- Thank you received: 26
Ethercat HAL driver
- Nico2017
8 years 6 days ago #119428
by Nico2017
Replied by Nico2017 on topic Ethercat HAL driver
doing ldd lcec.so
linux-gate.so.1 (0xb7783000)
liblinuxcnchal.so.0 => /usr/lib/liblinuxcnchal.so.0 (0xb7746000)
libethercat.so.1 => /usr/lib/i386-linux-gnu/libethercat.so.1 (0xb773b000)
libm.so.6 => /lib/i386-linux-gnu/libm.so.6 (0xb76e4000)
libc.so.6 => /lib/i386-linux-gnu/libc.so.6 (0xb752d000)
librt.so.1 => /lib/i386-linux-gnu/librt.so.1 (0xb7524000)
libpthread.so.0 => /lib/i386-linux-gnu/libpthread.so.0 (0xb7507000)
/lib/ld-linux.so.2 (0xb7785000)
I installed ethercat, using dpkg with github.com/sittner/ec-debianize as I am using debian as it is the OS suggested for linuxcnc. I did try the etherlab installation, building it, without much success as it does not document the file system architecture for debian, during the installation process.
So far I have managed to
-install debian Strech with latest RT prempt kernel : Linux plotter 4.9.0-8-rt-686-pae #1 SMP PREEMPT RT Debian 4.9.110-3+deb9u5 (2018-09-30) i686 GNU/Linux
-install linuxcnc, either 2.7.14 or 2.8.x
-install ethercat using sittner ec-debianize depot ( github.com/sittner/ec-debianize ). After building and installing, Ethercat master and ethercat slaves command work fine
-build and install linuxcnc-ethercat from github.com/sittner/linuxcnc-ethercat (make then sudo make install, or sudo make clean, make then sudo make install if I switch the linuxcnc version to update the kernel)
My problems are:
-when I try to run Linuxcnc 2.7.14 I have a permission denied on Ethercat0 as shown in
LINUXCNC - 2.7.14
Machine configuration directory is '/home/plotter/linuxcnc/configs/LAMGUI'
Machine configuration file is 'lam.ini'
Starting LinuxCNC...
Found file(REL): ./lam-v1.hal
Note: Using POSIX realtime
Failed to open /dev/EtherCAT0: Permission denied
LCEC: requesting master 0 (index 0) failed
lcec: rtapi_app_main: Invalid argument (-22)
./lam-v1.hal:2: waitpid failed /usr/bin/rtapi_app lcec
./lam-v1.hal:2: /usr/bin/rtapi_app exited without becoming ready
./lam-v1.hal:2: insmod for lcec failed, returned -1
LinuxCNC terminated with an error. You can find more information in the log:
/home/plotter/linuxcnc_debug.txt
and
/home/plotter/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
-when I build linuxcnc 2.8.x then install it I got
-LINUXCNC - 2.8.0~pre1
lcec: dlopen: /usr/lib/linuxcnc/modules/lcec.so: undefined symbol: rtapi_mutex_get
and
Any advice about how to make either 2.7 or 2.8 working with the ethercat and linuxcnc ethercat driver?
Cheers,
Nicolas
doing ldd lcec.so
My problems are:
LINUXCNC - 2.7.14
and
and
Cheers,
Nicolas
- Grotius
- Thank you received: 2349
8 years 6 days ago - 8 years 6 days ago #119448
by Grotius
Replied by Grotius on topic Ethercat HAL driver
Hi Nico,
Is the file EtherCAT0 in your dev directory on C drive?
I made a empty file EtherCAT0 and placed this in C:dev/
I hope this helps you a little bit.
Failed to open /dev/EtherCAT0: Permission denied,
Last edit: 8 years 6 days ago by Grotius.
- Grotius
8 years 5 days ago - 8 years 5 days ago #119494
by Grotius
I have a general question about the Ethercat.comp file used with Linuxcnc.
