- Thank you received: 26
Beckhoff ethercat 64 with bit linuxcnc, How to install.
- Nico2017
6 years 2 weeks ago #185882
by Nico2017
Replied by Nico2017 on topic Beckhoff ethercat 64 with bit linuxcnc, How to install.
Hi Grotius,
thanks for the update for installing linuxcnc and ethercat on Buster.
Did you manage to make glade and its library working on this OS? To me I manage to do like you: ethercat + linuxcnc but still struggling with the linuxcnc library for glade installation and I believe this is related to the python version.
Cheers,
Nicolas
Cheers,
Nicolas
- Mduran
6 years 2 weeks ago #185888
by Mduran
Replied by Mduran on topic Beckhoff ethercat 64 with bit linuxcnc, How to install.
hi grotius, in the script this part fails me:
3. Install linuxcnc-ethercat
$ cd linuxcnc-ethercat / => make
it shows me the following error:
configure.mk.8: *** halcompile / comp executable not found or set.
Do you know what is it?
- Grotius
- Thank you received: 2349
6 years 2 weeks ago - 6 years 2 weeks ago #185931
by Grotius
Replied by Grotius on topic Beckhoff ethercat 64 with bit linuxcnc, How to install.
@ Nico,
Ahaa... i did not know that.
To install glade on buster :
Usage : $ sudo ./setup2.txt
It has a txt extension, but that doesn't affect a bash script at all :laugh:
Good luck !!
@ Mike,
The linuxcnc-ethercat is the easyest to install.
For example, you can execute this script :
usage $ ./setup1.txt
Good luck !!
@ Mike,
Last edit: 6 years 2 weeks ago by Grotius.
- TheRoslyak
- Thank you received: 37
5 years 11 months ago - 5 years 11 months ago #190749
by TheRoslyak
Replied by TheRoslyak on topic Beckhoff ethercat 64 with bit linuxcnc, How to install.
A very dumb question
How I can to send command to el2004 from terminal?
Ethercat download -p (0/1) -t bool 0x7000 1 1 isn't work?
Upd. I do this by "halcmd lcec.0.D2.dout-0 1" But how to send it by simple terminal?
Last edit: 5 years 11 months ago by TheRoslyak.
- Grotius
5 years 10 months ago - 5 years 10 months ago #190881
by Grotius
This post has a attachment txt file with example command's. It point's to the documentation for the command's.
forum.linuxcnc.org/24-hal-components/223...ver?start=990#189977
file
file
Last edit: 5 years 10 months ago by Grotius.
- chimeno
- Thank you received: 125
5 years 10 months ago - 5 years 10 months ago #190903
by chimeno
Replied by chimeno on topic Beckhoff ethercat 64 with bit linuxcnc, How to install.
Hello @TheRoslyak
It is trying to send an SDO configuration value to a PDO, I think it is not possible, but it can send a pulse to the register that will be reflected in the output an instant.
registry value
value
Greeting
Chimeno
ethercat reg_write -p4 --type int8 0xf00 0x01
0xf00
0x01
Greeting
Chimeno
Last edit: 5 years 10 months ago by chimeno.
