Ethercat HAL driver
11 years 3 months ago #60646 by javiergr
Replied by javiergr on topic Ethercat HAL driver
Beautifull!!!
Can you put some data about universal joints, rods, etc (manufacturer, models, etc)
Best regards
11 years 3 months ago #60649 by LearningLinuxCNC
Replied by LearningLinuxCNC on topic Ethercat HAL driver
3 videos of my machine running
Very Nice! Can you show some details of the upper arms and servo drives as well?
11 years 3 months ago #60822 by automata
Replied by automata on topic Ethercat HAL driver
Hi Sascha,
Thanks for the excellent effort and library. I integrated 2 panasonic A5B ethercat drives with linuxcnc.
Thanks to your library, the integration was effortless.
My config: Debian Wheezy with 3.4-9-rtai kernel on the linuxcnc 2.6 live CD. Latest master from linuxcnc git
I have attached the xml file that was parsed with lcec_conf
There is one issue with the linuxcnc-ethercat repo at github:
github.com/sittner/linuxcnc-ethercat/blo...ster/configure.mk#L1
it is expecting "comp" to process the lcec at github.com/sittner/linuxcnc-ethercat/blo...ster/configure.mk#L1
It should be changed to halcompile as comp has been renamed to halcompile since mid 2014.
We should check for comp or halcompile and include the relevant paths.
-amit
11 years 2 months ago - 11 years 2 months ago #61796 by ftree
Replied by ftree on topic Ethercat HAL driver
I'm looking at developing a Yaskawa based linear motor machine using SGLFM coils and 2 meters of SGLFM ways.
The drive would probably be a Yaskawa ServoPack Sigma-7 with EtherCAT - fully closed loop with linear or absolute encoder.
www.yaskawa.eu.com/en/drives-motion/ac-s...a-7/description.html
I'm sure I spotted a chap on here tthat had Yaskawa/EtherCAT working. I'll do another search. Could this be a fairly straighforward coding job to support this setup? Alternatively I could look at Mesa / pulse version of the ServoPack. The fully closed encoder feedback intrigues me, especially the vibration suppression.
What are the pros/cons by closing the loop at the ServoPack rather than the linearscale being connected directly into LinuxCNC via MESA?
Last edit: 11 years 2 months ago by ftree.
11 years 2 months ago - 11 years 2 months ago #61928 by ftree
Thinking something along these lines. The encoder is directly attached to the ServoPack.
Would the EtherCAT module/driver support feedback through to LinuxCNC from the ServoPack?
11 years 1 month ago #62078 by Oscmol
Replied by Oscmol on topic Ethercat HAL driver
narogon wrote: 3 videos of my machine running
Servodrives OMRON R88D-KN02H-ECT
Beckhoff EL1014, EL3102
Hi Narogon
This looks really lovely B)
I have 2 Omron drives the same you are using except its 400watts instead.
My plan is to have these to on my lathe and would really like to test this ethercat communication.
I use ethercat alot at my work but have never tried it in Linux cnc.
- Can you maybe tell me more about your application and maybe put up some example file?
- What is your configuration on the Beckhoff I/O node?
- My idea were to put a hand / jog wheel like and MPG on the Beckhoff node and some other I/O for the toolchanger.
- Did you use CX-Drive from omron to tune and set up the drives?
I am thankful for all the information you can tell.
Best regards
Oscar
Time to create page: 0.662 seconds