Here is a sample of 2 found ethercat.comp file's
Version 1. wiki.linuxcnc.org/cgi-bin/wiki.pl?Contri...EtherCAT_Digital_I_O
Version 2. wiki.linuxcnc.org/cgi-bin/wiki.pl?Etherlab
Version 1:
Version 2:
If you want to compile the ethercat.comp file with latest version of linuxcnc it will not compile.
It has to do with librarie's, and much more. Okey a lot to solve in the component code.
Find out the error code's yourself : sudo halcompile --install ethercat.comp
My idea is to start working on a new ethercat.comp file.
If we get one good ehercat.comp file, that would also a very good Ethercat start option for today's linuxcnc user's i think.
A example : integrating ethercat in a custom made linuxcnc version is now a bit of a problem. In my opinion that is not documented before.
Here is my start of the new component, it compiles without issues :
Version 1:
Warning: Spoiler!
component ethercat"Ethercat.";
pin out bit eingang_0;
pin out bit eingang_1;
pin out bit eingang_2;
pin out bit eingang_3;
pin in bit ausgang_0;
pin in bit ausgang_1;
pin in bit ausgang_2;
pin in bit ausgang_3;
option extra_setup;
option extra_cleanup;
//option constructable no;
function update nofp;
MODULE_LICENSE("GPL");
// RTAI
//#include "/usr/realtime-2.6.15-magma/include/rtai_sched.h"
//#include "/usr/realtime-2.6.15-magma/include/rtai_sem.h"
// EtherCAT
#include "/home/ruediger/ethercat-1.3.0/include/ecrt.h"
#include "/home/ruediger/ethercat-1.3.0/include/ecdb.h"
// EtherCAT
static ec_master_t *master = NULL;
static ec_domain_t *domain1 = NULL;
spinlock_t master_lock = SPIN_LOCK_UNLOCKED;
static ec_master_status_t master_status, old_status = {};
// data fields
static void *r_dig_in;
static void *r_dig_out;
const static ec_pdo_reg_t domain1_pdo_regs[] = {
{"1", Beckhoff_EL1014_Inputs, &r_dig_in},
{"2", Beckhoff_EL2004_Outputs, &r_dig_out},
#define MAX 8
int io[MAX] = {0,};
RTAPI_MP_ARRAY_INT(io, MAX, "I/O addresses of serial ports");
* LOCAL FUNCTION DECLARATIONS *
static int request_lock(void *data);
static void release_lock(void *data);
EXTRA_SETUP() {
ec_slave_t *slave;
rtapi_print_msg(RTAPI_MSG_INFO,"Starting...\n");
//printk(KERN_INFO PFX "Starting...\n");
if (!(master = ecrt_request_master(0))) {
rtapi_print_msg(RTAPI_MSG_INFO,"BRequesting master 0 failed!\n");
//printk(KERN_ERR PFX "Requesting master 0 failed!\n");
goto out_return;
ecrt_master_callbacks(master, request_lock, release_lock, NULL);
rtapi_print_msg(RTAPI_MSG_INFO,"Registering domain...\n");
//printk(KERN_INFO PFX "Registering domain...\n");
if (!(domain1 = ecrt_master_create_domain(master))) {
rtapi_print_msg(RTAPI_MSG_INFO,"Domain creation failed!\n");
//printk(KERN_ERR PFX "Domain creation failed!\n");
goto out_release_master;
rtapi_print_msg(RTAPI_MSG_INFO,"Registering PDOs...\n");
