Ethercat HAL driver
11 years 8 months ago #55578
Oh. No wonder I didn't guess!
Replied by andypugh on topic Ethercat HAL driver
sdfzz wrote: And line 380 of linuxcnc/src/emc/motion/homing.c is commented out,
- roschi
- Thank you received: 29
11 years 8 months ago #55600
by roschi
Replied by roschi on topic Ethercat HAL driver
The issue about the homing in the repos
github.com/aschiffler/linuxcnc
is fixed
The intention to modify the homing source code was about the following cases:
- absolut / multi turn encoder --> HOME_SEARCH_VEL = 0.0 HOME_LATCH_VEL = 6.6; axis is homed at actual position feedback value; no movement
- drive driven homing sequence and switches connected directly to drives --> HOME_SEARCH_VEL = 0.0 HOME_LATCH_VEL = 9.9; NC waits for home-sw-in and assumes movement by the drive it self; axis is homed to position HOME_OFFSET (home-sw-in HAL pin is connected via EtherCAT to corresponding bit in status word of the drive)
- (Standard) NC driven homing sequence --> HOME_SEARCH_VEL != 0.0 HOME_LATCH_VEL != 0.0; NC commands the joint; axis is homed to position HOME_OFFSET
- (Standard) No homing needed / simulation --> HOME_SEARCH_VEL = 0.0 HOME_LATCH_VEL = 0.0
The following user(s) said Thank You: serdigi
11 years 8 months ago #55648
Magic numbers? Not normally recommended, because somebody might choose those numbers deliberately.
(I suppose that 99999999 and 66666666 would be OK, as nobody will ever home that fast.)
roschi wrote: - absolut / multi turn encoder --> HOME_SEARCH_VEL = 0.0 HOME_LATCH_VEL = 6.6; axis is homed at actual position feedback value; no movement
- sdfzz
11 years 8 months ago #55658
by sdfzz
Replied by sdfzz on topic Ethercat HAL driver
Roschi,
Thank you for your reply. I was aware of 6.6 and 9.9 settings.... I saw it from your previous comments. I guess it is a way to select the desired homing mode, although without a proper documentation, it may cause confusions.
Also, thank you for the fix.
Regards,
Steve
Regards,
Steve
- sdfzz
11 years 8 months ago #55659
by sdfzz
Sascha,
I tried your new project. Installation was much easier, and now I can jog and home my axis.
Thank you!
Thank you!
- kyoshiro1108
11 years 7 months ago #56611
by kyoshiro1108
Replied by kyoshiro1108 on topic Ethercat HAL driver
the first error :Mailbox corrupt received
I've encountered this issue two month ago.
you need to contact the drive manufacturor and update your driver version to 2.0.0
Time to create page: 0.185 seconds
