- Thank you received: 57
Ethercat HAL driver
- sirop
9 years 2 months ago - 9 years 2 months ago #97293
by sirop
Replied by sirop on topic Ethercat HAL driver
Then you can try something like that from the command line:
-p0 for slave position=0 , 0x8006 : CAN TxPDO Configuration Node for slave 0,
1 : subindex for Configuration of CAN TxPDO 1 , OCTET_STRING as explained for (8006+n*16):01 .
ethercat download -p0 0x8006 1 OCTET_STRING
Last edit: 9 years 2 months ago by sirop.
- plopes9000
- Thank you received: 18
9 years 2 months ago #97296
by plopes9000
Replied by plopes9000 on topic Ethercat HAL driver
Unfortunately it will be 2.5 weeks before I can try anything, but the issue is not the configuration of the el6751, after configuring the 8yyx objects it's all setup appropriately. The issue is that the igh ethercat master does not know that the mapping has changed and thinks that there are no PDOs assigned to 1000 and 1400 physical addresses - but there are by now.
- plopes9000
9 years 2 months ago #97298
by plopes9000
What puzzles me is how could this
github.com/sittner/linuxcnc-ethercat/blo.../ethercat-conf_X.xml
have ever worked ... I can only assume that the backup parameter was used to store the canopen slaves configuration so that it's available at preop just after boot, hence caught in the igh ethercat initial bus scan. But I did try the backup parameter without success - though I'm not sure I did it properly . . .
- sirop
9 years 2 months ago #97299
by sirop
You can also do
after the first (unsuccessful) launch.
BTW, last time I tied to use OCTET_STRING from cmd, I did not really succeed:
lists.etherlab.org/pipermail/etherlab-users/2016/003094.html .
ethercat rescan
- plopes9000
9 years 2 months ago #97301
by plopes9000
The goal is to be able to boot the pc and launch linuxcnc without manual steps.
Thanks Boris. I will keep trying when I'm back home.
- sqmathlete
9 years 2 months ago #97415
by sqmathlete
Replied by sqmathlete on topic Ethercat HAL driver
Hi Sirop,
I dug deeper as you suggested into the AKD example. Ran the bash example code and managed to output ethercat cstruct. (I have attached the file) As you can see there is some info at the top enabling the syncManagers which makes sense because I see the amplifier (Delta ASDA-A2E) in the preop state in LinuxCNC and cannot make it switch states or interact with it at all.
Q1. Is the file outputted by the cstruct command the "glue module" referred to here?
wiki.linuxcnc.org/cgi-bin/wiki.pl?Etherlab .
Q2. Does this info also need to be included in the xml file and if so how would it be parsed?
Q3. To all. Show of hands how many people have a working machine? Working on a bench?
Time to create page: 0.696 seconds