//rintk(KERN_INFO PFX "Registering PDOs...\n");
if (ecrt_domain_register_pdo_list(domain1, domain1_pdo_regs)) {
rtapi_print_msg(RTAPI_MSG_INFO,"PDO registration failed!\n");
//printk(KERN_ERR PFX "PDO registration failed!\n");
rtapi_print_msg(RTAPI_MSG_INFO,"Activating master...\n");
//printk(KERN_INFO PFX "Activating master...\n");
if (ecrt_master_activate(master)) {
rtapi_print_msg(RTAPI_MSG_INFO,"Failed to activate master!\n");
//printk(KERN_ERR PFX "Failed to activate master!\n");
rtapi_print_msg(RTAPI_MSG_INFO,"Started.\n");
//printk(KERN_INFO PFX "Started.\n");
return 0;
out_release_master:
rtapi_print_msg(RTAPI_MSG_INFO,"Releasing master...\n");
//printk(KERN_ERR PFX "Releasing master...\n");
ecrt_release_master(master);
out_return:
rtapi_print_msg(RTAPI_MSG_INFO,"Failed to load. Aborting.\n");
//printk(KERN_ERR PFX "Failed to load. Aborting.\n");
return -1;
EXTRA_CLEANUP() {
rtapi_print_msg(RTAPI_MSG_INFO,"Stopping...\n");
//printk(KERN_INFO PFX "Stopping...\n");
//printk(KERN_INFO PFX "Releasing master...\n");
rtapi_print_msg(RTAPI_MSG_INFO,"Unloading.\n");
//printk(KERN_INFO PFX "Unloading.\n");
FUNCTION(update) {
// receive
spin_lock(&master_lock);
ecrt_master_receive(master);
ecrt_domain_process(domain1);
spin_unlock(&master_lock);
//EC_WRITE_U8(r_dig_out, blink ? 0x0F : 0x00);
eingang_0 = EC_READ_BIT(r_dig_in, 0);
eingang_1 = EC_READ_BIT(r_dig_in, 1);
eingang_2 = EC_READ_BIT(r_dig_in, 2);
eingang_3 = EC_READ_BIT(r_dig_in, 3);
EC_WRITE_BIT(r_dig_out, 0, ausgang_0);
EC_WRITE_BIT(r_dig_out, 1, ausgang_1);
EC_WRITE_BIT(r_dig_out, 2, ausgang_2);
EC_WRITE_BIT(r_dig_out, 3, ausgang_3);
ecrt_master_get_status(master, &master_status);
if (master_status.bus_status != old_status.bus_status) {
rtapi_print_msg(RTAPI_MSG_INFO,"bus status changed to %i.\n", master_status.bus_status);
//printk(KERN_INFO PFX "bus status changed to %i.\n",
// master_status.bus_status);
if (master_status.bus_tainted != old_status.bus_tainted) {
rtapi_print_msg(RTAPI_MSG_INFO,"tainted flag changed to %u.\n", master_status.bus_tainted);
//printk(KERN_INFO PFX "tainted flag changed to %u.\n",
// master_status.bus_tainted);
if (master_status.slaves_responding !=
old_status.slaves_responding) {
rtapi_print_msg(RTAPI_MSG_INFO,"slaves_responding changed to %u.\n", master_status.slaves_responding);
//printk(KERN_INFO PFX "slaves_responding changed to %u.\n",
// master_status.slaves_responding);
old_status = master_status;
// send
ecrt_domain_queue(domain1);
ecrt_master_send(master);
return 0; // access allowed
option extra_setup;
// RTAI
// EtherCAT
// EtherCAT
// data fields
#define MAX 8
int io[MAX] = {0,};
EXTRA_SETUP() {
ec_slave_t *slave;
goto out_return;
return 0;
out_release_master:
out_return:
return -1;
EXTRA_CLEANUP() {
FUNCTION(update) {
// receive
// send
Version 2:
Warning: Spoiler!
