Ethercat HAL driver
7 years 11 months ago #121313 by Hawkeye
Replied by Hawkeye on topic Ethercat HAL driver
Hello Grotius,
I am now in from of a debian-strech laptop and I am struggeling with the basic setup of ethercat. do you have a strait guide wo bring the ethercat-stack up and running?
When I try to build the sources I cloned with "hg clone hg.code.sf.net/p/etherlabmaster/code ethercat-hg" I am getting always the following error:
checking for kernel for e1000e driver... configure: error: kernel 4.9 not available for e1000e driver!
so far I tried:
cd ethercat-hg
hg update stable-1.5
./bootstrap
#./configure --disable-8139too --enable-generic --enable-e1000e
./configure --disable-8139too --with-e1000e-kernel --enable-generic
make
make modules
sudo make install
sudo make modules_install
depmod
Best Regards and good night,
Ben
7 years 11 months ago - 7 years 11 months ago #121317 by Hawkeye
Hello,
Quick update:
Managed to bring up ethercat on my laptop. Needed to start
/etc/init.d/realtime and had to set within /etc/init.d/ethercat the driver to "generic". I had the same issue with /dev/Ethercat0 and solved it temporarily as already described within this Thread(s).
On shell I can see my ethercat devices using "ethcat slaves -v" now.
When I start Linuxcnc 3.8-pre now, it notifys me that my config needa Updates. Wheather or not I agree to update my config, the whole system freezes.
Any Idea?
Best Regards,
Ben
Last edit: 7 years 11 months ago by Hawkeye.
7 years 11 months ago #121318 by Hawkeye
Update:
It's alive!
Works like a Charm!
Linuxcnc3.8 + debian stetch 64bit iso + ethercat components from Beckhoff
The following user(s) said Thank You: Nico2017
7 years 9 months ago - 7 years 9 months ago #123883 by Nico2017
Replied by Nico2017 on topic Ethercat HAL driver
Hi @Hawkeye,
would you be able to summarize the different steps you went through to make it work.
Thank you,
Nicolas
Last edit: 7 years 9 months ago by Nico2017. Reason: More precise request
7 years 9 months ago - 7 years 9 months ago #123888 by Hawkeye
Hi @Nico2017,
YES - I will create a quick guide until end of thia week. Do you already have an working Hal-config for ethercat (are you migrating from previous version)?
It took me weeks and several retries to get all steps together. Did you already have a look here?
forum.linuxcnc.org/27-driver-boards/3559...uxcnc-how-to-install
This was helpful but copying files around is not my style..
So, stay tuned :-)
[hr]
This is my how-to guide on LinuxCNC 2.8 @ Debian 9 Stretch 64 Bit:
!! Before we start, please be adviced that I don't explain every single step in detail.
!! I assume that you are experienced linux user and you know what you are doing.
!! I don't want to discuss why I am installing this or that, and/or doing what I am doing.
!! If you think you can make this better, then simply do it and don't blame on me.
!! Regarding network:
!! - Build-in wifi is used to connect to my network
!! - Lan-Port will be used as ethercat master
!! Ethercat components:
!! - 2x EK1100 (Laptop -> 1. inside cabinet -> 2. mounted on back of Z-axis gantry)
!! - 4x EL4071 (X-Y-Z-A) [A is needed for extruder in 3D-printer mode or rotary axis in mill-mode]
!! - 1x EL3202 (used to get temperature from extruder hotend)
!! - 2x EL1008
!! - 2x EL2008
!! - 1x EL6021 to control 2.2KW spindle (still under development)
!! Objective:
!! - We are using a HP8440P Laptop.
!! - Rather than using LinuxCNC as run in place setup, we are building ".deb"-files and apply them to the operating system.
!! I would like to thank the guys from #linuxcnc-devel@irc.freenode.net - you guys are awesome B)
!! My special thanks are going to :woohoo:
!! - "rmu"
!! - "pcw_home"
