- Thank you received: 18
Ethercat HAL driver
- plopes9000
9 years 3 months ago #96423
by plopes9000
Replied by plopes9000 on topic Ethercat HAL driver
First off, great work with beckhoff's ethercat support in linuxcnc - love the modularity of the bus ... it's great that it's supported by linuxcnc.
I'm interested in adding support for the IL2301 B110. In particular I'm after using the IP Link to control Festo valve blocks.
I have multipoint valve blocks hooked up to my Linux cnc box, but would prefer to save the 16 digital ports (only really using 8 now) - besides it so much more elegant to control it via ethercat.
Could not find anything on the web, any pointers?
Thank you
Thank you
- sirop
- Thank you received: 57
9 years 3 months ago #96429
by sirop
So just write an XML description in order to try this slave out.
Replied by sirop on topic Ethercat HAL driver
plopes9000 wrote: I'm interested in adding support for the IL2301 B110. In particular I'm after using the IP Link to control Festo valve blocks.
www.beckhoff.de/default.asp?fieldbus_box/il230x_b110.htmIt detects the connected modules and automatically allocates the input and output data to the process image.
- mngr0
9 years 3 months ago #96466
by mngr0
I meant "Unable.. sorry for the horrible typo
today i installed igh master and then linuxcnc-ethercat driver using this commands:
when i type
the answer is
what did i do wrong?
still, thank sirop for the patience
Replied by mngr0 on topic Ethercat HAL driver
sirop wrote:
What should be enabled? Do you quote ethercat or linuxcnc log?mngr0 wrote:
it said "Enable to open shared memory, err=2, segmentation fault"
when i type
sudo /etc/init.d/ethercat start
Starting EtherCAT master 1.5.2 ERROR: could not insert 'ec_master': Invalid argument
failed
- sirop
9 years 3 months ago #96468
by sirop
Maybe, you installed more than 1 EtherLab master?
- mngr0
9 years 3 months ago #96474
by mngr0
it may be, because while installing linuxcnc-ethercat he told me that the file /etc/default/ethercat was already existing, and asked me what to do (replace, or keep the file, i kept the file)
so i don't have to install the ethercat master?
this is what i tried the first time, but i didn't know where is the file to configure the master and the one to start it.
- sirop
9 years 3 months ago #96475
by sirop
A network device can be used only by one master at atime.
So there should be only one master.
Time to create page: 0.221 seconds