pin out bit eingang_4;
pin out bit eingang_5;
pin out bit eingang_6;
pin out bit eingang_7;
pin in bit ausgang_4;
pin in bit ausgang_5;
pin in bit ausgang_6;
pin in bit ausgang_7;
option extra_setup;
license "GPL";
#include "/opt/ethercat/include/ecrt.h"
// EtherCAT
static ec_master_state_t master_status, old_status = {};
// data fields
static uint8_t *domain1_pd; // process data memory
// offsets to data fields
static unsigned int o_dig_in[8], bo_dig_in[8];
static unsigned int o_dig_out[8], bo_dig_out[8];
// pdo definitions may be read from autogenerated file
//#include "ethercat_cstruct.c"
#define Beckhoff_EL2004 0x00000002, 0x07D43052
#define Beckhoff_EL1014 0x00000002, 0x03F63052
const static ec_pdo_entry_reg_t domain1_pdo_regs[] = {
{ 0, 1, Beckhoff_EL2004, 0x7000, 1, &o_dig_out[0], &bo_dig_in[0]},
{ 0, 1, Beckhoff_EL2004, 0x7010, 1, &o_dig_out[1], &bo_dig_in[1]},
{ 0, 1, Beckhoff_EL2004, 0x7020, 1, &o_dig_out[2], &bo_dig_in[2]},
{ 0, 1, Beckhoff_EL2004, 0x7030, 1, &o_dig_out[3], &bo_dig_in[3]},
{ 0, 2, Beckhoff_EL2004, 0x7000, 1, &o_dig_out[4], &bo_dig_in[4]},
{ 0, 2, Beckhoff_EL2004, 0x7010, 1, &o_dig_out[5], &bo_dig_in[5]},
{ 0, 2, Beckhoff_EL2004, 0x7020, 1, &o_dig_out[6], &bo_dig_in[6]},
{ 0, 2, Beckhoff_EL2004, 0x7030, 1, &o_dig_out[7], &bo_dig_in[7]},
{ 0, 3, Beckhoff_EL1014, 0x6000, 1, &o_dig_in[0] , &bo_dig_out[0]},
{ 0, 3, Beckhoff_EL1014, 0x6010, 1, &o_dig_in[1] , &bo_dig_out[1]},
{ 0, 3, Beckhoff_EL1014, 0x6020, 1, &o_dig_in[2] , &bo_dig_out[2]},
{ 0, 3, Beckhoff_EL1014, 0x6030, 1, &o_dig_in[3] , &bo_dig_out[3]},
{ 0, 4, Beckhoff_EL1014, 0x6000, 1, &o_dig_in[4] , &bo_dig_out[4]},
{ 0, 4, Beckhoff_EL1014, 0x6010, 1, &o_dig_in[5] , &bo_dig_out[5]},
{ 0, 4, Beckhoff_EL1014, 0x6020, 1, &o_dig_in[6] , &bo_dig_out[6]},
{ 0, 4, Beckhoff_EL1014, 0x6030, 1, &o_dig_in[7] , &bo_dig_out[7]},
/* { 0, 1, Beckhoff_EL2004, 0x7000, 1, &o_dig_out[0], NULL}, */
/* { 0, 4, Beckhoff_EL1014, 0x6000, 1, &o_dig_in[0] , NULL}, */
void request_lock(void *data)
EXTRA_SETUP() {
goto out_return;
if (ecrt_domain_reg_pdo_entry_list(domain1, domain1_pdo_regs)) {
domain1_pd = ecrt_domain_data(domain1);
return 0;
out_release_master:
master= NULL;
out_return:
return -1;
EXTRA_CLEANUP() {
if (master) {
FUNCTION(update) {
// receive
eingang_0 = EC_READ_BIT( domain1_pd+o_dig_in[0], bo_dig_in[0]);
eingang_1 = EC_READ_BIT( domain1_pd+o_dig_in[1], bo_dig_in[1]);
eingang_2 = EC_READ_BIT( domain1_pd+o_dig_in[2], bo_dig_in[2]);
eingang_3 = EC_READ_BIT( domain1_pd+o_dig_in[3], bo_dig_in[3]);
eingang_4 = EC_READ_BIT( domain1_pd+o_dig_in[4], bo_dig_in[4]);
eingang_5 = EC_READ_BIT( domain1_pd+o_dig_in[5], bo_dig_in[5]);
eingang_6 = EC_READ_BIT( domain1_pd+o_dig_in[6], bo_dig_in[6]);
eingang_7 = EC_READ_BIT( domain1_pd+o_dig_in[7], bo_dig_in[7]);
EC_WRITE_BIT(domain1_pd+o_dig_out[0], bo_dig_out[0], ausgang_0);
EC_WRITE_BIT(domain1_pd+o_dig_out[1], bo_dig_out[1], ausgang_1);
EC_WRITE_BIT(domain1_pd+o_dig_out[2], bo_dig_out[2], ausgang_2);
EC_WRITE_BIT(domain1_pd+o_dig_out[3], bo_dig_out[3], ausgang_3);
