethercat-config
- reboot
- # ethercat slaves
this sould show your connected slaves - start working with Ethercat enabled LinuxCNC
Sascha
The following user(s) said Thank You: cgc, narogon, Allan, sqmathlete, Nico2017
- sdfzz
11 years 8 months ago #55572
by sdfzz
Replied by sdfzz on topic Ethercat HAL driver
Dear all,
Thanks to all your help, now I can jog 3 servos using Omron G5 servo drivers. However, when I hit "home all" button, nothing happens...
- I've connected "axis.N.home-sw-in" to a homing switch, and it seems working fine
- in my ini file, under axis, I added:
HOME = 0.0
HOME_DELAY = 1.0
HOME_OFFSET = 0.0
HOME_SEARCH_VEL = 3.0
HOME_LATCH_BEL = 3.0
HOME_FINAL_VEL = 0.0
HOME_USE_INDEX = NO
HOME_IGNORE_LIMITS=NO
HOME_SEQUENCE = 0
- when I press the home switch, linuxcnc says homing is completed (although the servo did not move at all)
- I did not connect velocity command pins (axis.N.joint-vel-cmd)....would this cause a problem in homing? I can jog all right using position command..
Does anyone encountered a similar issue?
Best regards,
Steve
HOME = 0.0
HOME_DELAY = 1.0
HOME_OFFSET = 0.0
HOME_USE_INDEX = NO
HOME_SEQUENCE = 0
Best regards,
Steve
11 years 8 months ago - 11 years 8 months ago #55575
If the INI really sees this then it will see a latch-velocity of zero.
And this one really is zero.
Try non-zero values for all the velocities.
Replied by andypugh on topic Ethercat HAL driver
Typo?sdfzz wrote: HOME_LATCH_BEL = 3.0
Last edit: 11 years 8 months ago by andypugh.
- sdfzz
11 years 8 months ago #55577
by sdfzz
Thank you for the reply.. I found the problem.
I used LinuxCNC-add-hal-ethercat distribution from: github.com/aschiffler/linuxcnc/tree/add-hal-ethercat
And line 380 of linuxcnc/src/emc/motion/homing.c is commented out, preventing servos from searching for home.. ( github.com/aschiffler/linuxcnc/blob/add-.../emc/motion/homing.c )
Regards,
Steve
Regards,
Steve
Time to create page: 0.663 seconds
