Beckhoff ethercat 64 with bit linuxcnc, How to install.
5 years 7 months ago #200895 by V-max
Hi.
Doing:
4. configure for debian
Terminal :cd debian
Terminal : ./configure uspace
(should run without errors)............jejejejejej
I obtain:
Package libxenomai-dev exists, but information about its source package
is not available. This most likely means that you do not have the
right deb-src lines in /etc/apt, or that you need to "apt-get update".
I dont find the repositories.
5 years 7 months ago - 5 years 7 months ago #200900 by db1981
have you already tryed:
sudo apt-get update, after this
sudo apt-get upgrade
if this fails again, skip this step. And do the next step and obeye the output from the other configure step.
Last edit: 5 years 7 months ago by db1981.
5 years 7 months ago #200901 by V-max
Yes for sure.
5 years 7 months ago - 5 years 7 months ago #200902 by db1981
if this fails again, skip this step. And do the next step and obeye the output from the other configure script.
5 years 7 months ago #200904 by V-max
Hi
Skiping:
Terminal: ./configure uspace
All whent well
5 years 7 months ago #200906 by db1981
okay, that means linuxcnc is running as rip install now ?
Time to create page: 0.589 seconds