EC_WRITE_BIT(domain1_pd+o_dig_out[4], bo_dig_out[4], ausgang_4);
EC_WRITE_BIT(domain1_pd+o_dig_out[5], bo_dig_out[5], ausgang_5);
EC_WRITE_BIT(domain1_pd+o_dig_out[6], bo_dig_out[6], ausgang_6);
EC_WRITE_BIT(domain1_pd+o_dig_out[7], bo_dig_out[7], ausgang_7);
/* eingang_0= EC_READ_BIT( domain1_pd+o_dig_in[0],0); */
/* EC_WRITE_BIT(domain1_pd+o_dig_out[0],0,ausgang_0); */
ecrt_master_state(master, &master_status);
if (master_status.al_states != old_status.al_states) {
rtapi_print_msg(RTAPI_MSG_INFO,"bus status changed to %i.\n", master_status.al_states);
// send
option extra_setup;
license "GPL";
// EtherCAT
// data fields
EXTRA_SETUP() {
goto out_return;
return 0;
out_release_master:
master= NULL;
out_return:
return -1;
EXTRA_CLEANUP() {
if (master) {
FUNCTION(update) {
// receive
// send
Warning: Spoiler!
description
Ethercat Component
Modification list :
1. Changed include source from ethercat to etherlab
2. Start from zero
3. When writing a new component it is importand to use also "case" in programming style.
This will make a nice routing in the workflow of handling different senario's, like emergency stop,
and what to do in that senario.
Expanding "case" is very easy, just copy and rename a case, and add case name to typedef enum.
4. Don't us goto statements in your code.
5. In C style you can write your mind into the code.
author "Grotius CNC Machines, started Oktober 2018";
license "GPL";
option singleton yes;
//Ethercat terminal hal connection :
//Servo hal connection :
//Stepper hal connection ;
//Input hal connection :
pin in bit Enable "Enable this ethercat component";
pin in bit Input_0 "Comment ....";
//Output hal connection :
pin out bit Ethercat_enabled "Connect to user gui led";
pin out bit Output_0 "Comment ....";
function _;
#include "/opt/etherlab/include/ecrt.h"
// EtherCAT
//spinlock_t master_lock = SPIN_LOCK_UNLOCKED;
// data fields
typedef enum { INIT, SELECT} state_T;
state_T state = INIT;
FUNCTION(_) {
switch(state){
case INIT:
if(Enable){
Ethercat_enabled = 1;
state = SELECT; // If ethercat input is enabled the case function jump's to case SELECT:
if(!Enable){
Ethercat_enabled = 0;
state = INIT;
break;
case SELECT:
EC_WRITE_BIT(domain1_pd+o_dig_out[0], bo_dig_out[0], Output_0);
break;
description
Ethercat Component
Modification list :
2. Start from zero
license "GPL";
function _;
// EtherCAT
// data fields
FUNCTION(_) {
switch(state){
case INIT:
if(Enable){
if(!Enable){
state = INIT;
break;
case SELECT:
break;
Last edit: 8 years 5 days ago by Grotius.
- Nico2017
8 years 3 days ago - 7 years 11 months ago #119562
by Nico2017
Hi @Grotius,
it does actually help.
The /dev/Ethercat0 was already there but with some restrained permission so after a sudo chmod a+rwx Ethercat0, the linuxcnc 2.7 and linuxcnc 2.8 were able to carry on.The only issue is I have to do that everytime I log in as the permission seems not to be saved for some reason. Any idea about how I could make the permission permanent?
