Ethercat HAL driver
8 years 3 weeks ago #118626 by gbcwbz
Replied by gbcwbz on topic Ethercat HAL driver
andrax,
If you want to send an uint32 number, who's value is 1000, and 000003E8 in hex format, then you should write E8 03 00 00 in sdoRawData field
8 years 3 weeks ago #118641 by andrax
Replied by andrax on topic Ethercat HAL driver
Hello,
the question about PDO and SDO has been resolved.
I found the values ​​and understand the entries.
I have now created the xml without Axes and tested in linuxcnc.
The ethercat haldriver brings a lot of errors but linuxcnc starts and I can address the pins of el1014 and el2008.
The el 6731 has the following statuses:
RUN: flasch
BF: flash
ERR: off
in the Hal:
state-safeop = false
slave-preop = true
state-op = true
state-init = false
slaves-responding = 0x00000004
link-up = true
is there a solution for the errors of ethercat-haldriver?
Best regards
Andre
File Name: ethercat-c...0-10.xml
File Size:2 KB
File Name: ethercat-h...rors.txt
File Size:74 KB
8 years 2 weeks ago #118825 by andrax
Hello,
i have an entry:
PDO Content: 0x1600
Offs: 0.0
Name: Outputs.3 PD (3 words)_1_0
Type: ARRAY [0..2] OF UNIT
How do I describe this in the XML ?
Best regards
Andre
8 years 1 week ago #119155 by andrax
Hallo,
ich habe die Klemme el6731 zum Laufen bekommen.
Der Datenaustausch funktioniert.
Vielen Dank für eure Hilfe...
8 years 1 week ago - 8 years 1 week ago #119224 by Grotius
Replied by Grotius on topic Ethercat HAL driver
Hi i did a install for 64 bit linuxcnc
terminal : sudo apt-get install mercurial
hg clone hg.code.sf.net/p/etherlabmaster/code ethercat-hg
./bootstrap
./configure --disable-8139too --enable-generic (no real time driver)
or take look for a currently used ethernet driver :
sudo lspci -v | grep "Ethernet\|driver"|grep -A1 Ethernet
in my case output = e1000e
./configure --disable-8139too --with-e1000e-kernel
make
make modules
sudo make install
sudo make modules_install
sudo depmod
/opt/etherlab/etc/init.d/ sudo ./ethercat restart
So far so good. Terminal say's :
Shutting down EtherCAT master 1.5.2 done Starting EtherCAT master 1.5.2 modprobe: ERROR: could not insert 'ec_master': Invalid argument failed
I think i have to configure a few files.
My system is : 4.9.0-5-rt-amd64
Last edit: 8 years 1 week ago by Grotius.
The following user(s) said Thank You: Nico2017
8 years 1 week ago - 8 years 1 week ago #119312 by Nico2017
Replied by Nico2017 on topic Ethercat HAL driver
Hi Rene (@ReneCNC), I think I am in your situation but I still do not manage to make it work. I have got:
LINUXCNC - 2.8.0~pre1
Machine configuration directory is '/home/plotter/linuxcnc/configs/LAMGUI'
Machine configuration file is 'lam.ini'
Starting LinuxCNC...
Found file(REL): ./lam-v1.hal
Note: Using POSIX realtime
lcec: dlopen: /usr/lib/linuxcnc/modules/lcec.so: undefined symbol: rtapi_mutex_get
./lam-v1.hal:3: waitpid failed /usr/bin/rtapi_app lcec
./lam-v1.hal:3: /usr/bin/rtapi_app exited without becoming ready
./lam-v1.hal:3: insmod for lcec failed, returned -1
LinuxCNC terminated with an error. You can find more information in the log:
/home/plotter/linuxcnc_debug.txt
and
/home/plotter/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
What did you do to make it work? I have the good rt headers installed, so still surprised it does not work.
Cheers,
Nicolas
Last edit: 8 years 1 week ago by Nico2017. Reason: Add more details
Time to create page: 0.473 seconds
