Ethercat HAL driver
- euerka
11 years 5 months ago #58345
by euerka
Replied by euerka on topic Ethercat HAL driver
I got the answer after I read the source code.
add
in configure file to support multi-master.
add
<masters>
</master>
- pavel7890
11 years 5 months ago #58833
by pavel7890
Replied by pavel7890 on topic Ethercat HAL driver
I finally started to work out my indradrive ethercat project. I acquired Wasino gang lathe and want to use 2 axis servo and main spindle, all controlled by ethercat.
I started with main spindle. So far so good
Just a bit playing with correct soft start/stop spindle procedure.
I guess I found a bug in sittners lcec_conf.c for scale and offset. Since I do not have any experience with git contribution i put it here:
// parse scale
if (strcmp(name, "scale") == 0) {
floatReq = 1;
p->floatScale = atof(val);
continue;
// parse offset
if (strcmp(name, "offset") == 0) {
floatReq = 1;
p->floatOffset = atof(val);
continue;
There was not continue; so it just parsed scale parameter with error.
Hope it helps.
// parse scale
floatReq = 1;
continue;
// parse offset
floatReq = 1;
continue;
Hope it helps.
- sascha
- Thank you received: 29
11 years 5 months ago #58889
by sascha
Replied by sascha on topic Ethercat HAL driver
You are right, thank you.
I've took it into master: github.com/sittner/linuxcnc-ethercat/com...7da79e3406d6d881dc8b
- bkt
- Thank you received: 114
11 years 5 months ago #59059
by bkt
Replied by bkt on topic Ethercat HAL driver
sorry at all .... I have not experience with ethercat ..... and i read some specification on linuxcnc doc ethercat, I have a doubt: How many drives can be connected to LinuxCNC with EtherCAT with safe/robust operation ?
- a60081
11 years 4 months ago #59516
by a60081
Replied by a60081 on topic Ethercat HAL driver
I want to create two domain for pdos because the motor i used is required one domain(1600) for transfer, and another one for receive(1A00).
If only one domain, it will be synchronize error.
How could i edit it in lcec.c?
- narogon
- Thank you received: 14
11 years 4 months ago - 11 years 4 months ago #59628
by narogon
Check tutorial
step 9 parameter 4.
I think you mean sync managers when you say domains.
Replied by narogon on topic Ethercat HAL driver
a60081 wrote: I want to create two domain for pdos because the motor i used is required one domain(1600) for transfer, and another one for receive(1A00).
Check tutorial
step 9 parameter 4.
Last edit: 11 years 4 months ago by narogon.
The following user(s) said Thank You: a60081, Nico2017
Time to create page: 0.199 seconds