Edit: to make the /dev/EtherCAT0 usage permanent just do sudo adduser $USER ethercat, and/or sudo adduser root ethercat then you have to reboot (see post askubuntu.com/questions/373096/how-do-i-...ssions-for-dev-ttys0 for a similar case.)
However it did show another error for linuxcnc 2.8, which I believe is link to an error seen on the make of the linuxcnc-ethercat.
Using the linuxcnc-ethercat last commit:
commit b02252a79d11f1c9dd5884bac1a53743b3818d39
Merge: 22bcaa9 333dec5
Author: Sascha Ittner <sascha.ittner@modusoft.de>
Date: Fri Aug 17 16:37:32 2018 +0200
Merge pull request #60 from sittner/add-fsoe-support
Add fsoe support
I obtain
Machine configuration directory is '/home/laminator/linuxcnc/configs/LAMGUI'
/home/laminator/linuxcnc_debug.txt
and
/home/laminator/linuxcnc_print.txt
Using the linuxcnc-ethercat commit:
commit 7b1e4bb0bb0b5886486b98fc2511b2333402ad0d
Author: Sascha Ittner <sascha@wicky.rb.modusoft.lan>
Date: Sat Mar 10 10:03:44 2018 +0100
use linuxcnc's Makefile.modinc to build RT component
I obtain:
lcec: dlopen: /usr/lib/linuxcnc/modules/lcec.so: undefined symbol: ecrt_slave_config_sdo
and
I believe this is related to the last post on github.com/sittner/linuxcnc-ethercat/issues/57 > and github.com/sittner/linuxcnc-ethercat/issues/61
Any idea how to avoid this error?
Thanks a lot for the help,
Nicolas
Add fsoe support
I obtain
and
I obtain:
and
Nicolas
Last edit: 7 years 11 months ago by Nico2017. Reason: More precise answer
- Grotius
8 years 3 days ago - 8 years 3 days ago #119566
by Grotius
Okey guy's,
I have some news. Struggling with include files in hal.
Done some test's. I needed the "/opt/etherlab/include/ecrt.h" to work with linuxcnc hal. In hal we can couple a lot of stuff.
Nothing happened and linuxcnc refused to load dlopen .....
So i start from zero with a sucesfull test to that directory, to print some info.
Next thing will be integrating a bigger file.
in postgui.hal
ethercat component, ethercat.comp :
(compiled in terminal by : sudo halcompile --install ethercat.comp)
The external_file.h is located in directory : /opt/etherlab/include/external_file.h
The file below is : external_file.h (it is a short file, only containing a function with a print message, for fun, function is in fact : () )
Inside the function we say only print some info :
Output in linuxcnc terminal :
So i think this is a first start to use Ethercat to Linuxcnc hal for me.
in postgui.hal
loadrt ethercat
addf ethercat servo-thread
component ethercat"ethercat";
description
Test Component
license "GPL";
pin in bit Testpin_in "Enable this component";
pin out bit Testpin_out "Connect to user gui led";
function _;
#include <stdio.h>
#include "/opt/etherlab/include/external_file.h"
FUNCTION(_) {
switch(state){
case INIT:
state = SELECT;
break;
case SELECT:
// do something with the include file
function_print();
break;
#include<stdio.h>
int function_print()
printf("external file print");
return 0;
Last edit: 8 years 3 days ago by Grotius.
- gbcwbz
7 years 11 months ago #120133
by gbcwbz
Replied by gbcwbz on topic Ethercat HAL driver
Hi Nicolas,
Please refer to IgH Master 1.5.2 Documentation Chapter 9.5
Then you can use that device as non-root user.
Regards
Bryan
The device nodes will be created with mode 0660 and group root by default. If “nor-
mal” users shall have reading access, a udev rule file (for example /etc/udev/rules.d/99-
EtherCAT.rules) has to be created with the following contents:Code:KERNEL ==" EtherCAT [0 -9]*" , MODE ="0664"
Regards
Bryan
The following user(s) said Thank You: Nico2017
Time to create page: 0.531 seconds