01. Get install media from link below and install it on your machine.
www.linuxcnc.org/testing-stretch-rtpreem...uspace-amd64-r13.iso
02. Perform basic setup of Operating System
- wifi config
- enable root account
sudo passwd root
- change to user root
su - root
- configure repository list (see wiki.debian.org/SourcesList )
nano /etc/apt/sources.list
- update operating system:
apt-get update && apt-get upgrade -y && apt autoremove
- create "/install" directory (we will store some of install resources)
mkdir /install cd /install
- install some tools
apt-get install geany \ ufw \ clamav \ clamtk \ git \ curl \ mercurial \ htop \ mplayer \ net-tools
- create "/git" dir and initialize it
mkdir /git cd /git git init
- activate firewall
systemctl start ufw systemctl enable ufw ufw enable
- determine mac address of lan port
ip link show
- configure lan
"nano /etc/network/interfaces"
# This file describes the network interfaces available on your system # and how to activate them. For more information, see interfaces(5). source /etc/network/interfaces.d/* # The loopback network interface auto lo iface lo inet loopback allow-hotplug eth0 iface eth0 inet static address 10.0.0.1 netmask 255.255.255.0
- avoid wait time due to startup of network services
"nano /lib/systemd/system/networking.service" (change here "TimeoutStartSec=5min" to "TimeoutStartSec=1sec")
- install some reseources required for build process later on
apt-get install docbook-xsl \ dvipng \ graphviz \ groff \ inkscape \ python-lxml \ source-highlight \ texlive-extra-utils \ texlive-font-utils \ texlive-fonts-recommended \ texlive-latex-recommended \ w3c-linkchecker \ xsltproc \ asciidoc-dblatex \ python-dev \ libxmu-dev \ libglu1-mesa-dev \ libgl1-mesa-dev apt-get install libgtk2.0-dev \ gettext \ intltool \ autoconf \ libboost-python-dev \ netcat \ libmodbus-dev \ libusb-1.0-0-dev \ yapps2 \ tcl8.6-dev \ tk8.6-dev \ libreadline-gplv2-dev \ asciidoc \ devscripts \ build-essential \ lintian \ texlive-lang-cyrillic \ texlive-lang-french \ texlive-lang-german \ texlive-lang-polish \ texlive-lang-spanish \ devscripts \ build-essential \ quilt
03. Remove pre-installed linuxcnc
apt-get purge linuxcnc-doc-en linuxcnc-uspace-dev linuxcnc-uspace
04. Setup LinuxCNC 2.8
cd /git git clone git://github.com/linuxcnc/linuxcnc.git linuxcnc-dev cd linuxcnc-dev/debian ./configure uspace cd .. dpkg-buildpackage -b -uc cd /git apt install ./linuxcnc-doc-en_2.8.0~pre1_all.deb apt install ./linuxcnc-uspace_2.8.0~pre1_amd64.deb apt install ./linuxcnc-uspace-dev_2.8.0~pre1_amd64.deb mkdir /git/linuxcnc-dev/deb/ mv linuxcnc_* /git/linuxcnc-dev/deb/ mv *.deb /git/linuxcnc-dev/deb/ reboot
05. Setup "ec-debianize"
cd /git git clone https://github.com/sittner/ec-debianize ec-debianize ./get_source.sh cd etherlabmaster dpkg-checkbuilddeps dpkg-buildpackage (the output error "failed to sign .dsc file" is no issue) sudo dpkg -i /git/ec-debianize/etherlabmaster_1.5.2+20180317hg9e65f7-2_amd64.deb sudo dpkg -i /git/ec-debianize/etherlabmaster-dev_1.5.2+20180317hg9e65f7-2_amd64.deb nano /etc/default/ethercat (change mac-address [MASTER0_DEVICE=""] e.g. [MASTER0_DEVICE="11:22:33:44:55:66"]) nano /etc/default/ethercat (change [DEVICE_MODULES=""] to [DEVICE_MODULES="generic"]) sudo update-ethercat-config usermod -a -G ethercat linuxcnc reboot
06. Setup "LinuxCNC-Ethercat"
cd /git git clone http://github.com/sittner/linuxcnc-ethercat.git linuxcnc-ethercat" nano /git/linuxcnc-ethercat/src/lcec_main.c (add here [#include "rtapi_mutex.h"] below [#include "rtapi_app.h"]) cd /git/linuxcnc-ethercat make -j4 make install sudo make install
07. Further things to consider
- if you experience issues when starting linuxcnc (cpu high load), then try to change "BASE_PERIOD=0" within your ini-file (config of your machine)
08. .. this is know the part where I guess I can end this guide now.
.. further steps (setting up ethercat.xml, machine config, ... can be seen within the forum).
.. hope this helped you - thanks for reading.
.. please leave a comment whether you managed it to get your system running.
[hr]
Best Regards,
Ben
Last edit: 7 years 9 months ago by Hawkeye.
The following user(s) said Thank You: Nico2017, Matze-K, hilo90mhz
7 years 9 months ago - 7 years 9 months ago #123929 by Nico2017
Thanks your for those explanations. I have linuxcnc and ethercat up and running but not the linuxcnc-ethercat part as everytime I try a simple config using lcec components it fails to start the configuration. I actually had follow the instructions on the provided link before but there was still an issue at the end.
However you indicate a manual modification during the linuxcnc-ethercat installion that I did not do so it might explain why I have been failling so far. nano /git/linuxcnc-ethercat/src/lcec_main.c (add here [#include "rtapi_mutex.h"] below [#include "rtapi_app.h"])
I will give it a try and le you know. Thanks a lot.
PS: edit, it is working now apparently thanks the manual modification that you indicated during the linuxcnc-ethercat installation. I can now make linuxcnc with ethercat working on either a 32bits or 64bits architecture on a debian rt kernel. This line to be added make it work either for 32 or 64bits.
Thanks again
Nicolas
Last edit: 7 years 9 months ago by Nico2017. Reason: More precise results
Time to create page: 0.417 seconds
