Ethercat HAL driver
- schlank
8 years 2 months ago - 8 years 2 months ago #115502
by schlank
Replied by schlank on topic Ethercat HAL driver
Hello!
I have some CANopen-Standard 402 Stepper-Motors and I want to use them with LinuxCNC. They can be configured to operate via ordinary Step/Dir interface. The CAN Bus is then exclusively used to put the motor into operation with the Step/Dir interface, not for actual motion planing. My plan was then to get the whole thing running with a Mesa card "the old fashioned way"
No I read on page 12 that via EtherCAT and some Beckhoff hardware I could use these motors properly via CANopen.
I am now unsure which approach to chose. The old-fashioned way seems to be straight forward but I anyway need to wire the CAN bus through the machine and get a script or something working to put the motors into Step/Dir operation (This I already managed, motors were running)
Using the CANBus is nicer from technical perspective and maybe the motors will also perform better as they were developed to work with CANopen (Just as guess). On the other hand I have no idea how complicated it is to get the motors running via the EtherCAT driver. Some Information are form 2014 or older, some Github pages are not available anymore and some files are missing.
The Mesa Card would be around 200€, the Beckhoff gear is slightly more expansive, depending on how cheap you can get it on eBay.
Would be nice to get some feedback which way to go and how much one need to get into Ethercat and CANopen in detail to get things running. Thanks in advance.
Last edit: 8 years 2 months ago by schlank.
- Ilya
8 years 2 months ago #115516
by Ilya
Replied by Ilya on topic Ethercat HAL driver
Thank you Chimeno and Dan for your responsiveness!
Everything was simple.
In the lcec_deasda.c file, the correct pin already was created.
In my case lcec.0.X.enc-index-ena
thanks,
Ilya
thanks,
Ilya
The following user(s) said Thank You: chimeno
- chimeno
- Thank you received: 125
8 years 2 months ago #115604
by chimeno
Replied by chimeno on topic Ethercat HAL driver
hello I do not think it is very difficult you can manage CanOpen through EK1100 and EL6751, using the generic module, to do the tests, I recommend that you configure everything through TWINCAT and then export it to linuxcnc-ethercat, in my opion if You do not know much about ethercat, it would be easier and cheaper to use the MESA card, I hope I have helped.
Chimeno
Chimeno
- KRSO
8 years 2 months ago - 8 years 2 months ago #116366
by KRSO
Replied by KRSO on topic Ethercat HAL driver
Hi.
New member here, and new to LinuxCNC!
I'm doing some research for a new CNC.
I want to make a CNC with a distributed/decentralized ethercat servo system with small DC supplied servo drivers at around 80-120VDC.
Have anyone successfully used Copley Plus series, Elmo Gold series or Ingenia servo drives?
Are there any reasons for these to not work with LinuxCNC?
Best Regards Kristian
Last edit: 8 years 2 months ago by KRSO.
- sirop
- Thank you received: 57
8 years 2 months ago - 8 years 2 months ago #116369
by sirop
Replied by sirop on topic Ethercat HAL driver
I used Copley Plus drives without problems.
Any drive will "see" only the EtherLAB master.
LinuxCNC will only make you create corresponding IO pins.
The more interesting question is precision of your setup: that's depends on your encoders, gear trains (backlash)...
Last edit: 8 years 2 months ago by sirop.
- KRSO
8 years 2 months ago - 8 years 2 months ago #116373
by KRSO
That's excellent! My fist choice would be Elmo Gold. We'll see what I can get within the budget.
I bought a complete three axis dual gantry Aerotech (AGS10000) linear motor stage to play with. All parts, including enclosure, but without servo drives. Accuracy should be pretty good;)
Mainly for PnP, but might also be used for 3D printing and light milling.
Time to create page: 0.253 seconds
